interior heating low - Bimmerfest - BMW Forums
Old 12-21-2019, 10:07 AM
jonopon30 jonopon30 is offline
Mein Auto:
Interior heating is very low. how do I increase?
Old 12-21-2019, 10:09 AM
Doug Huffman's Avatar
Nuclear engineer
Hotter engine coolant temperature.
Old 12-21-2019, 11:14 AM
First thing to check is climate control setting via idrive and make sure your climate settings are not set to cold. It's under options IIRC. If that does not do the trick, something is amiss with the coolant circulation.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 12-21-2019, 06:26 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Check the IDrive settings 1st. Next make sure the coolant is full. If all of the 1st 2 are good, you probably have a bad heater valve. Also check the hoses on both sides of the thermostat to make sure they are both hot. The heater valve is a very common problem & a easy repair. I think the valve is around 200.00.
Have you added coolant recently, & did you turn the heater on full hot while adding the coolant. It is possible air could be trapped, but our system are self bleeding. You can watch the small line that comes in the top on the expansion tank, to make sure the coolant is recirculating.
Super Moderator
What?
Old 12-22-2019, 11:49 AM
roseng's Avatar
roseng roseng is offline
Whatchya smoking big boy?
Old 12-22-2019, 11:51 AM
roseng's Avatar
My heating valve controller in the engine compartment was failing and I had the same issue. It's a fairly easy replacement and not too expensive to do.
