2008 650i Coolant Sensor - Bimmerfest - BMW Forums
Old 01-20-2020, 02:00 PM
2006525XI 2006525XI is offline
Mein Auto:
Happy New Year,
Went to put coolant in the 650 and noticed the red indicator stick was sitting sideways in the tank. I tried to carefully remove it but it sank to the bottom. All that is left is the flat white float it attached to.
Q1. If I remove the tank and get the red indicator out can I reattach it? OR
Q2. Must I replace the tank.
It does not leak.
GOT THE ANSWER, I NEED A NEW TANK
Harry
Old 01-20-2020, 06:13 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Here are some cheaper expansion tanks, that will save you some money. BEHR makes the BMW part.
https://www.rmeuropean.com/Make/BMW/...?catalogID=004
Old 01-20-2020, 06:20 PM
kwikuk kwikuk is offline
Mein Auto: E63 650i
I actually got a new OEM unit when mine cracked for under a hundred quid.
A VERY rare occasion something was cheaper at the dealer.
While your coolant is “dry” take the time to swap out the plastic return line that runs across the front slam panel. I used 10mm ID anno’d aluminium.
You can see it in the pic:
Sent from my iPhone using Tapatalk
2006 E63 650i - Stratus grey
Old 01-20-2020, 06:41 PM
Mein Auto:
Thanks, a bit less expensive on this side of the pond, paid $55.00 for a quality piece. I replaced the other piece about 6 months ago when that sprung a leak.
