Valve adjustment - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E30 M3 (1986-1990)
E30 M3 (1986-1990)
Old 10-05-2017, 11:33 PM
andremz10 andremz10 is offline
Mein Auto: i135
Valve adjustment
I just made a valve adjustment on my e30, when I finished I could not hear the tick tick noise on the head, but after a drive sound came back. Has someone had this issue ? If yes, please let me know how you fixed it.
Old 11-07-2017, 02:15 PM
catso's Avatar
catso catso is offline
catso
Sometimes, when the wear pattern changes after you adjust the valves the first time, you need to do it again. It's just a normal occurance with solid lifters. Make sure your oil has the correct content of ZDDP; most newer oils dont have much so it's a good idea to add some more. STP oil treatment is a good source of ZDDP, but there are also other additives and sources.
![/I][/FONT]
