Auto H functionality - Page 3 - Bimmerfest - BMW Forums
Old 08-24-2019, 07:53 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Just another FYI in case it was overlooked. The gear shift lever can be pushed into N from D without having to press the safety button (just like the old BMW gear shift levers prior to the new "joy stick" versions. So don't fear that you're going to push the lever into reverse if you found yourself needing to disengage from the transmission. If you don't press the button, the gear shift will stop in N.
But to get back into D...you do need to press the safety button.
And also...to actually turn the ENGINE OFF (when you're in motion)...you have to move out of D and put the gear shift in NEUTRAL...then press the START/STOP button once to kill the engine...then press the STOP/START button again and the parking brake will come on. (I recommend waiting until your speed has slowed down (unless you're heading for a brick wall or cliff) because as mentioned above...I was only doing about 20 MPH and was already coasting from the 1st press...then when I did the 2nd press of the START button...the car bogged down to a stop real quick.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 08-24-2019, 11:47 PM
ArgentoCarNut ArgentoCarNut is offline
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
You sir, are more brave than I am... I was expecting something bad to happen, so I acted with urgency
Sent from my iPhone using Tapatalk
Old 08-25-2019, 05:02 AM
Falkon Falkon is offline
Mein Auto: 2008 BMW X5 3.0si
Just another FYI in case it was overlooked. The gear shift lever can be pushed into N from D without having to press the safety button (just like the old BMW gear shift levers prior to the new "joy stick" versions. So don't fear that you're going to push the lever into reverse if you found yourself needing to disengage from the transmission. If you don't press the button, the gear shift will stop in N. But to get back into D...you do need to press the safety button
That's very correct
This is really my concern; getting into Park P so quickly while still at some speed may not be so good for the transmission.
Old 08-25-2019, 12:37 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
From what I understand, the zf trans will not go into park until you are stopped.
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
Old 09-04-2019, 07:05 AM
QSilver7's Avatar
Good point...I agree that it was braking action that brought the car to a stop...it didn't feel like the transmission was being jammed into PARK (which would probably damage the parking pawl {if these modern BMWs even have one}).
Braking, in this situation, is probably the same operation as the Auto-H and Parking brake activation (see info below). As long as the car is moving, the hydraulic brakes (DSC) is slowing momentum...then when the car stops, the electro-mechanical parking brake is applied (how this is done varies by build date):
Name:	Parking Brake button and Auto Hold button Functions.jpg
(SOLD)
Old 09-04-2019, 07:10 AM
Doug Huffman's Avatar
Nuclear engineer
I believe that the selection of Park will be refused until some low speed higher than zero stopped. I believe also that ZF still uses a 'pawl'.
