E63/E64 BMW Technical Service Bulletin's (SIB's) - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 03-17-2017, 11:47 PM
myles_92 myles_92 is offline
Mein Auto: 08' E64 650i/08' E60 M5
Can we make a sticky of any and all TSB's that are available for the E63/E64? I know there are sites that show them all and people can hunt around for them, but a nice central (FREE) location would be nice. I've already found a considerable amount and I'm sure with everyone's contribution we'll have a nice compilation. I've attached what I've got
__________________________________________________ _________________________
Edited to show SIB Subjects
SI B 11 01 07 Engine
SUBJECT
N62 and N62TU Crankcase Ventilation System – Cold Climate Conditions
SI B 12 05 07 Engine Electrical Systems
SUBJECT
Diagnosis: Low Oil-Level Warning Message Is Displayed
SI B 24 03 09 Automatic Transmission
SUBJECT
550i and 650i with N62TU and 6HP26 - Various Drivability Complaints
SI B 24 08 06 Automatic Transmission
SUBJECT
ZF 6HP Transmissions - Mechatronic Sealing Sleeve Seepage
SI B 25 01 09 Gear Shift Mechanism
SUBJECT
E6x GWS: Gears D or R Cannot Be Selected
SI B 25 03 07 Gear Shift Mechanism
SUBJECT
Sport Transmission Paddle Shifters Inoperative - Diagnosis
SI B 32 17 08 Steering and Wheel Alignment
SUBJECT
Rubbing and/or Scraping Noise from the Steering Column
SI B33 01 02 Rear Axle
SUBJECT
Grinding Noise from the Differential during Slow Cornering
SI B33 02 06 Rear Axle
SUBJECT
Recall Campaign 06V-277: Inspect Rear Shock Absorbers
SI B34 04 10 Brakes
SUBJECT
Recall Campaign 10V- 446: Inspect Brake Booster Vacuum Supply Line
SI B34 05 06 Brakes
SUBJECT
Service Action: Replace SZL Optical Element
SI B54 17 06 Special Roofs
SUBJECT
Convertible Top Does Not Completely Open or Close
SI B 61 03 05 General Electrical Systems
SUBJECT
Software Errors Corrected with Progman
SI B 61 07 06 General Electrical Systems
SUBJECT
No Crank, No Start, CAS FC A111
SI B 61 08 00 General Electrical Systems
SUBJECT
Closed-circuit Current Measurement
SI B 61 13 05 General Electrical Systems
SUBJECT
Dead Battery - Energy Diagnosis Must Be Performed
SI B 61 14 03 General Electrical Systems
SUBJECT
SI B61 14 12 General Electrical Systems
SUBJECT
Recall Campaign 12V-126: Check the Battery Cable Connection
SI B 64 08 07 Heating and Air Conditioning
SUBJECT
Important Information about Heating and Air Conditioning
SI B 65 28 07 Audio, Navigation, Monitors, Alarms, SRS
SUBJECT
CCC: Radio Does Not Resume With Previously Selected Station
SI B65 30 05 Sound System, Cruise, Alarms, Monitors
SUBJECT
CCC: MP3 CD Playback Not Available
SI B 65 75 06 Audio, Navigation, Monitors, Alarms, SRS
SUBJECT
Airbag Warning Lamp for OC3 Seat Mat Fault
SI B84 13 04 Phone, Navigation Systems
SUBJECT
BMW Assist with Integrated Bluetooth
SI B 84 14 05 Communication Systems
SUBJECT
Retrofitting a Telematics Control Unit (TCU) with Bluetooth Technology
Old 03-23-2017, 04:01 PM
fotis fotis is offline
Mein Auto: bmw 650i
thanks
Old 07-15-2017, 06:37 AM
VAQWAN VAQWAN is offline
Mein Auto: BMW 1985 e24 Euro 1982 e
Transmission problems
Sent from my HTC Desire 530 using Bimmerfest mobile app
Old 10-24-2017, 01:01 AM
Tony_504 Tony_504 is offline
Mein Auto: 2005 645ci smg
My 2005 645ci smg has been having trouble getting into gear lately, it’ll drive fine for a while then out of no where it won’t shift, and I don’t hear the pump “prime”
Old 10-24-2017, 01:02 AM
Can it be the salmon relay, or is my pump done?
Help
Sent from my iPhone using Bimmerfest mobile app
