Glass rubber cover, windshield & rear window (E39) - Page 15 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-21-2014, 04:21 AM
shorecrab shorecrab is offline
Mein Auto: BMW 523i SE 1999 (E39)
I've just replaced the windscreen moulding on my 1999 523i SE and discovered something which I haven't read about on this forum - it was causing me a problem so I thought I'd share it. The moulding seated perfectly in the top corner on the driver's side, but would not do the same on the other top corner. It became obvious that the width of the channel between the edge of the glass and the body was significantly narrower on this side and would never accept the rubber moulding. I began to think that the windscreen must have been a replacement and that I'd need to modify the rubber to make it fit. Then I discovered that the strip of roof metal at the edge of the roof - the strip that has the holes for mounting a roof rack - slides a bit from front to back. So I pushed it backwards with the side of a screwdriver and the necessary width of channel opened up and the moulding went in nice and flush. You can then slide the strip forwards if desired to 'trap' the moulding more firmly in the corner.
Old 11-21-2014, 05:46 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2016 X5, 2006 M3, 2002 M5
Good info, and glad it worked out for you. But...
Screwdriver shouldn't be anywhere near the glass. Need to use plastic tools.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
LeMans 2002 M5, Black/Tech Graphite, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Wife's chariot - 2016 xDrive 3.5i, Sapphire over Black. M Sport, Premium, Cold Weather, Driver Assist and Plus, Luxury and MultiContour Seats, Roof Rails, Harman Kardon
  #353
Old 11-21-2014, 06:37 AM
Yes I agree - much safer to use plastic tools. I just hope the new rubber from BMW is of a more lasting quality than the original.
Old 02-18-2015, 05:39 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
There's a very nice windshield cover molding R&R DIY here today ...
> E39 (1997 - 2003) > DIY Windshield and rear windows seal cover
Originally Posted by jieg View Post
This is my second DIY
I had purchased the windshield and rear windows months ago.
I visited a couple of shops, both: wanted $100-150 for the job, both wanted to remove both glasses then reinstall, both mentioned the risk of breaking the glass.
I read on Real OEM that this rubber pieces are "cover" not a seal, so I thought WTH, and finally decided to DIM (do it myself)
WARNING: Avoid trouble with the wife. THE RUBBER DEBRIS FALLING ON YOUR FLOOR WILL HAVE A DARK GLUE THAT WILL LEAVE STUBBORN STAINS, take precautions.
  #355
Old 10-19-2015, 12:34 PM
Stueyo Stueyo is offline
Mein Auto: 528i bmw 2000
Agent 99
Seems to be a common problem here in Florida , first the moisture in the morning then the tremendous heat in the afternoon .
Even the windshield washer tubes dry out and go brittle then snap .
There should be some kind of silicone sealer to prevent this
  #356
Old 01-28-2016, 02:58 AM
bitzer bitzer is offline
Mein Auto: X5 E53 3.0i
10 Australian summers has made a mess of our X5 E52 Upper Trim Seal for Front Windshield Moulding. Does not rain much here so it's just trim and is not causing any leaking issues. Going to replace it and it seems easiest to get one from the USA than here but finding the exact one on Ebay is challenging.
PN # for the 2006 seems to be
Manufacturer Part Number: 51 31 7 182 004
Other Part Number: 51317182004
Looked on youtube and no one seems to have done this particular one but looks simple and as was said they windscreen specialists recommend the window screen removal but it's looking like a furphy.
The LHS top is in the best condition and a photo of it attached.
  #357
Old 01-28-2016, 07:01 AM
BlackBMWs's Avatar
BlackBMWs BlackBMWs is offline
Check twice, fix once...
Mein Auto: 540it 533i 318ic 325i
Www.getbmwparts.com
1999 540it - Jet Black/Sand Beige, style 5 rims, Zionsville Cooling kit
1984 533i - Schwarz/Schwarz, 17" style 65 reps
1997 318ti Sport - Schwartz II/Schwartz Anthratz, style 68 rims
1995 318ti Sport - Schwartz II/Schwartz Anthratz, style 27 rims
1994 325i Sedan - Bostongrau/Tan
1991 318ic - Schwarz/Anthratz Stoff
1985 635CSI - Schwartz\Sand - Sold
1984 318i - Champagne/Tan, Stock - Sold
BMWCCA# 160411
  #358
Old 01-28-2016, 11:24 PM
To Australia as well? I am cussing now, was in SF in August should have brought a few bits then...grrh.
  #359
Old 03-02-2016, 05:43 PM
kscutie79 kscutie79 is offline
Mein Auto:
I have a 2003 525i i am in kansas and have the same issue how do we find out which cars are in the recall? I thought i read somewhere here that there was a recall on this
  #360
Old 03-16-2016, 01:36 AM
For mine this one was purchased
Cover, windshield 51317182004 $27.82
It was easy as to remove the old degraded one, clean it's channel out with a good hosing and microfiber rub and the new one fitted like a dream just using my hands making sure both ends lined up.
  #361
Old 03-16-2016, 02:20 AM
Top trim windscreen X5
The finished product.
  #362
Old 05-23-2016, 09:06 PM
avinator avinator is offline
Mein Auto: 528i
same problem here... I want to change mine as well. Anyone know a good glass shop in the sf bay area ? East bay preferred.
  #363
Old 05-24-2016, 05:30 AM
Edgy36-39's Avatar
Constantly Learning
Why are you asking for a glass shop - this is a DIY thread!
BLUE HEAVEN:
  #364
Old 06-22-2016, 11:12 AM
Marine48 Marine48 is offline
Mein Auto: 2006 530xi
Seal cracking
I have a 2006 530xi and i'm having the same problem.
  #365
Old 09-07-2016, 03:52 AM
It's so easy. I used Windex to clean out the channel. Looked closely at how the old one fitted (take a photo) lined it up on each side and slotted it in and tapped it down with fist and a matter of minutes.
  #366
Old 09-23-2016, 08:43 AM
stephenc59 stephenc59 is offline
Mein Auto:
I also have the cracked window cover on my front window on a 2001 e39
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
2003 X3 issue with the rear window rubber Techson X3 E83 (2004 - 2010) 2 12-23-2005 08:29 PM
rear window switch RChoudry 3 Series & 4 Series 4 07-19-2002 04:38 PM
Odd Rear Window Problem GSR13 3 Series & 4 Series 6 07-18-2002 08:25 AM
