E65/E66 22" avarus av1 staggered deep lip wheels w/pirelli tires bmw 7 series e65/e66 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Wheels and Tires
Wheels and Tires
Wheels, tires, spacers etc....
Old 02-23-2013, 11:59 AM
stretch1100 stretch1100 is offline
Mein Auto: 2011 Alpina B7
$2,100 OBO
THIS IS A USED SET OF AVARUS AV1 WHEELS BY ASANTI IN SILVER WITH A CHROME STAINLESS STEEL LIP OFF OF MY 2002 745I E65. IT IS A STAGGERED SET OF 22X8.5 AND 22X10.0. THEY HAVE THE VERY DESIRED DEEP LIP ON THE REAR WHEELS. THEY ARE SET UP TO FIT ON A SEVEN SERIES BMW. THE TIRES ARE PIRELLI PZERO NEROíS THAT WERE PURCHASED NEW LAST SUMMER ($310 EACH FOR FRONT/$359 FOR REARS, TOTAL $1338 FOR THE TIRES ALONE WITHOUT TAX, BALANCING AND INSTALLATION) THE FRONTS ARE 265-30-22 AND THE REARS ARE 295-25-22. THE TIRES ARE NOT EVEN 1 YEAR OLD YET (HAVE RECEIPTS FROM DISCOUNT TIRES) AND HAVE 9/32 TREAD LEFT (11/32 IS NEW). THE WHEELS ARE IN GREAT SHAPE WITH A VERY LIGHT AMOUNT OF CURB MARKS ON THE FRONT WHEELS (SEE PICíS ITíS HARD TO SEE AS THE STAINLESS LIP DOES A GOOD JOB OF BLENDING IN THE MARKS). THE WHEELS HAVE BEEN HIGH SPEED BALANCED AND ARE STRAIGHT AND TRUE.
THESE WILL ALSO FIT THE FOLLOWING BMW's. (SPACERS AND HUB-CENTRIC RINGS MAY BE REQUIRED):
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
ID:	363494   Click image for larger version
ID:	363495   Click image for larger version
ID:	363496   Click image for larger version
ID:	363497   Click image for larger version
22's, avarus, pirelli
