F45/F46/F48/F55/F56 Coding Thread - Page 14 - Bimmerfest - BMW Forums
Old 06-17-2019, 01:29 PM
cucca76 cucca76 is offline
Mein Auto: bmw x3 f25
Originally Posted by ak0707 View Post
Hi cucca76
If you are installed steering wheel Control Unit with Vibration Actuator Motor then code: LIN_VARIANTE_LRE > lre_tlc LRE_VERBAUT > aktiv
Did you installed Control Uni for vibration motor only or with heated ?
HELLO AK0707
I only installed the vibration, and the two codes configured it but it always gives me the error.
the module code is the following 9218381-02
I tried various encodings but nothing, I checked power supply and it's ok the only thing that comes to mind is that the module doesn't work. or are there other encodings to do? I connected the module to the lin11 as described in the tis.
Old 06-17-2019, 01:32 PM
rhiza888 rhiza888 is offline
Mein Auto:
Hello, Need help to fix my Problem.
Sport+ is activated and Works, but no signal in cluster/kombi, when Activated.
I tried to FDL Code the Kombi like: FDS_Menue_Text/Signal1-4 to Menue_3
My Problem is, if i try to Code, there is no Option Menue_3. I only can change to Menue_10.
The Button ***8222; Werte" one line down Could be changed to everything i want. But i dont know the number of werte.
Is there a way to fix my Problem?
HERE is a photo of my car shown in esys:
Old 06-17-2019, 02:58 PM
ak0707 ak0707 is offline
Mein Auto:
I had same issue when I aktiv Sent_msg_345 in Kafas2 so don't need to aktiv this entry instead of that Try this
In Kafas2 SEND_MSG_A18 > aktiv
In BDC_BODY ComAdapterPdu_18A_Steurung_Vibration_Lenkrad > aktiv
If you have ICM module then code
Vibration_Lenkrad > Aktiv
Old 06-17-2019, 03:18 PM
Mein Auto:
Try this
in NBT
eff_dyn_sport_cid
eff_dyn_sport_unit
hud_sportanzeige_enable
hud_sportanzeige_fes_enable
hud_sportanzeige_ms_gasse_enable
In Kombi
hud_pia_m_sport
ki_pia_m_sport_digi_tacho
spa_sport_enale
I think these entires related to HUD and Kombi display
Old 06-17-2019, 03:20 PM
Mein Auto:
HELLO AK0707
I tried various encodings but nothing, I checked power supply and it's ok the only thing that comes to mind is that the module doesn't work. or are there other encodings to do? I connected the module to the lin11 as described in the tis.[/QUOTE]
[QUOTE=ak0707;13030135]
Hello cucca76
If you have ICM module then code Vibration_Lenkrad > Aktiv
Old 07-05-2019, 10:20 AM
Mein Auto:
Looking / Searching for Can-High and Can-Low Signal for Can-Bus controlled Valve Exhaust.
Hello,
i want to install a ***8222;HG-Motorsport Ego-X" Valve Controlled Exhaust.
To install the Controller i Need to know, where i can find the Can-High and Can-Low Signal in BDC??
I Need to know Pins and Cable-Colors.
Anyone know the answer?
Old 08-16-2019, 01:23 AM
funkier funkier is offline
Mein Auto: F30 N13
Hello,
Has anyone succeeded on the activation of camera based active cruise control?
Mein Auto: F30 N13
Hello,
Old 09-11-2019, 02:31 PM
Damienf45 Damienf45 is offline
Mein Auto: 220d active tourer f45
Hello Shawn, or anyone who can help
I have an F45 with active guard and I want to activate SLI. Can you help regarding fsc code? Thanks in advance.
Old 09-11-2019, 02:33 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
