2007 750i will reverse but not drive. Please help. - Bimmerfest - BMW Forums
Old 10-15-2019, 06:08 PM
dlb26666 dlb26666 is offline
Mein Auto: 2007 750i
Can someone please help? I have a 2007 750i. The car has 107k miles. I bought it at an auction and drove home no problem. Almost 2 months later, the car started shifting rough then "TRANSMISSION FAULT, DRIVE MODERATELY" message with YELLOW GEAR on the display. When coming to a stop, the car would stop then move forward again until a full stop. Then, taking off, it's like I had to "baby the gas pedal" for it to shift gears. Once on the highway, no problem.
Now, the vehicle has to warm up and when it does, it wont stay in gear. Eventually (after a few more minutes) the shiftier does engage in reverse and will move. When I shift to drive it drops back to to park but it wont engage in drive.
I took it to the local BMW Dealer about 2 weeks before all this and had diagnostics ran. Please bear with me because it's a laundry list of codes (see Attachments).
Please help! I'm looking for the best way to go on the repair without getting "hosed" Thanks all. I really could use your suggestions and appreciate your help. Thanks.
ID:	868355   Click image for larger version
ID:	868357   Click image for larger version
ID:	868359   Click image for larger version
Old 10-15-2019, 06:45 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
look like a bad battery coupled with probably a leaking transmission. Change the fluid, seals and filter/pan.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 10-17-2019, 07:24 AM
mathat mathat is offline
Mein Auto: 730d
did it really cost 1000 for a new water pump - was it actually broken or was it just a faulty thermostat ?
anyway +1 on csmeance , your gearbox needs more fluid , you might as well service it while you are there to stop the leaks (the oil can get into the electrics hence changing the seal)
would have thought they would have told you this - since they have taken all your money !
Old 10-17-2019, 11:46 AM
Thanks for your response. No they wanted to charge me that much for the thermostat I told him now that's okay I don't think that's what the problem was initially and then when I asked for the cheat codes they acted as if they didn't even want to give them to me and so that's when I knew that there was a problem going to that dealership. So now I'm looking at going to a shop that specifically works on Mercedes and BMWs and they're pretty good they worked on my 98 750 some time ago. be
I just wanted to get a pretty good idea what I'm looking at because I don't want to be faced with the shop telling me that I'm going to need a new transmission when I really don't. I've been hearing that in cases like this maybe it'd be good to change out the transmission filter and also check the "mechtronics"? Any ideas on that? Thanks
Also what might I be looking at as far as price for repair? I really do appreciate as much input as possible.
Old 10-17-2019, 07:05 PM
Any one else solved an issue similar to this? Can some PLEASE HELP! What do some of these codes mean? Yes, I'm a Noob
Old 10-18-2019, 02:09 AM
Mein Auto: 730d
In my opinion don't worry about the codes - most will be from low battery or when the power dipped when starting (my car is full of them but all works fine) , look up gearbox oil change and then get then to do that and the the little parts - if your gearbox worked fine before there would be no point in going to far into the gearbox but get all the main parts done as they are small cost parts (1 seal +5 rubber bits and a filter + 7 liters of expensive oil), get the codes cleared and make sure the car gets to temperature and then see what problems still exist.
I am not sure what codes you have could be important maybe someone else will know if they are important
Old 10-18-2019, 08:12 PM
Thanks for your reply I really appreciate the help. I spoke to a local shop that's worked on my cars in the past. They told me to bring it in a they'll run their own codes to see what the problem is. Question: should I go ahead and order the transmission filter kit and have them replace that too? I am new at this and read as many post as I could. This type of problem comes up and suggestion is to replace trans filter as it could be leaking but you don't see fluid on the ground. Do you think that may help since I might suggest the other possible solution (Gear Box)? Thanks.
Old 10-21-2019, 08:08 PM
2007 750i
Well, I had the Car towed today to the shop. Hope it's not a new transmission. I'll keep you posted...
Old 10-21-2019, 08:21 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
Most of the time it is old bridge seal and the 4 sealing tubes to the valvebody. Also, if your fluid level is off or the mechatronic sleeve is leaking, you will experience this behavior. Rarely will it require a new transmission (these are pretty robust). Been there, done that.
Mineral White Metallic 1993 850Ci
Alpine White III 2008 B7
