To anyone looking for a spare tire solution for our F30 335's - Bimmerfest - BMW Forums
Old 07-22-2013, 09:47 AM
335Fanatic 335Fanatic is offline
Mein Auto: F80 M3 / E24 633CSi
Thumbs up To anyone looking for a spare tire solution for our F30 335's
Got this for myself and can't imagine driving my car without a spare now. Absolutely a must have for anyone with non run-flats tires. But even with run-flats, there is only a limited distance you can drive on a damaged tire or you might not be able to drive at all if there is a severe damage to the tire. I was completely relying on BMW Roadside Assistance before, but good luck with that if you are in a remote location (it will take hours for the tow truck to show up as I just learned).
It doesn't take up much space in the trunk even though our cars don't have a dedicated space for it (shame on BMW).
Got mine from bimmerzone, great guys to deal with (Vincent, in particular)!
Anyone else is using this product?
ID:	387950   Click image for larger version
ID:	387951   Click image for larger version
Old 07-22-2013, 10:00 AM
bimmerzone bimmerzone is offline
Past Sponsor
Mein Auto: E63 650i, F13 M6
THanks for the mention!
For all who needs the spare for the F30 335 (including Msports)
Here is the link:
http://www.bimmerzone.com/BMW_Perfor...T-F30-KIT.html
Thanks!
Old 07-22-2013, 10:30 AM
SNye45 SNye45 is offline
Mein Auto: 2014 328xi
Spare Tire
This seems a great solution but it brings up a quick question.
I am still waiting for my car to arrive, so I can't verify the answer
Since their cars are fitted with RFT, and does not supply a spare, does BMW supply a jack with their cars, or is that gone too?
Old 07-22-2013, 10:45 AM
tturedraider's Avatar
Freedom isn't free!!
No jack. The BMW jack is worthless anyway. One should get a good scissor jack. They can be had fairly inexpensively.
There is a list of parts for a spare and jack in a sticky at the top of the E9x forum. You can put that together pretty inexpensively. It's only a 17" wheel, but there shouldn't be any fitment issues. It has been used on E9x 335s and there aren't any significant differences on F30s.
www.bmwcca.org
Old 07-22-2013, 11:14 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
the E60 spare rim needs a spacer to clear the 335i F30 brakes in the front-- i used a 15mm as it was hubcentric.
i gave my original kit to my bro who got an E90.
off the top of my head, its been a few months:
bmw E60 rim- $60
kuhmo temp spare tire- $30
Spacer and bolts- $40
scissor jack- $20
total cost $150
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 07-22-2013, 06:46 PM
joedoe joedoe is offline
Mein Auto: MY2014 BMW 328i
Here is the link:
Thanks!
Ridiculously overpriced
Old 07-22-2013, 07:22 PM
hans007 hans007 is offline
Mein Auto: 2017 A4 Quattro
i am planning on just using a fullsize spare. i mean a 225/18 rim is only 80mm wider than the space saver. only going to take it with me on road trips (i do 4-5 trips to vegas or bay area from where i live a year) . no need to use spacers etc, and you can drive on it for just as long as any tire and dont have to worry about a tiny space saver wheel.
KLC KLC is offline
Mein Auto: '13 335i Sport
bmw E60 rim- $60
scissor jack- $20
total cost $150
This is much more realistic.
For the price of the OP's suggestion I could have a proper 5th wheel and tire.
ED - 5/13/2013
PCD - 7/17/2013
2013 335i Sport Line PPK | Alpine White/Coral Red | ZDH | ZCW | 2TB | ZTP | ZPP | 508+3AG | 5AC
Old 07-22-2013, 07:25 PM
you would be surprised at how much space a full sized tire will take up in your trunk...
Old 07-22-2013, 07:35 PM
when i first found this retrofit kit for the e90, it was a reasonable 270 shipped, i specifically set out to find a reasonable alternative to the gouging, iirc leatherZ was charging 400+ for an e46 spare kit with spacer.
now it looks like we are back where we started. 579 including the jack set is back in the insane category.
Old 07-22-2013, 08:01 PM
well, what i was saying is the space saver spare in the link, is exactly the same diameter , just its 145mm across instead of 225mm. so it would only be 3" more in 1 dimension.
i know it'd take a good amount of space, but i'd only have to put it in there 4-5 times a year and the rest of the time i could go with tire sealant and a a compressor
Old 07-23-2013, 03:37 AM
Past Sponsor
yes, its unfortunate that the Bridgestone tire itself cost around $300.. nothing much we can do, but this is the best suited tire for this application.
Old 07-23-2013, 06:48 AM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i (F30)
Of course, this could encourage summer tire use. One of the snow tires or all season tires, used during the winter, could be the full sized spare most of the year. One of the summer tires would be the spare during the winter.
Old 07-23-2013, 08:48 AM
F30's rolling diameter is .5 greater than E60's rolling diameter (26 vs 25.5) which is a big deal (anything more than 1% is).
Plus you can always sell your spare to the next owner when you move away from F30. Not all people will buy untested E60 solution which is not meant for our cars. The initial cost might be cheaper (though nowhere near the cost that Orient330iNYC has provided if you buy brand new quality parts), but it is for you to decide.
Old 07-23-2013, 10:17 AM
Originally Posted by 335Fanatic View Post
F30's rolling diameter is .5 greater than E60's rolling diameter (27 vs 26.5) which is a big deal (anything more than 1% is).
its actually not. the F30 stock rolling diameter is 26", the same as the old E60, so the E60 spare, so either bmw didnt know what they were doing when they specced the spare or...
base tire size for the E60: 225/50/17 = 25.9"
base tire size for the F30: 225/45/18= 26.0"
bmw specs the same spare for all variants of the E60, with a rolling diameter of 25.5. it was standard equipment on the base E60 (that did not come with runflats) with a tire size of 225/50/17.
Old 07-23-2013, 11:02 AM
Past Sponsor
the rolling on the E60 Spare is 25.5, and the F30 is 26
Anyway, OP was just trying to be nice to let everyone know about what he found...
Old 07-23-2013, 08:14 PM
Nordique's Avatar
Nordique Nordique is offline
Mein Auto: 2013 320i ZSP ZMT
Really, you should just carry a full-sized spare tire, mounted on a steel wheel, in your nice big trunk. Don't forget to start the wife on steroids too so that she can get that large heavy wheel out of the trunk (since you had that hernia, you have an excuse not to haul that spare wheel out of the trunk--which is surprisingly high). I've only driven about 240,000 miles on my two previous BMW three-series, hauling around that huge heavy spare wheel, located SO low in the trunk, and never needed it. Not once.
Old 07-23-2013, 09:52 PM
Dave 20T's Avatar
Super Moderator
In my previous car, I retrofitted a full sized spare to replace a compact spare. In my new BMW, I plan to eventually use a snow tire as a full sized spare if I travel more than about 50 miles away, which isn't often. For me, only a trip to expensive British Columbia or over the mountains to eastern Washington state would justify it for me, not locally. Maybe not even south to Portland, Oregon as it is fairly urban much of the way. It might depend on your circumstances. It's nice to be able to drive at full speed, which could be a 70 mph speed limit.
Old 09-05-2019, 03:25 PM
smo1usa smo1usa is offline
smo1usa
Mein Auto: F33 M Sport
I know this is an old thread, but has anyone thought about the fact that the tires are directional? At least on my F33 they are. 2 spares? I think not. Roll the dice!
Old 09-05-2019, 06:48 PM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
So what if they are directional?
Sent from my iPhone using Tapatalk
Old 09-05-2019, 11:08 PM
Dave 20T's Avatar
Super Moderator
I have a new, never used BMW wheel and a new, never used Dunlop run flat for my F30. This is my full sized spare tire. It's the best because there are no 50 mph speed limitations or 50 miles of use with a full sized spare. You could use it for 10,000 miles and more going at 100 mph if you want
I am planning to get snow tires so my snow tires/wheel set up can be my summer spare tire.
Private message me and I will practically give you the full sized spare tire for a nominal fee, nothing near the price of a new wheel and new tire, which is what I have.
Having a full sized spare is really peace of mind and a feeling of security.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
Old 09-06-2019, 11:09 AM
Kestas Kestas is offline
Mein Auto: 2015 320i
There are plenty of space saver spare tires in the junkyard, but which ones would fit my 2015 320i? You have to match diameter, lug pattern, offset, and maybe a few other things like the pilot hole and brake clearance. My tires are 225/45/18.
Old 09-06-2019, 11:27 AM
Donít get spare tire from junk yard. Wheel? Yes. But tire? Absolutely not. It could be old, exposed to elements etc. you might regret it big time.
Old 09-07-2019, 08:45 AM
Rebound Rebound is offline
Mein Auto: Toyota Prius
I bought a scissor jack from Harbor Freight. It fits the BMW jack points without modification. However, when I tested it, the gear became very hot. It needs a heavy lubricant before being wrapped up in a towel (to prevent rattling in your car).
I stow the jack along with a BlackJack tire plug kit and a 12V tire inflator inside my car. Itís very compact ó much smaller than carrying a spare
Old 09-08-2019, 02:27 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
A well designed scissors jack should not get extremely hot when lifting. I would be concerned about jamming or sudden failure.
bmw spare tire kit 335 msport
