Fxx-/Ixx-/Gxx-series F07 IHKA CAFD Missing....heated seat??? - Bimmerfest - BMW Forums
Old 09-03-2019, 12:05 PM
Dave530d Dave530d is offline
Mein Auto: BMW 530D GT
Hi all,
1st post, so please be gentle. Recently bought a 530D GT 2010 and only just noticed that the front heated seat controls don't light or seats heat. Did the usual fuse check and connector checks under the seat, eventually bought a lead and downloaded E-Sys. It appears that I'm missing the CAFD for the IHKA module. I get the error below:
Failed to get CAFs for SWE "SWFL_000003d5-005_019_001"
Could someone point me in the direction of how I locate/source the required files please?
Other than that the car is amazing, replaced the silver cabin trim with a dark wood variant......plenty of things planned for the car, but would like to sort the seats.....
Cheers
DC
Old 09-03-2019, 07:25 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
What is vehicle I-step and which Psdzdata and E-sys are you using?
Old 09-04-2019, 03:36 AM
Hi,
I'm using E-sys 3.24.1 and Psdzdata 63.3 full (but, looks like I have 3 rar files missing!!! 1, 6 and 16 of the set of 19). When I'm connected E-sys shows. the I-step target as F001-17-11-520.
I think I may need to download the full PSDZdata set again!!!
Thanks in advance for all your help.
Cheers
DC
Old 09-04-2019, 05:37 AM
weebyx weebyx is offline
Mein Auto: BMW 320d F30 2018
Originally Posted by Dave530d View Post
Hi,
Cheers
DC
You dont need Full psdz to inject CAFD.
Here is a link to the latest lite version. I think(someone correct me) that the latest psdz needs E-Sys 3.3x, and there is also a link to 3.31 E-sys.
https://www.bimmerfest.com/forums/sh...d.php?t=983244
/Weebyx
Old 09-04-2019, 12:10 PM
Ok, making a little bit of progress I think!!! Installed E-sys 3.33.4 with the PSDZdata lite and the software now shows the IHKA module with a red CAFD file CAFD_00000092_004_002_010. It also shows 2 SWFL files SWFL_000003D5_005_019_001 and _002.
I assume my next step is to try and locate the file CAFD_00000092_004_002_010 and inject it.
Old 09-04-2019, 09:29 PM
Almaretto's Avatar
Super Moderator
Hi,
Cheers
DC
Try E-sys 3.27.1 and same Psdzdata.
You do not need full to inject. But, since you have older I-Step, using newer Psdzdata can cause issues injecting.
CAFD_00000092.caf.004_002_010 is in latest. But, rather than picking latest I-Step, try one closest to actual I-Step when injecting.
Old 09-09-2019, 06:53 AM
OK, bit of an update which may help others.....while trying other ideas regarding the IHKA missing CAFD files and issues with the cars heating controls I decided to install ISTA+
After resetting the module, I have fully working heated seats, correct indications and the rear climate controls also work as they should. The CAFD also appears in the IHKA module when viewed in E Sys.
Now my next problem, when I switch the car off and return to it the fault appears to come back to it defaults back to no heated seats and the rear controls don't work.
Early days, but this may help others.
Old 09-10-2019, 03:40 AM
tafikhulafa tafikhulafa is offline
Mein Auto: E39 530i
Have you succeeded injecting the cafd? if not i can help you send the required CAFD.
good luck
Old 09-10-2019, 11:35 AM
All sorted, new to BMW's and coding, but looks like all the errors I was getting was due to the car not having the CAFD, the solution was to connect with ISTA+, runt the car test to identify the modules and faults, clear the faults. Then exit ISTA+ and open E-Sys without turning off the car power(engine running for me as I don't have a power supply). Once I opened E-Sys it showed the correct CAFD under the IHKA module, I then did the normal module flash by right click on "IHKA" and select "CODE". This then injected the CAFD into the IHKA and all problems are now gone.
Originally when I connected with ISTA+ it would work once I reset the modules, but once I turned the car off and on again it would go back to as before i.e. no heated seats, missing CAFD and rear climate control not working.
Posted this in the 5 Series forum for others as well.
https://www.bimmerfest.com/forums/sh....php?t=1345739
