F07 open big hatch with interieur hatch button on the floor panel - Bimmerfest - BMW Forums
Old 10-23-2012, 01:34 PM
cuorealfa1's Avatar
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5erGT 535d/Mini F57 JCW
Hello
ello888 was asking some time ago for the correct coding for F07 to set the interieur hatch button to open and close the big hatch.
https://www.bimmerfest.com/forums/sho...640219&page=52
if found the correct coding settings so that the functionality would be:
hatch button floor panel: open and closes the BIG hatch
fob button 3: opens the small hatch (long press)
fob button 4: opens and closes the BIG hatch (long press)
CAS -- 3002 CLM -- REMOTE_KEY_SPECIAL_FCT -- aktiv/Werte=01
CAS -- 3002 CLM -- REAR_SCREEN_IS_PRIMARY -- aktiv/Werte=01
CAS -- 3002 CLM -- OPEN_RSCR_WITH_REMOTE_KEY_SPFN -- nicht_aktiv/Werte=00
CAS -- 3002 CLM -- OPEN_RSCR_WITH_PUBU_A_PILLAR - aktiv/Werte=01 change to "nicht_aktiv/Werte=00"
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_FBD -- aktiv/Werte=01
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_TOEHKI -- nicht_aktiv/Werte=00 change to "aktiv/Werte=01"
HKL or HKFM -- 3010_HKLBEDIENUNG -- TASTER_FBD --nicht_aktiv/Werte=00
HKL or HKFM -- 3010_HKLBEDIENUNG -- USE_FBD4 -- aktiv/Werte=01
cheers
2011-?, BMW F07 2010 /// Retrofits: 6VC, 2VB, 323, 5AC, 5AD, 5AG, 5DL, LCI M5/6 Sports Steering Wheel, M-Package
2017-May 2018, Mini Cooper S F57 2017 /// Retrofits: none ;-)
May 2018- ?, Mini Cooper JCW F57 LCI
Old 10-24-2012, 02:24 AM
ello888 ello888 is offline
Mein Auto: BMW
Wow, thanks!
I think I got used to the 3rd and 4th button on the remote switched by now.
But having this is good and I might set it back correctly.
Old 09-07-2019, 03:28 AM
BimmerCraz BimmerCraz is offline
Mein Auto:
Hi,
i coded my F07 (HKL) to open & close with key fob und driver door button.
Since then, the trunk doesn't open and close at all.
Can somebody help me out?
