Parking Brake Malfunction - manual release issue - Bimmerfest - BMW Forums
Old 10-17-2019, 10:53 AM
Flying Ace Flying Ace is offline
Mein Auto: M6 GC ZCP; '12 X5 Diesel
This morning, I received the dreaded parking brake malfunction error. I realize I have a long road of diagnostics coming up regarding actually fixing the issue (actuator, cables, electronics, etc), but for the time being I just need to release the brake engagement so I can drive the car.
I read the manual and viewed the youtube videos and I still cannot manually disengage it. The release in the trunk is a steel metal loop, not a "nut" that the videos show. I pulled the wire upwards to the resistance point, and pulled it a bit more and heard a small pop. I tried the push the button down, then push the button up reset sequence, but it still won't disengage.
Any suggestions? I did the reset while the ignition was on and with a firm foot on the brake.
2014 F06 M6 (oil rig fire)
2012 E70 X5 diesel (oil burner)
2008 E90 M3 (oil distillates guzzler- Retired)
2013 bicycle (oily chain)
Old 10-17-2019, 02:28 PM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Pull harder.
Verzonden vanaf mijn iPhone met Tapatalk
Old 10-17-2019, 02:41 PM
kankou kankou is offline
Mein Auto: 2012 X5 35d
+1, I agree, pull up harder. When my parking brake broke, I remember having troubling releasing via the loop. I ended up putting a small tool into the loop to get more leverage to release. It was a pretty solid pop/release noise once it disengaged.
I was not in a position to DIY the fix, so took it to my Indy for a replacement. Cost a pretty penny.
Old 10-17-2019, 02:58 PM
thanks! what was the ultimate issue for you? Actuator?
Old 10-17-2019, 03:03 PM
Doug Huffman's Avatar
Nuclear engineer
The EMF actuator uses a ‘nylon’ pinion gear much like the VTG TC actuator and it wears similarly.
Milady Wife sets the EMF parking brake every time she parks in our garage.
Old 10-17-2019, 03:25 PM
the actuator was unresponsive via tool. the unit was replaced and coding done.
Old 10-17-2019, 03:45 PM
I'm trying to pull the loop now, and it's very difficult past the resistance point. I'm using a screwdriver and it's getting to the point where I might bend the shaft of the screwdriver.
Keep pulling?
Old 10-17-2019, 05:11 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Lesson learned, don't use the parking brake cause it's a crap design. It should be recalled lol
I had an error a month ago, one of the leads to the motor broke inside. Even though I don't use it, the modules check for continuity.
Soldered on a wire and reconnected it, making sure to hot glue the wires so they don't vibrate and wiggle which breaks it off the motor.
I did it from under the car as I did not want to have to disconnect the cables from the parking brake drums.
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
Old 10-17-2019, 05:21 PM
Good news: I think I was able to release the brake. I didn't hear a pop, but i am able to move the car with no noticeable resistance or noise indicating the ebrake is likely no longer engaged. This morning, it was obvious that the brake was engaged, I would push lightly on the gas pedal and the car would have major resistance.
Bad news: that park light is still on with the malfunction message. It gives me pause that perhaps I haven't fully released the brake. I tried the reset process both by pushing the button down and pulling it up for few seconds and pulling the fuse, but the light is still on and won't reset.
Have I truly disengaged the brake? Any other way to check without damaging the brake?
The car currently is parked on a slight hill. So when I put it in P, and shut down, the car inches forward and gets caught in gear, similar to if you put the transmission in P and didn't engage the parking brake.
Old 10-17-2019, 05:35 PM
Also in neutral the car rolls with no resistance forwards or backwards. I think I'm good?
Old 10-17-2019, 10:37 PM
Masoe Masoe is offline
Mein Auto: 2012 750Li/2008 X5 4.8
You should be good. I had mine replaced last week at my Indy. He had to order the part but told me it was fine to drive with the malfunction light on. I drove it for 2 weeks without issues. It's funny, we have probably used the parking brake 6 times in all the years we had the vehicle in/around San Francisco, but the second we used it in our drive way it broke.
PS, the "Pucker Gong" is annoying when you first get in the vehicle but it stops within a few seconds...also, once we got the vehicle's Park Brake released, the "park" brake indicator changed from RED to Yellow on the dash...jfyi.
2012 750Li, Carbon Black Metallic/Oyster&Black, M Sport (Current)
2008 X5 4.8 (Sport), Platinum Bronze Metallic/Tobacco&Black (Current)
2006 750i, Sapphire Black Metallic/Black
2002 745i, Sapphire Black Metallic/Beige
2002 530i (5 speed), Sapphire Black Metallic/Black
Old 10-18-2019, 06:29 AM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
Non-use of the parking brake is what leads to problems with the parking brake the first time it gets used.
I ALWAYS set the parking brake when my cars are parked. Absolutely no exceptions. Never had a problem in more than 40 years of driving. Regular use prevents problems with the parking brake system. My 2012 X5 35d at only 228k miles still has the original parking brake system. The only thing that has been replaced is the parking brake switch after the plastic button broke from my pulling it much harder than necessary.
Sent from my XP8800 using Tapatalk
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 10-18-2019, 08:05 AM
Thanks. So what parts did you end up changing?
Old 10-18-2019, 08:54 AM
Nuclear engineer
Good to know. That eases my mind a bit.
Old 10-18-2019, 01:46 PM
twh twh is offline
Mein Auto: '06 530xi 6sp
non-use of the parking brake is what leads to problems with the parking brake the first time it gets used.
I always set the parking brake when my cars are parked. Absolutely no exceptions. Never had a problem in more than 40 years of driving. Regular use prevents problems with the parking brake system. My 2012 x5 35d at only 228k miles still has the original parking brake system. The only thing that has been replaced is the parking brake switch after the plastic button broke from my pulling it much harder than necessary.
Sent from my xp8800 using tapatalk
+1
Old 10-18-2019, 01:52 PM
I don't like the parking brake system but use it once a month just to exercise it.
The annoying thing is when you are on a hill, set parking brake and put trans in P.
Here's the face palm, it'll momentarily let go of parking brake so it sits on the P pawl in the transmission and re engage it, defeating the purpose of why I wanted to use the freaking parking brake! (To not have the gravity pushing on the pawl in the first place argh!)
Wait until the wire breaks off the motor inside the module and you'll see how mechanically it's great but electrically a piece of crap.
Old 10-18-2019, 02:57 PM
I chose to replace with a Re-Built actuator.
Old 10-20-2019, 05:16 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
How do you not set the parking brake since the E70 does it automatically when you stop
http://www.wardphotography.com/sig10.jpg
| '09 X5 35D - Work horse (Sold) | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily | '17 X5 35D - current work horse |
Old 10-20-2019, 05:36 AM
Nuclear engineer
There are three functions at play. Transmission Park 'lock' is set on engine off. Auto Hold / Anti-roll Back is hydraulic DSC while the engine is running. Parking 'Emergency Brake' Electro Magnitic Force - EMF - is manual. Auto Hold may engage EMF automatically at engine off but I have not tried it.
Old 10-20-2019, 07:03 AM
twh twh is offline
Good point...when you put the car in P and turn off the car, the parking brake automatically engages on my 2009 X5.
Old 10-20-2019, 07:46 AM
This
Old 10-22-2019, 05:26 PM
Falkon Falkon is offline
Mein Auto: 2008 BMW X5 3.0si
... . Auto Hold may engage EMF automatically at engine off but I have not tried it.
Yes it does indeed. The following actions causes the Auto-Hold (Green Park Lighting) to automatically turn on the Parking Brake (Red Park Lighting). If you:
1. switch the Bimmer off
2. get off your seat, even a little bit, while the engine is running
Old 10-22-2019, 05:31 PM
The Parking Brake does not engage automatically when the Bimmer is switched off unless you had previously had it on Auto-Hold function.
You may probably be referring to the Transmission Park, which if the engine is running, you could select by pressing the little button on the Gearshift Selector.
The Parking Brake Switch is totally different, it's the big Black Button on the Console that you Press down or Pull up to disengage or engage the Parking/ Emergency brake respectively.
Old 10-22-2019, 05:36 PM
I imagine you are referring to the Transmission PARK not the Parking Brake.
Old 10-22-2019, 06:00 PM
twh twh is offline
I never use auto-hold. I never set the parking brake when turning off the car. Every time I get into the car and start it, I have to release the parking brake.
