2005 X5 Missing Rear Brake Sensor - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 08-25-2019, 11:30 AM
ratchitjaw ratchitjaw is offline
Mein Auto:
Hello,
I purchased my X5 and the red brake light was on. Previous owner told me it was just a sensor.
I found it was missing the brake sensor on the driver side rear brake. I purchased a new sensor and when I went to put it on I found that the white harness that it connects to that is housed inside a plastic box was missing with no wires coming down from the wheelwell.
The other side has the connecter in the box with a yellow and black wire going up through the wheelwell.
Can anyone tell me where this connects and what part I would need to complete the connections ?
thanks much...
Ratchitjaw
Old 08-25-2019, 11:33 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Www.NewTIS.info. Enter with your VIN-7. Search / Browse.
Looks like only front left and rear right
https://www.newtis.info/tisv2/a/en/e...d-wear/ajGVfpa
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-25-2019, 08:37 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
05 X5. Sensors go to right rear and left front. Only. The light comes on when the circuit is broken. So if no sensor is installed, you will get a light. The sensor has a continuous circuit until it is worn through and the circuit is no longer complete.
Old 08-28-2019, 09:16 AM
Rickster X5 Rickster X5 is offline
Mein Auto: X5
Ratchitjaw,
Unfortunately sensor connections get old and brittle on these vehicles. Since I know my X5 so well, I actually just connect the wires together above the sensor and the light is gone. This DOES mean that you have to be aware of the condition of your brake pads, but since I do my own maintenance, not a bother.
Good luck.
Rickster
2003 X5 3.0
