04 X5 "check side lights" warning - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 12-11-2011, 04:19 AM
Rogerrpb Rogerrpb is offline
Mein Auto: 03 Z4, 04 X5
getting "check side lights" warning all the time although all my side lights are working just fine. Any clues?
Roger
04 X5, 03 Z4 dinan
(rip 01 x5, 96 740 IL, 86 325 I, 83 320)
Old 12-30-2011, 02:18 PM
gerry9870 gerry9870 is offline
Mein Auto: BMW X5 V8
Roger
04 X5, 03 Z4 dinan
I took both bulbs out and cleaned the terminals with a cotton bud, the side light display message never came back on, only other thing I know of is the relay may be faulty, there is one relay the controls all the lights, but is split inside in to various cones to direct and control the power outlet to each lighting system
Cheers
Gerry
Old 01-02-2016, 10:33 AM
Fernando51454 Fernando51454 is offline
Mein Auto: 2004 X5 4.4i
Gerry, which bulbs did you clean the connectors for side lights or angel eye lights?
Old 01-02-2016, 02:15 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
AE lights...are side lights. The AEs come on when the light switch is turned from the off position to the 1st position to the right...thus if you have an AE burnt out you will get the side light out message.
Only mentioning this due to many past posts that say all side lights were checked...without specifically identifying the AEs, too.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 01-02-2016, 10:40 PM
torontox5 torontox5 is offline
Mein Auto: 20005 BMW X5
Hello QSilver. Got a high regard for your knowledge and for your input. What is AE?
Old 01-03-2016, 07:38 AM
QSilver7's Avatar
My use of AE = angel eyes.
Name:	E53 x5 swapped angel eyes.jpg
(SOLD)
Old 01-03-2016, 11:10 AM
Thanks for the pic. I did a total walk around in every light position including hazards and all my lights work fine but continue to get the message. So I assume it's a bad sensor but don't know which socket to Clean?
Old 01-03-2016, 03:56 PM
QSilver7's Avatar
It may not be over yet with checking the bulbs. I've been lucky so far and haven't had to do anything with my turn indicators...and these bi-xenon adaptive headlight assemblies on the facelift e53 are a lot different than the regular halogen & xenon lights on my other BMWs.
The LCM III (which we have) has a replacement light feature...which means that on the front and rear...if a bulb burns out...it can substitute another bulb by limiting voltage...or using the other filament in a dual filament bulb.
If this is the case...you may be looking at a bulb from outside of the vehicle...and it looks like the turn park lamps are okay when actually...the LCM may be turning on the turn indicator bulb (filament) and reducing its voltage so that it doesn't shine bright like the turn indicator. With these vehicles...you can't just look at the bulb from outside...you need to physically check each bulb...or do a test that will make a bulb that is been pressed into double duty...go crazy.
For instance...if a front park lamp is burnt out and the turn indicator is pressed into service...turn on the parking lights/headlights (which will get them to turn on)...but if you turn on the hazards or the turn indicators at the same time...the LCM can only illuminate one of those features...either the park light will go off or the bulb will blink for the hazards or turn indicator...it can't do both if one of the dual filaments is burnt out.
Again...you need to physically check the bulbs...not just look at them from the outside of the vehicle.
(SOLD)
Old 01-03-2016, 04:34 PM
Thanks for the insight. Sound like a lot of trickery going on to keep bad lights seem like they are working. By doing it in the dark, can you tell which light is the culprit by the amount of illumination. Meaning, the light that's kicking in for the failed one looks dimmer?
Old 01-04-2016, 02:31 PM
QSilver7's Avatar
The only way I know is to physically look at the bulb when its a dual filament. You can visually see that a filament is burnt or detached.
BTW, I jinxed myself last night. On the way home my CHECK SIDE LIGHTS warning came on. Got home and I have a burnt out AE.
(SOLD)
Old 01-04-2016, 02:54 PM
Lol! At least you know which light it is. I have to start pulling bulbs!
Old 01-09-2016, 02:04 PM
Amazered Amazered is offline
superfire
Mein Auto: 2005 x5 4.4l
OMG THANK GOD FOR YOU GUYS IN THE FORM POINT BLANK PERIOD.. LORD KNOWS I CATCH A TOUGH ONE BEING A GIRL WHO'S 2ND FAVORITE THING IS AUTO-MECHANICS, KIDS ALWAYS COME FIRST... SO IMAGE ASKING A PROFESSIONAL AT BIMMER.BREAKYOURWALLET.COM "LOL" A SERIOUS QUESTION REGARDING THE INTAKE MANIFOLD DESIGN Demotions AND WHAT WOULD BEST INCREASE OPTIMAL VALVE TIMING, DISTANCE, Ratio's, SHAPE, optimal casting MATERIALS AND ECT... I so am glad to hear some have the same problem. You guys rock I spend hours doing testing connectors bulbs at school none of us could find the issue not even the Professor.. So you know I am so grateful to have found you thanks a milllllion times over you are bimmer knight in shining BMW armor.!!!!!!!!!!!!!
ThANKSSSSSSS Amazered
Old 03-28-2017, 01:12 AM
AK-BMW-X5 AK-BMW-X5 is offline
Mein Auto: X5
I had the "Check Side Lights" message come on my X5 the other day. Before checking the forums I looked at the "side lights" on my car (the one behind the front wheels) and sure enough they were not on. After spending hours trying to get them to light up I searched the forums and read where "side lights" according to BMW are Angel Eye lights. Go figure. I looked at mine and sure enough one was not working. I switched bulbs and they both started working again and the message went away. Still puzzled why the lights on the side of my car (behind the front wheels) were not on, it dawned on me to try the turn signal and sure enough they flash to the beat of the turn signal. How frustrating but thanks to the internet for helping me track down the issue.
Old 08-22-2019, 09:02 AM
Meinhold Meinhold is offline
Mein Auto: 2004 X5 4.4 and 2006 750L
I was having the same issue and was sure what it was and I found this post and sure enough the angle eye light was out. Thanks
