Am I missing something? - Page 2 - Bimmerfest - BMW Forums
Old 07-29-2019, 03:19 PM
2010xdrive35d's Avatar
2010xdrive35d 2010xdrive35d is offline
Mein Auto: 2010 X5 xdrive35d White
Originally Posted by blue dragon View Post
Here is the original thread from 5 years ago where I identified the problem
https://www.bimmerfest.com/forums/sh...highlight=4b99
That's it! I knew I saw it on here reading around, just couldn't remember where the thread was and I'm glad you added here blue dragon! You're the reason I started on this. Atleast you had parts to leak.. lol
Mine are broken or missing altogether.
Old 07-30-2019, 09:00 AM
Update: Received an email from the GM at the dealership and he said they would be mailing the parts out today and apologies they missed that. So I have to put them on myself.. It's all good. Better than having to buy them. And like Doug pointed out it will be a good time to inspect everything under the hood. Get familiar with it all.
Old 08-04-2019, 06:29 PM
Final Update: I think it's pretty much a wrap. Not missing anything anymore... except 2 screws. Which I'm pretty sure I can source those pretty easily.
Box showed up with my parts and they were super easy to install.
Thanks for all the feedback and contributions on this thread!
P.S. I apologize for all of my pictures being so dark. As you can tell I'm normally doing all my work at that time after the wife and kids are in bed.
ID:	860239   Click image for larger version
Old 08-11-2019, 06:58 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 35d, MY2011 150,000 mi
Only reporting back . . . only had to replace the three pieces, rest of the pieces were all in good condition . . .
while doing this replacement checked the injector area - no corrosion . . . so I am hoping no damage from those broken partitions . . .
I used to check for cracks . . . mine cracked neatly, a quick look didn't reveal anything . . . after reading this thread I went back and placed my finger underneath the partition (where the cracks happen) I could feel it . . . closer examination revealed they were all cracked . . .
glad I caught it . . .
Old 08-11-2019, 07:55 PM
Glad you did too!
You brought up a good point... I need to go back and check my engine for sure! Just to look for corrosion. Fingers crossed none present.
Also.. I need someone else's eyes on this screw I found. Can't seem to pinpoint the exact two I need but pretty sure this will do the trick. Thoughts?
https://www.fcpeuro.com/products/bmw...nt-51419124467
Old 08-12-2019, 08:17 AM
Originally Posted by 2010xdrive35d View Post
. . . Also.. I need someone else's eyes on this screw I found. Can't seem to pinpoint the exact two I need but pretty sure this will do the trick. Thoughts?https://www.fcpeuro.com/products/bmw...nt-51419124467
Not sure I understood your question correct . . . are you asking whether the BMW Torx Bolt (P/N 51-41-9-124-467) is part of the engine bay partitions?
No, it is not . . . the torx bolt you reference is part of the gear selector assembly . . . #6 on this diagram.
The screws you need for the engine bay partitions in case one or more are missing/broken are shown in this diagram.
Old 08-12-2019, 12:03 PM
You're right! The torx bolt that ties the 2 side partitions together with the center.
I see the diagram but it gives all available hardware for engine compartment mounting parts.
Which one do I need?
Old 08-13-2019, 09:57 AM
I took a look under the hood (see picture) . . . my best guess is Item #16 on this diagram . . . Torx-bolt with washer (P/N 07-14-7-114-625)
You could also call a BMW dealer parts line and have them look up this part number . . . and have them confirm this is the right screw/washer you need . . . they probably have a diagram that shows where #16 goes.
Finally, IMO any screw with the matching thread and a washer should be plenty good . . .
Name:	BMW Torx Bolt with Washer 07-14-7-114-625.jpg
Old 10-09-2019, 01:59 PM
ill_kuma's Avatar
ill_kuma ill_kuma is offline
Mein Auto: 2009 X5
I recently noticed my 3 pieces are broken as well and didnt want to start a new thread as there are a few of these already. I know what I need to buy and it costs a bit over $400 for all 3 pieces. So far everything on my X5 is OEM but I cant seem to justify paying $400 for some plastic pieces vs like $45 for 3 pieces on eBay. My questions is will the quality be that different to justify the crazy price difference? Please let me know your thoughts as I will be ordering it soon. Thanks.
Old 10-09-2019, 02:13 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
I have a brand new one from China sitting in my garage. Ordered by mistake. Material quality was fine but the holes were hand drilled and a little off the spot it should have been. Never tried installing.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 10-09-2019, 03:08 PM
Gary214 Gary214 is offline
Mein Auto: 2011 X5 50i M-Sport
I replaced the partitions at the dealership. Chinese stuff may look good but material will breakdown and cause a fire hazard.
Old 10-09-2019, 08:30 PM
According to most that have replaced theirs speak to how vital these parts are when it comes to the possibility of leaks and shorting out injectors. Specifically the #5.
It's easy for me to say because I didn't buy mine, but I wouldn't cut corners on these parts especially due to the purpose they serve.
Old 10-09-2019, 08:32 PM
This is more of a diesel issue right? Iím not doing anything with my partitions I have so if ill_kuma wants mine he can have them for shipping and a beer.
Old 10-09-2019, 08:36 PM
Old 10-14-2019, 05:15 PM
This was the China one. Click image for larger version
Old 10-14-2019, 07:52 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
This is more of a diesel issue right? I'm not doing anything with my partitions I have so if ill_kuma wants mine he can have them for shipping and a beer.
If you don't mind water on your engine it's not just a diesel issue. Are you thinking gas engines have a different better part lol...
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
Old 10-14-2019, 08:01 PM
Nope. Just a spark plug in a different position under the drip. Isnít it something like cylinder #5 that gets the drip from the typical leak on the diesel? Not where my plugs are? They leak on all models but mostly affect the diesels if Iím not mistaken.
Old 10-15-2019, 03:59 AM
I'd think it's still a problem because other things can go bad.
I used epoxy glue to fix my cracked side partitions and it's held up for a year +
