Front Hub Replacement Question - Bimmerfest - BMW Forums
Old 12-21-2019, 02:58 PM
Stella650i Stella650i is offline
Mein Auto:
Hello!
Is there a way to remove the front hub without removing the strut?
I was able to remove 3 of the bolts with ease. But the bolt obstructed by the strut I can't reach with a standard open end wrench or mildly offset box end wrench. I would like to avoid removing the strut.
Old 12-21-2019, 03:45 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
https://www.newtis.info/tisv2/a/en/e...nuckle/7BOlXlF
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 12-21-2019, 06:15 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Originally Posted by Stella650i View Post
Hello!
Yes the front hub can be removed without removing the strut. You have to have a offset wrench to get the one bolt off. Work it off slowly, & it will finally work back to where it is easier to get the wrench on it. You could also probably loosen the bolts on the bottom of the strut, & tap it down. It has been several years since I have done this, but the one bolt is a pain to work off.
Old 12-21-2019, 07:13 PM
Mein Auto:
Can you send me a picture of the type of wrench that will fit. I'd like to know the name brand and model if possible. I got a Proto offset box end wrench and the offset is too mild I think.
Old 12-21-2019, 08:00 PM
Super Moderator
I can't remember for sure if I used an open end wrench, or used the offset wrenches below. I think I had to go get the ones below?
https://www.harborfreight.com/8-piec...set+wrench+set
Old 12-23-2019, 10:05 PM
Hsurf's Avatar
Hsurf Hsurf is online now
Super Moderator
Mein Auto: E63 645ci
+1
Yep, that's the style I used when I did it too. I also put a steel tube ove the end of the spanner to lengthen it as a lever, it helped me to apply greater pressure but in a slower and more controlled rate, "Give me a place to stand on and I'll move the earth" and all that jazz .
You probably know anyway but the tightening torque is critical as is replacing the bolts, can't stress that enough on a part like this .
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 12-24-2019, 03:28 AM
Mein Auto:
Thanks. I'm not sure I see how you guys got the wrench on the bolt back there. The spacing is super tight and when I tried to get there, it wouldn't fit. I tried turning the wheel in either direction.
Old 12-24-2019, 11:44 AM
Hsurf's Avatar
Super Moderator
If you're really struggling then try the open end or if you need the leverage a good quality crows foot (don't use cheap with these things) with a ratchet wrench.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 12-24-2019, 01:28 PM
Mein Auto:
Thanks for all the advice. Replaced the hub. Unfortunately my problem still persists. Get a steering wheel vibration without brakes at 65+ mph and when applying brakes, vibration in the steering steering wheel and seat all the way down to 30mph. Had front brakes and rotors changed in the last 500 miles, and also replaced both thrust arms. Had an alignment done when brakes were changed. Beginning to run out of ideas.
Old 12-24-2019, 04:22 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Might just be the tires? That or a steering component issue.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 12-24-2019, 08:51 PM
Super Moderator
Did you replace the upper or lower thrust arms? The lower thrust arms will usually cause that vibration. What does your tire wear look like?
Old 12-25-2019, 11:03 AM
Mein Auto:
Both were replaced. The tire where there is rotor wear, the tire is worn down much more. Not in any type of pattern, as in inner is not more worn than outer or vice versa, but in general just more worn, like it's dragging.
Old 12-25-2019, 05:26 PM
zod zod is offline
Mein Auto: 1987 BMW 535is 2008 E64
Hah! This reminds of the travails of changing the number eight plug on a 75 Corvette. I had to go back to the store twice for tools. Carry on.
Merry Christmas to all.
Old 12-25-2019, 06:15 PM
Super Moderator
The belt in the tire might be damaged, causing the vibration, just a guess at this point. Road force balancing would find or fix the problem?
