Brake clicks ONCE when reversing - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 07-01-2019, 08:31 PM
DrivingPassion DrivingPassion is offline
Mein Auto: 2015 M235xi
I replaced all 4 brake pads on my 2015 M235xi and everything went well. Nothing felt changed.
Then, I replaced the front rotors. Everything is still fine.
Then, I replaced one Hub Assembly Bearing because I was troubleshooting a very soft metallic ring coming from the wheels.
Now, there is one single click from that brake when I reverse the car out and steps on the brakes. When I go fwd, there is another single click. No other sounds after the single click in one direction.
What do you think? Is this normal?
I just pulled out the pads and checked everything and reinstalled the 2 pins + anti-rattle springy clip and went for another test --- it did the same thing.
2018 M3 | 6MT | Competition Pkg | Executive Pkg
2015 M235i xDrive (daily commuter) | 8AT | Premium Pkg | Tech Pkg | HK Sound | Cold Weather Pkg | Driver's Assistance Pkg | MPE
2015 335xi AT (Sold) | 2009 335i 6MT (Sold) | 2006 325i my kid's car (Sold)
Old 07-02-2019, 06:33 PM
Anyone?
Old 07-03-2019, 07:32 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
The clock is likely caused by the pads shifting slightly in the caliper. Are the pads factory or aftermarket? I replaced the factory pads in my 2018 M240i with Performance Friction 08s and they shift very slightly when I brake. Hence the click.
Old 07-03-2019, 08:06 AM
I replaced rotors and pads with StopTech products.
Old 08-31-2019, 08:28 AM
chrisria chrisria is offline
ferraricare
Mein Auto: 2016 M235i
I believe you are right on target! Double check the pad movement.
