Evap solenoid valve resistance 1999 i6? - Bimmerfest - BMW Forums
Old 12-20-2018, 11:01 AM
Arawak420 Arawak420 is offline
Mein Auto:
CEL came on when I pulled out the driveway. I replaced fuel cap. My scan tool says evap. I'm guessing purge valve. Cold Idle is a little rough but doesn't drop rpms. What is the ohm resistance of the solenoid valve suppose to be at? I'm showing a constant 24.5ohms when I checked.
Sent from my SM-N960U using Bimmerfest mobile app
Old 12-20-2018, 01:18 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
Resistance is less important than whether or not it leak's when it's supposed to be closed. Remove the valve and use if you can blow thru it when de-energized.
Old 12-20-2018, 01:35 PM
Mein Auto:
Thanks. So I shouldn't be able to blow through it?
Old 12-20-2018, 02:46 PM
Mein Auto:
Think this may be culprit. The hose clamp was broken off. The tube was kinda loose but not to much. But prolly enough to lose pressure. I'll reset codes and report back. Click image for larger version
