1988 M3 Turns Over, But Want Start: Distributor or Fuel Pump? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E30 M3 (1986-1990)
E30 M3 (1986-1990)
Old 07-16-2018, 11:52 AM
Sircas Sircas is offline
It's the Machine in Me!
Mein Auto: 06 M6, 94 840CI & 88 M3
1988 M3 Turns Over, But Want Start: Distributor or Fuel Pump? What the best way to test?
Old 07-16-2018, 03:26 PM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
How new is the battery? Can you hear the fuel pump switch on after sitting say overnight? How long has it been since the car has ran? Distributor index wheel can be cleaned to a degree with smooth file. Have you pulled a plug and check the electrode to see if it's wet? Most non start issues are weak battery, bad ground and bad reference sender on the bell housing.
