Fxx-/Ixx-/Gxx-series Idrive Buttons - Bimmerfest - BMW Forums
Old 09-05-2019, 09:57 AM
Shakall Shakall is offline
Mein Auto: Mini R56
Idrive Buttons
I have updatet my NBT 2016 to NBT Evo 2019.
Everything works good only two buttons are wrong.
How and where i can code my buttons to work properly ?
Thanks people.
Old 09-05-2019, 10:01 AM
weebyx weebyx is offline
Mein Auto: BMW 320d F30 2018
Thanks people.
In the ZBE module there is a mapping of the buttons, I have never changed it, but they are there.
I guess thats where to look. Or just buy a ZBE that matches the EVO, then you will also get the touch option I guess.
/Weebyx
Old 09-05-2019, 10:16 AM
Mein Auto: Mini R56
i dont need the Touch only chnage the buttons. Thank you i must look in the ZBE but i dont know what values i must change.
Old 09-05-2019, 10:31 AM
They have pretty meeningfull names, try to take a look and see.
Old 09-05-2019, 10:41 AM
Mein Auto: Mini R56
HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP auf aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER auf aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER auf aktiv
HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH auf aktiv
Somthing else ?
Old 09-05-2019, 11:05 AM
Somthing else ?
Yes, something else, look after something with button_1 or something like that. There should be a setting for each of the buttons.
cant remember, and do not have the CAFD for my ZBE here right now.
/Weebyx
Old 09-05-2019, 11:09 AM
Mein Auto: Mini R56
/Weebyx
hmmm i cant find it
Old 09-05-2019, 12:06 PM
dayvg dayvg is offline
Mein Auto: F10 530D MSport
The FDL you need to change is ZBE_HARDKEY_LAYOUT. Newer EVO systems have Com, Map, Nav and Media options. Change that option on the evo and youíll be all set.
2015 530D MSport
Retrofits: KAFAS2, TV Module, Paddle Shifters, Leather Sport Shifter, Rear Cam, Top View Cams, Folding Mirrors, Side View, Extra 12v sockets! (601, 6WB, 2TB, 3AC, 5DL, 430, 5DP, 5AT, 316, 5AG and ACC)
Retrofits to complete: Comfort Access
Old 09-05-2019, 12:07 PM
Mein Auto: Mini R56
Originally Posted by dayvg View Post
The FDL you need to change is ZBE_HARDKEY_LAYOUT. Newer EVO systems have Com, Map, Nav and Media options. Change that option on the evo and you'll be all set.
Yeah thank you i have set it to nicht_aktiv and its Work !
Old 09-05-2019, 12:09 PM
Good good!! I updated to Evo recently and bought an idrive controller with the new layout. I spent ages trying to get the buttons working thinking it was a CAFD/flash issue as I flashed it to latest istep, turns out it was as simple as changing that FDL
2015 530D MSport
Old 09-05-2019, 10:28 PM
Great it works
And others have learned from it
Old 09-05-2019, 10:29 PM
Why is it needed to change the FDL if you bought the controller that matches ?
/Weebyx
Old 09-05-2019, 10:44 PM
Mein Auto: Mini R56
This was my Question. I have the first Controller and they work 1a. So i dont need to buy other only set to nicht_aktiv.
Old 09-05-2019, 11:12 PM
/Weebyx
Iím guessing because I flashed the EVO and maybe used an FA from a car that had the old controller. The ZBE was from an F30.
2015 530D MSport
Old 09-06-2019, 12:07 AM
Aaah ok makes sense
