Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 17 - Bimmerfest - BMW Forums
Old 08-03-2019, 07:26 AM
Dylferguson98 Dylferguson98 is offline
Mein Auto:
Hi am looking to get the latest version of esys and launcher which currently works with token master any help would be much appreciated
Cheers
Old 08-03-2019, 06:54 PM
Almaretto's Avatar
Almaretto Almaretto is online now
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by mochoukri View Post
Hi Guys,
when i start the esys launcher pro i get the following error:
E-SYS LAUNCHER ERROR
LOADING E-SYS LAUNCHER PSDZ API MODULE FAILED!
ERROR : C:/PROGRAMDATA/TOKENMASTER/E-SYS LAUNCHER PRO/BIN/PSDZAPI.DLL : CAN'T FIND DEPENDENT LIBRARIES
Anyone knows what this means?
Thanks in advance
Try reinstalling Launcher after first deleting all traces.
Old 08-12-2019, 07:29 PM
choginwat choginwat is offline
Mein Auto: BMW E60
Hi friend,
Can you help us for some things. I found some data sheet about F10 modules So, we canít found some modules.
Example
I want to code module HU_CIC or HU_NBT I not found this but found only HU_CAMP2 and then I want to have sound(beep) when lock/unlock door I canít found F2D module too.
My car is BMW 520d LCI Y2014 with small screen.
Thank
Old 08-13-2019, 12:11 PM
bms5 bms5 is offline
Mein Auto: 335d, X5 35d
Descriptions missing for coding HKFM2
Connected with my old laptop with 3.27.1 and 4.18.22 (canít load Esys on my new laptop because of the date and Token conflict).
I was able to connect and do some FDL coding in BDC using both Cheat Codes as well as manual editing.
However, when I read coding data from HKFM2 CAFD_00005710_004_000_000 and attempt to Edit FDL, there are no descriptions showing up to know what to edit and Cheat Code section is empty. I am trying to code hatch closing with fob and inside button.
I-Step (current) is F-25-18-11-520
Any help is greatly appreciated!
Old 08-13-2019, 01:55 PM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
Cheers
the last working esys + free lauchner is esys version < 3.0 + launcher 2.8.2 - but not recommended for G-series
Old 09-20-2019, 05:53 AM
Fettler Fettler is offline
Mein Auto:
Hi Guys,
Thanks in advance
Hi, I have the same problem as Mochoukri above:
New install of E-Sys v3.27.1 build 44813 with TokenMaster's free E-Sys Launcher Pro v2.82.162.
When I run the launcher I get error message: "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries."
I'm using Windows10 Home laptop.
When I start E-Sys without using the launcher, it runs and connects to my vehicle. I have downloaded PSdZ data and put it in C:/data/PSdZdata and I have re installed E-Sys Launcher.
Did thie problem get solved? Any help would be much appreciated, thanks
Old 09-20-2019, 06:01 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by Fettler View Post
...When I start E-Sys without using the launcher, it runs and connects to my vehicle. I have downloaded PSdZ data and put it in C:/data/PSdZdata and I have re installed E-Sys Launcher.
Just to be clear, it goes in c:\data with the result being c:\data\psdzdata. It does not go in c:\data\psdzdata with result being c:\data\psdzdata\psdzdata.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-20-2019, 06:13 AM
Mein Auto:
Thanks For your reply Shawn, My path is c:\data\psdzdata and in that psdzdata folder there are 7 folders: extlibs, kiswb, mainseries, mapping, security, swe, temp and 1 file: Version
Old 09-20-2019, 08:38 AM
Then I do not know why your Launcher PRO has PSdzAPI.dll.
Is latest .NET Installed?
Old Yesterday, 09:40 AM
joopi joopi is offline
Mein Auto: F30
Hi
I have E-Sys v3.27.1. where can i download the E-Sys Launcher?
sorry for my english.
Old Yesterday, 09:48 AM
Originally Posted by joopi View Post
Hi
You can use E-Sys Launcher PRO 2.8.2 for free, at least until April 2020 when it expires:
http://tokenmaster.blogspot.com/2019...r-pro-282.html
Old Yesterday, 10:05 AM
Mein Auto: F30
Thank you
and newest psdzdata?
Old Yesterday, 10:09 AM
Thank you
What is wrong with links in first post?
Old Yesterday, 10:12 AM
Mein Auto: F30
Nothing, the first post ist the launcher and now i am asking for new psdzdata.
Old Yesterday, 10:17 AM
Go back and Read Note 2 at Top.
Old Yesterday, 10:23 AM
Mein Auto: F30
i am sorry, i didnīt see it.
thank you
Old Yesterday, 10:24 AM
thank you
