What retracts the brake pistons? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 06-20-2019, 08:38 PM
DrivingPassion DrivingPassion is offline
Mein Auto: 2015 M235xi
When your foot is off the brakes, what retracts the pistons in disc brake system?
2018 M3 | 6MT | Competition Pkg | Executive Pkg
2015 M235i xDrive (daily commuter) | 8AT | Premium Pkg | Tech Pkg | HK Sound | Cold Weather Pkg | Driver's Assistance Pkg | MPE
2015 335xi AT (Sold) | 2009 335i 6MT (Sold) | 2006 325i my kid's car (Sold)
Old 06-21-2019, 02:32 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Nothing.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 06-21-2019, 06:09 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
To add to Doug’s elegant reply, the brake pads are in constant, but very light, contact with the brake rotors whenever the brake pedal is not depressed.
Old 06-21-2019, 07:05 AM
Wouldn't that wear out the pads?
Old 06-21-2019, 07:43 AM
Nuclear engineer
Yep, and the discs.
My BMW even has a feature that automatically tightens the brakes if I come off the throttle quickly and also periodically tightens the brakes in the wet. BMW Dynamic Stability Control uses the brakes to prevent wheel spin like a limited slip differential.
Old 06-21-2019, 07:49 AM
jaye944 jaye944 is offline
Mein Auto: BMW
Douglas,
That is the shortest reply, post I have ever seen you make.
made me laugh dude... I was expecting at least a 3 line reply,
citing various sources and some anecdote
LOL
yr da best !
Originally Posted by Doug Huffman View Post
Nothing.
Old 06-29-2019, 09:36 AM
Yep, and the discs.
Why such a design?
Are all disc brakes designed this way?
Old 06-29-2019, 10:03 AM
Nuclear engineer
The pads need to float on the discs for minimum delay when applying the brakes, to keep the discs clean (of rust, e.g.) and dry. All designed this way, without active retraction, yes. But remember that they don't touch but float, much like a hard disc RAM read-write head floats above its 10,000 RPM disc.
Old 06-29-2019, 10:18 AM
Got it. It made sense now. Thanks!
Old 06-29-2019, 10:31 AM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Just don't drive with one foot resting on the brake pedal like I've seen some people do!
Dan
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSpt AlpWhite
Old 06-30-2019, 04:51 PM
MikeNola MikeNola is offline
Mein Auto: 2017 M240i
The caliper piston is sealed to the caliper bore by a square seal set into a groove machined into the bore just below the top.
When the brakes are applied, hydraulic pressure pushes the piston out, which twists the square seal. When the brakes are released and the hydraulic pressure dissappates, the square seal returns to its "untwisted " normal shape and retracts the piston as it does.
Mike
Old 06-30-2019, 05:54 PM
Nuclear engineer
Barbara Streisand.
Old 07-30-2019, 02:15 PM
lmacmil lmacmil is offline
Mein Auto: 2006 BMW Z4 3.0si
When you apply the brakes the caliper expands slightly and when you release the caliper returns to its unpressured shape and sends the fluid back to the master cylinder. The piston seal design and the shape of the groove it sits in determine the distance between the pads and the rotors, which, as was pointed out, is pretty much nothing.
2006 3.0 Si
Old 07-30-2019, 04:11 PM
Thanks for all the clear description.
It's nothing like seeing the inside.
https://www.aa1car.com/library/brake_calipers.htm
I still cannot fully understand how the seal can retract the piston.
Old 07-30-2019, 06:03 PM
The seal is pretty stiff rubber and almost square. As the piston moves, it stretches the seal and when the pressure is released, the seal returns to its original shape.
2006 3.0 Si
Old 08-08-2019, 07:20 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Also note that the distances involved here (the amount the pads "retract"; movement of the piston seals) are on the order of a thousandth of an inch, if that. As Doug explained, the pads essentially float on the air film created by the spinning rotor and this is a Good Thing™.
Jack up a wheel and spin it by hand and you will hear the pads dragging ever-so-lightly on the rotor in the absence of that air film. The additional wear from this contact is technically non-zero but in practice, is completely negligible: with each brake application, a few additional microns of pad/rotor material are lost to this "dragging" effect until all contact is eliminated. After that there is zero wear until the brakes are next applied. So, think of it as a normal "tailing off" effect each time you touch the brakes--it's not additional wear, it's just a part of normal wear that is imperceptible.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
