F15! Can not read BDC_BODY data - Bimmerfest - BMW Forums
Old 01-11-2014, 12:21 AM
magicyuan magicyuan is offline
Mein Auto: 3 series
Hit"Reading code" , All ecus going fine except BDC_BODY
Errors below:
Transaktions-Report: Aktion: Codierdaten lesen
cafd_000017be-005_016_107 Fehler:
CPS read from ECU "ECUId:BDC_BODY_0x40" failed! [C070]
openECUConnection for link BDC_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name BDC_BODY_40_ETHERNET doesn't map to an item [1694]
Old 01-12-2014, 12:46 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Errors below:
There is a known issue with E-Sys / PSdZData and F15's. Try "Read ECU" instead of "Read VCM" to populate SVT, and then try coding it.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 07-16-2014, 05:52 AM
evacheung evacheung is online now
Mein Auto: F07 GT
Same issue here - any resolution for this? Thanks.
Old 07-16-2014, 06:05 AM
What issue? You can't read BDC module? Did you try Read ECU instead of Read SVT? Do you have E-Sys memory set for 1024 Mb?
Old 07-16-2014, 09:35 AM
Mein Auto: F07 GT
Read ECU lists all the ECUs but when I go to read individual CAFD_ under BDC_BODY to make changes, I get "BDC_BODY_40_ETHERNET doesn't map to an item" error. Memory is set to 1024. Using 52.5 PSDZData.
Old 07-16-2014, 09:46 AM
Try 53.0 PSdzData.
Old 07-18-2014, 03:40 PM
NPickles NPickles is offline
Mein Auto: RX450h, F15 on order
Did Shawn's suggestion work?
If not are you using the F025 connection target?
Old 07-20-2014, 09:22 AM
Mein Auto: F07 GT
Try 53.0 PSdzData.
Tried 53.0 and same error. Tried F025 target and still have the same problem.
Old 07-20-2014, 10:13 AM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
It does sound like PSdZ mapping error.
If you like, you can send your SVT and log file to me and I can try and look at it tonight: fxxtokenmaster[at]Gmail
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 07-20-2014, 10:53 AM
If it is a PSdZ mapping error, this usually only happens with FrankenPSdZdata, where new PSdZData version folder was copied on top of older version, rather then deleting and replacing, or when an ISTA/P Jetstream update (e.g. 52.1) is incorrectly applied to its base PSdZdata (e.g. 52.0).
Old 07-21-2014, 07:57 PM
Rbats Rbats is offline
Mein Auto: 2014 bmw x5
So, was this a PSdZ mapping error? Curious as I will be coding my F15 soon. Thanks.
Old 07-22-2014, 01:07 AM
One of two causes from what I have learned.
Either two different versions of PSdZdata haven been copied, one over the other, ending up with mixed versions in a single folder structure which gives errors or if the wrong connection target is used you can get an error when trying to download certain ECU's CAFD files.
On the F15, BDC_BODY is one that only works using the F25 connection target whereas many of the ECU's can be downloaded using other targets without error. For the F15, the F25 connection target is the correct one to use.
Old 12-06-2017, 03:19 AM
Mlodeks Mlodeks is offline
Mein Auto: Bmw f25
I have same problem where I can not read BDC_BODY can someone send me newest PSdZdata please.
This is error I,m getting Hit"Reading code" , All ecus going fine except BDC_BODY
Old 12-06-2017, 03:36 AM
Bimmercoder Bimmercoder is offline
Mein Auto: BMW
Did you select F25 as target?
Old 12-06-2017, 04:06 AM
Mein Auto: Bmw f25
Yes I did.
Old 12-06-2017, 04:11 AM
Mein Auto: BMW
Yes I did.
psdzdata 63.1 Lite link sent by PM
Old 12-06-2017, 07:14 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Latest always found here. But, update only required if "not found [C012]" error.
Old 12-06-2017, 07:50 AM
"Object with name not found" and "doesn't map to an item normally means you have incorrect E-Sys Launcher Car Series or E-Sys Connection Target selected.
Old 12-27-2018, 07:56 PM
rmelugin rmelugin is offline
Mein Auto:
Sorry to bubble up an old thread, but I've burned a couple hours researching this and still having issues. I'm getting the same error;
I also have the same issue with HKFM. I'm trying to code a 2018 X5 xDrivei35 (F15). I was able to successfully code HU_NBT already on this vehicle, but that's it. I previously coded my F10 (2015 535i) without issue also. I've set the Launcher PRO to include F025 (and tried various other combinations as well). I've messed with the RAM settings. I can't get past this error. Any suggestions? What additional information is needed?
I'm using:
- v.63.3_PSdZData_Full
- Latest Launcher Pro (it just updated) v.3.2.1.153
- E-Sys 3.31.0
Happy to send any logs or screenshots that would help. Thanks so much.
Old 12-27-2018, 08:24 PM
Same Error = Same Answer:
"Object with name not found" and "doesn't map to an item normally means you have incorrect E-Sys Launcher Car Series or E-Sys Connection Target selected."
Old 12-27-2018, 08:48 PM
Almaretto's Avatar
Super Moderator
https://www.bimmerfest.com/forums/sh...d.php?t=983245
NOTE: Incorrect Connection Target results in "doesn't map to an item" read errors
Old 09-11-2019, 05:07 PM
daf290 daf290 is offline
Mein Auto: 2007 650 I
I have same issue with my F15, I will check my PSDZData and try F025
Sent from my iPad using Bimmerfest
Old 12-01-2019, 09:06 AM
BMW640 BMW640 is offline
Mein Auto:
I have some issues here with my F15 tried to code the new headlight ECUs and I couldn't go past BDC-BODY as ISTA/P keep trying to program and code BDC but was getting NOTExecutable for both. however, the car is dead now nothing works at all.
ISTA/D and ISTA/P cant read Terminal 15 anymore. at some point, ISTA/P asked to replace BDC-BODY. and then tried E-sys but I was getting Gateway/ECUs are not correctly connected or not responding.
the car was working fine! do I need a new BDC-BODY now or what could be the fix?
thanks in advance.
