airbag malfunction kight - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-08-2019, 08:41 PM
kenmar kenmar is offline
Mein Auto: X5
airbag malfunction light but scanner reads no faults in any airbag systems. I do have a multifunction steering wheel fault and no cruise control no horn no radio also the MID panel is dead but no faults on scanner for it. ????
Old 07-13-2019, 11:48 AM
Mein Auto: X5
replaced clockspring with no change. I get a DME fault immediately. It is identified as 2d multifunction steering wheel control module interface. Can I program the new clockspring with a foxwell NT510 scanner? does anyone know the procedure?
Old 07-13-2019, 01:16 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
No programming required for clockspring.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
2013 X5 xDrive35i
Old 07-13-2019, 05:51 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Don't see what I'm about to suggest often on the e53...but you've described many of the symptoms of a failing ignition switch.
This is a oft discussed topic...so a simple google search (BMW failing ignition switch) should pull up past threads and videos that show this seemingly unrelated symptoms that all correct themselves after the ignition switch is changed (or cleaned).
There is a test that you can do that sometimes can get many of the symptoms to replicate themselves:
  1. Start the engine, turn on the radio
  2. Reach up and pull down the passenger sun visor
  3. Open the mirror cover on the visor's mirror
If the radio turns off (or turns itself on)...or if the horn works or stops working, and look for other electrical gremlins that change when you open/close the mirror cover on the sun visor. Again, if you do a youtube video search...you can find past videos that show some of the weird electrical gremlins that occur.
Again, this is just a suggestion..it may or may not be your actual problem.
Good luck.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 07-16-2019, 06:14 AM
QSilver7's Avatar
I don't know if the OP finally resolved his issue...but in regards to the ignition switch being the culprit...here's a thread from Xoupost (7/14/19) where it (the ignition switch) was the culprit and cleaning it (versus replacing it) fixed the issue: https://xoutpost.com/bmw-sav-forums/...ng-solved.html
(SOLD)
Old 08-19-2019, 02:17 PM
Mein Auto: X5
After several weeks of testing and reading every post I could find related to a trans failsafe error and the associated errors I have seen with it we came down to this. after replacing the clockspring without any change I stepped out and tried replacing the ignition switch. All symptoms disappeared and the steering column switches are all working. No more errors showing and all working well. Thanks to everyone for suggestions and ideas. I have learned a ton about the BMW brand.
