Legacy X5d owner update! - Bimmerfest - BMW Forums
Old 06-01-2019, 09:34 AM
Flying Ace Flying Ace is offline
Mein Auto: M6 GC ZCP; '12 X5 Diesel
Hey everyone!
Not sure if you still remember me. I was pretty active here between 2015 to 2017 until my M6 and life stole my attention away from the X5d and this forum.
My '12 X5d now has 86k miles. Whiles it's no spring chicken, it still runs like the day I picked her up!
Some updates on my issues:
1. My parking break switch broke. My preliminary research indicates that the replacement switch may need coding as you may have to buy the entire switch module!
2. The turbo setup has a lot of leaks. Most are very minor, a significant leak was caught before my CPO expired in 2018 so it was fixed on the company's dime. Yesterday, BMW servicing found another leak with oil on my intercooler.
3. I've been on Nitto Motivos (20 inch staggered setup), for a good 20k miles. It now has 5/32nds depth with some excess inside wear (4/32nds on inside). No big deal on the wear as I had an alignment done before install, and regardless, by the time uneven wear showed, it was time to change the tires anyways.
4. Diesel equipment has been reliable since the initial fixes. I've had the classic list of diesel equipment failures fixed around 60k miles including glow plugs controller, DEF tank metering, and SCR. Recently I've had a CEL on and off. I suspect it's a diesel emissions fault but funny thing is I've never been able to catch it on my rudimentary OBD scanner. Even BMW couldn't read any stored code.
5. Over last 20k, the front driver strut area has developed a clunk on low speed bumps. I've had 2 unsuccessful fixes (trust rod bushings and strut assembly). Yesterday, dealership estimated it could be a simple sway bar endlink issue. Just a $50 replacement. Any thoughts on this?
2014 F06 M6 (oil rig fire)
2012 E70 X5 diesel (oil burner)
2008 E90 M3 (oil distillates guzzler- Retired)
2013 bicycle (oily chain)
Old 06-01-2019, 10:03 AM
Bump for any thoughts on the suspension clunk:
- only on slow speed bumps or potholes
- if wheel at full lock or half lock, no noise over similar bumps
- nothing at highway speeds
Sounds like an endlink issue, considering the strut assembly (with strut tower bushing "donut" replaces) and trust bearing bushings replaced already. Here's a picture of the X5 with the M
Old 06-01-2019, 10:10 AM
ArgentoCarNut ArgentoCarNut is offline
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
Have you done the strut top bushings?
Sent from my iPhone using Tapatalk
Old 06-01-2019, 10:12 AM
The donut? Yes, along with the strut itself. See pics below. This was the parts list of the replacement
ID:	853605   Click image for larger version
ID:	853607   Click image for larger version
Old 06-01-2019, 12:54 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
I recently found a clunk in my steering that I thought I fixed by doing drivers tie rod inner and outer. Turns out a lot of bmw get slop in the rack, including the newer f cars.
Engine off, wobble the steering wheel and listen if it's clunking. Have someone wobble the wheel and listen to see if its coming from the area of the driver's side inner tie rod balljoint. If so, this may help.
The adjustment is a bit annoying... see image. Only do this if you are comfortable and it's not easily accessible without tweaking around. There's a spring inside that tensions this U shaped piece that presses the rack into the gear where the steering wheel shaft connects to.
Old 06-02-2019, 09:36 PM
ChrisM011 ChrisM011 is offline
Mein Auto: e70 X5d, e36 M3
Thanks for the update!
As for the parking brake switch: if you are referring to the actual lever inside the car that is used to set the brake and release it, then you simply remove and replace - no need for coding/registration to my knowledge.
Old 06-02-2019, 10:01 PM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
A couple of years ago the parking brake in my 2012 X5 35d became a parking break when the switch handle broke. I was still able to operate the switch using a screwdriver stuck down into the switch assembly. A replacement switch assembly wasn't expensive from what I recall and didn't require any coding.
Sent from my XP8800 using Tapatalk
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 06-03-2019, 12:38 AM
deroy deroy is offline
Mein Auto: X5 e70 4.8
What is "wobble" for you? I have a click when I quite swiftly move my steering wheel back and forth while parked (engine off) by 1/2 inch, no more. But no sounds when I slowly move the steering wheel. Also, the front wheels always follow the steering wheel, i.e. there is zero play.
Would my click qualify for this treatment you think?
Also; did nut require a lot of torque?
Old 06-03-2019, 03:05 AM
Yeah I was hearing knock from small movements and couldn't see play.
I had a random clunk feel sometimes when braking at slow speed, and I did the drivers side tie rod +ends already so I figured to try this since friend with e60 m5 had this issue and fixed it that way.
Not a lot of torque. I felt it get tight fast and then went back loose about 20 degrees.
If you don't have the clunk in braking, don't bother with this but it's good to know in case it starts.
Old 06-03-2019, 03:58 AM
No not while braking, just low speed, swift, short not too severe bumps that cause a soft cluncking. As if a suspension component does not keep up with the swift but mild up and down movement that is required. Longer wavelength bumps etc are all fine. High speed is fine too.
Old 06-03-2019, 05:19 AM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
sounds like control arms.... I had a light click when coming out of the driveway and turning left, wound up replaceing control arms and engine mounts...and 1 sway bar end link.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 06-03-2019, 06:55 AM
Theoretically, the control arm bushings do not do much with just vertical wheel movements. Mine seem good. In your case, when turning, they take a lot of load pushing/pulling the car round the corner. The ball joints take some vertical movement, but mine are tight. Sway bar end links would be prime first suspect, but mine are tight too. My strut mount bushings seem fine to they eye, they have not disintegrated like reported by others.
Verzonden vanaf mijn iPhone met Tapatalk
Old 06-03-2019, 07:43 AM
hsindogg's Avatar
hsindogg hsindogg is offline
Mein Auto: 2011 X5 35d | 2020 530xe
Here's a DIY $2 fix for the parking brake lever: https://www.bimmerfest.com/forums/sh...d.php?t=977191
If you do buy the replacement module, there's zero coding involved. It's just a remove and plug and play.
I have the Nittos as well, I'm probably around 35K on them, I'll probably get another set.
Sparkling Bronze 2011 X5 xDrive35d
Old 07-21-2019, 09:11 PM
As an update, I changed the endlinks and it resolved the clunk. I am loving the car all over again.... until it started leaking again.
Old 07-21-2019, 09:36 PM
ard ard is offline
Resident Curmudgeon
thanks for closing the loop!
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-22-2019, 01:01 PM
X5-User X5-User is offline
Mein Auto:
again? so do you mean you had a previous leak that you got it fixed then started again?
Old 07-22-2019, 01:16 PM
sunny_j's Avatar
sunny_j sunny_j is offline
bmw addiction
Mein Auto: X5d
^^ I'd like to know that as well
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Log
https://www.bimmerfest.com/forums/sh....php?t=1290337
Old 07-29-2019, 12:10 PM
as if today, I haven't diagnosed the leak yet. It's not a heavy leak. I calculated I lost about a half bottle of oil over the course of 3 months.
I'll look into it in a few weeks. My local BMW dealership is now offering a "free" inspection everytime I go in for service/repair and they also have a "free" coupon to redeem for this service. I'm hoping they're willing to do a minor visual diagnostic to pinpoint where the leak is coming from and provide an estimate. We'll see if they'll do all this without collecting the diagnostic fee.
Old 07-29-2019, 12:16 PM
hey, if you have time, can you send me the part number you purchased for the replacement?
On realOEM, I'm seeing that i have the buy then entire module and I cannot simply buy the switch.
Old 07-29-2019, 12:27 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
61 31 9 148 508. Switch EMF Price:$73.75
https://www.newtis.info/tisv2/a/en/e...sensor/OReE9hl
Old 07-29-2019, 12:32 PM
Thanks Doug! This procedure was going to be my next search on these forums! This broken switch have been bothering me a lot recently.
Old 07-29-2019, 02:36 PM
Nonsuch Nonsuch is online now
Mein Auto: M6
...This broken switch have been bothering me a lot recently.
You might try to repair the switch, mine works better than new (less play)
Old 07-29-2019, 08:59 PM
Ok thanks, I'll give a try. It's hard to visualize how the screws are going to hold a broken switch in place. Maybe after I take it out, it'll be easier to figure out
Old 07-29-2019, 11:22 PM
sunny_j's Avatar
bmw addiction
Mein Auto: X5d
Which side are you noticing the leak? If it's on the passenger side, it can be from one of the turbo oil lines/oil return lines. Another leak can happen from a ceased valve cover gasket. Do you have any boost leaks? Look at the orange boost hose for any leaks which can cause oil to leak out
Build Log
Old 12-02-2019, 12:40 PM
An update on my ownership. I'm now at 90k miles, exactly. I've fixed the oil leak from the car. Details here: https://www.bimmerfest.com/forums/sh....php?t=1346243
Last week, I performed another two sets of repair on the car:
1. My parking brake malfunctioned. The replacement part is close to $1000, labor was a reasonable $150.
2. I had a boost/vacuum issue. Code P0299. I decided to take this one to an indy. It was diagnosed as a deteriorating vacuum line. Replaced the lines as well as the some type of "box". I'll update this post with the p/n of that box. It wasn't the MAF or diverter/re-circulation valve based on my knowledge of what those parts looked like. I've been so busy that I haven't gotten around to updating my records yet. Total parts cost of less than $100. But labor was a painful $400 due to diagnostics time.
The indy pulled stored codes related to the DEF tanks. This is related to the codes I've mentioned earlier on this thread. I'll have to check the thermostat operations first before I decide what to do.
Lastly, my car continues to chew through brakes. I am now fully on board with the FCP Euro process. I'll need a new set of rear pads and rotors next month. Hopefully, I won't sell the car until at least one more set of brake change and I'll be able to recoup some of this cost through FCP's return policy.
You pay to play!
