Fxx-/Ixx-/Gxx-series E-Sys Activate FA - Bimmerfest - BMW Forums
Old 09-20-2017, 06:05 AM
Picotrain Picotrain is offline
Mein Auto: M240i
E-Sys Activate FA
Hi all
Fairly new to installing and setting up esys!
Have installed 3.30.1 token all working.
Have installed full psdzdata from 62.3.001.
Set up symbolic link from ista-p to C:data\psdzdata
Can load esys, select f20, read FA, but when trying to activate FA I just get constant green progress bar scrolling on activating FA?
It never actually activates and I have to cntr, alt, del to shut down esys. My older setup (on different laptop partition) reads and activates in same vehicle no problem!
Any ideas guys as I have run out of ideas myself now.
Pico
Old 09-20-2017, 09:11 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Update to latest launcher (link never changes).
Old 09-20-2017, 10:09 AM
Mein Auto: M240i
Thanks , just noted change log and wish I had seen this about 4 hours ago.
Ps how quickly can we get latest psdzdata files as I note 62.4 is now current but only have links to 62.3 so can't currently update modules in fear of not being able to play with coding afterwards ?
Old 09-20-2017, 10:18 AM
Almaretto's Avatar
Super Moderator
Both lite and full for 62.4 were available at beginning of month.
Old 09-20-2017, 10:21 AM
Mein Auto: M240i
Anyone or anywhere to keep up to date links?
Old 09-20-2017, 11:59 AM
Almaretto's Avatar
Super Moderator
Try the Stickies!
Old 09-20-2017, 12:25 PM
Mein Auto: M240i
Found sticky to lite but not full, do I need to request this? Thanks in advance
Old 09-20-2017, 12:31 PM
Almaretto's Avatar
Super Moderator
Yes.
Old 09-21-2017, 04:29 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-21-2017, 04:31 AM
Mein Auto: M240i
Many thanks
Old 09-09-2019, 09:59 AM
Vitalijs_A Vitalijs_A is offline
Mein Auto:
Good day,
Sorry to resurrect an old thread but have the same thing as op.
I am using Windows 10 on mac through boot camp, Psdzdata 4.19.13 lite form original coding post + (3.30.1 build 49938) since 3.27.1 could not start with out the error of missing psdzdat.dll missing (conflict of java) and using mighty TokenMaster launcher V2.8.2 162
Question is what possibly I can change from setup to activate FA, without getting constant green progress bar scrolling on activating FA.
I am almost there, but can't get to coding EBC in NBT on f16. I have modified an FA in car but does not allow mw to get to coding.
Thank you In advance.
Old 09-09-2019, 10:05 AM
Originally Posted by Vitalijs_A View Post
Good day,
I don't see where OP is using a Mac...
With E-Sys Direct, no Launcher, can you activate FA?
Old 09-09-2019, 10:52 AM
Mein Auto:
Have not tried that... will do and report.
Old 09-09-2019, 11:04 AM
Mein Auto:
Good day,
Affirmative can activate , but can't further read svt, I guess puncher is not working correctly ?
Old 09-09-2019, 01:01 PM
Mein Auto:
Is is it possible to code meaning doing the second step of:
To VO Code:
Connect => Read FA => Activate FA => Read VCM => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
without the launcher ? because all my trying's fail since mac can't do the Activation FA (VO) its in constant loop with no results.
Old 09-09-2019, 01:15 PM
To VO Code:
Yes, Launcher needed ONLY for FDL Coding, and nothing more.
Old 09-09-2019, 10:16 PM
Almaretto's Avatar
Super Moderator
On any car with BDC, you must Read ECU.
Old 09-10-2019, 01:30 AM
Mein Auto:
Thank you everyone , did it through read ECU.
This forum at least helps people, keep up the good work.
