Rollover Controller Module Problem (code: 9402) - Bimmerfest - BMW Forums
Old 02-17-2017, 09:08 AM
adamczix adamczix is offline
Adam Cz.
Mein Auto: 650i Convertible
I had some problems with battery few weeks ago in my 55reg 650i convertible (all sorted, new battery fitted now) and suddenly airbag light popped on dashboard and message on screen about restraint system not working properly. I've tried to delete it in local garage with no result. It showed on diagnostic as Rollover Controller internal fault (CODE 9402) and it was impossible to clear. About a week later I went to local 'BMW specialists' with more advanced diagnostic computer (he said its the same BMW main dealers use) and he had an attempt to clear the fault - no result. He said that the only way to resolve this issue is to replace unit. He said he can do it for 300 (brand new module) + labour... around 380 total +VAT.
Now,I found a guy on ebay that has this units (second hand) for sale. He said the only one thing I need to check is the connector color - Green or Grey and he can supply this unit for 150 and I can change it myself.
Did any of you guys had the same problem?
Is it just a straight swap and problem will go away or do I need to visit BMW dealer and pay 1000 to fix it?
Regards,
Adam
Old 02-17-2017, 06:15 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Regards,
Adam
I have had this error 1 time on my 750 when the battery was going bad. After I replaced the battery & charged it for 12 hours overnight, I could clear the error. The error has to be cleared in the module having problems, & reset the ECU in that module. I would charge the battery over the weekend, & have your local shop clear the error in the ECU itself.
Old 02-18-2017, 02:37 AM
Adam Cz.
Thaks for reply HerbP. I went to garage after I've changed battery and error didn't clear.
Sent from my SM-G935F using Bimmerfest mobile app
Old 02-18-2017, 02:04 PM
Super Moderator
Did you charge the battery for 12 hours before trying clearing the error. What program did he use, & how did he perform the diagnostics?
Old 02-18-2017, 02:10 PM
Adam Cz.
we tried to clear the error after i've charged the battery but the battety was already nackered so we tried to do it again after car was fitted with brand new battery. no result.
no idea what program he used.
Old 03-08-2017, 02:37 AM
xrix4096 xrix4096 is offline
Mein Auto: E64 650i
Did you get anywhere with this? I have the exact same issue. I replaced the module with another from eBay and nothing has changed. I'm stumped
Old 03-08-2017, 05:33 AM
Adam Cz.
xrix4096,
I was just about to buy one from ebay as well, was yours with exactly same numbers as the faulty one? people who sell them say they are compatible with other numbers... maybe my mechanic is right. he said i need a brand new one as second hand ones are already matched with original cars and might not work... or somebody is selling faulty units on ebay?
Are you planning to go to Dealer BMW garage to check the issue?
Regards
Old 07-12-2018, 08:28 PM
GatesN54 GatesN54 is offline
Mein Auto: '07 335i cabriolet
Sorry for digging up the old thread but if anyone is interested to know the fix since there are no exact answers.
The issue with the ROC module is the EEPROM's hex code is messed up. It's 100% fixable as i just rewrote the proper code to mine without having to desolder the chip.
Old 07-13-2018, 04:18 AM
Mein Auto: E64 650i
Hey GatesN54,
Please do let me know how to do this. Mine still has the problem and is about to fail it's MOT next week because of it. I'm a software engineer and have some electronic experience and equipment too so hopefully I can use your method if you are willing to share.
-- Chris
Old 07-13-2018, 04:37 AM
Adam Cz.
Hi Guys, sorry for late reply. I managed to fix mine by buying second hand unit on ebay (paid 60). Local BMW specialist ask me to get one with same software and same hardware (all info on top of the unit). It took him 30 seconds to code it after swap. No problems since.
Old 07-13-2018, 04:53 AM
Originally Posted by xrix4096 View Post
Hey GatesN54,
-- Chris
I used carprog to program the chip on the circuit board. You can pick one up with the adaptors on ebay. Ill need the dump from the eeprom on your bad module to correct it
Old 01-23-2020, 02:10 PM
My650iBeast My650iBeast is offline
Custom650i
Mein Auto: 2006 BMW 650I
Rollover Controller Internal Fault Fix Help 9402
I Have the same problem now with my 2006 e64. I tried a new battery with a full charge for 12 hours.
DOES ANYONE KNOW WHERE THE MODULE IS LOCATED? ANY DYI VIDEOS?
