Accidental rev in freezing weather on cold start - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 02-11-2019, 08:55 AM
Chilli42 Chilli42 is offline
Mein Auto:
Hi,
So I jump in the car this morning and it's about 30 degrees outside. Start up the engine and it idles for maybe 10 secs, then instead of pressing the brake pedal, I press the gas. Before I realized what I did the engine revved up to around 4500 rpm :-/
I know the engine is not toast, but is this likely to cause any long term damage as a one-off?
Also, what damage/harm could this potentially do to the engine and how does that actually manifest? Is it just likely to cause potential issues at like 120k miles or something when the engine is much older?
Old 02-11-2019, 09:27 AM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
I wouldn't worry too much about it, but I wouldn't make it a regular practice. If the car has been driven regularly, there still would have been an adequate amount of oil film between any bearing surfaces until the oil pressure builds once again. The oil wouldn't have had a prolonged time to totally drain back into the oil pan. Just a little "woopsie", nothing more.
If you can't fix it, you don't own it.
Old 02-11-2019, 12:03 PM
marcthedark marcthedark is offline
Mein Auto: X1 F48
No issues from a one time incident. Do not overthink it
Similar Threads
Backfiring on cold start - dealer claims its normal 2012-x5-35i E70 X5 M and E71 X6 M (2010 - 2015) 2 02-24-2019 07:24 PM
Rough Idle on cold start zcasavant 1M & M2 8 05-29-2003 05:40 PM
Idle revs dropping in cold weather? DavyByrne 3 Series & 4 Series 15 02-27-2003 10:31 AM
cold start clinking noise sj-02-325Cic 3 Series & 4 Series 13 04-05-2002 11:02 PM
