G-Series BMW X4 G02 Driving Assistant Plus + Parking Assistant Plus RETROFIT! - Bimmerfest - BMW Forums
Old 09-06-2019, 01:40 PM
Szabee_Bmw Szabee_Bmw is offline
Mein Auto: BMW 640i 2014
Hi All,
I need a little help.
I would like make some retrofit in my car. G02 2018 X4 30i xdrive.
5AT - 5DN.
Installed TRSCV module, front and side cameras, + 4 sensors with High PDC module, 2 x front side sensor with ACC sensors, the new high ABS, and the SAS module.
All module flashed and coded with esys. All module has a car VIN number already.
Only 1 problem: The SAS module I dont see in the SVT list.
If I connecting my original ICOM to the car, the SAS module show in red, after the ECU test no respond from the SAS.
The wiring connection used from TIS.
https://www.newtis.info/tisv2/a/en/g...tem/1VnbxEG1jK
Checked, all connection is ok. Interesting thing the ACC (FRR2) connecting to the BDC via the SAS module, this is GREEN, no error, but THE SAS is stay in RED color in the ISTA + .
My question: I read in some forums possible need a ZGW flexray port opening in the older models with TOOL32. Possibe in my case the problem is same? Must I opening the port?
Has anybody any infos for me? what I must do for the SAS module install?
My other problem: the car is an US version. I live in Europe, I made an VO coding for US to EU. All are ok, except the Navi. (NBT EVO id6) I can not make the VO coding on the HU_NBT. Yes , the navi broked after the VO coding, but I can solve it no problem. My problem is I can not adding the 5TA and 5DN function to my HU. any solution for this problem too ?
I have an esys 3.27.1 with original ICOM.
Thank you
Old 09-07-2019, 11:58 AM
Nobody has idea?
Has anybody a CAFD file for NBT Evo from X4 or X3 G02 or G01 with ACC and parkassist plus?
Thx a lot...
Br
Mate
Old 09-07-2019, 02:41 PM
donsr3 donsr3 is offline
Mein Auto: BMW
Hi look at this wiring diagram, i think you have to bridge FR BP2
https://www.newtis.info/tisv2/a/en/g...ler/1VnbpprRi5
Choose your SA´s and check the bridges
Then you have to init Flexray with ISTA or Tool32
Old 09-08-2019, 01:51 AM
Thx Donsr3, I made the flexray init with ista and flashing and coding with Esys, now all are WORKING!
Now all modules are ok, no error in the esys. The last step only the NBT id6 caf file.
I cant make a FA coding with esys because after the coding the HU is bricked. So I must do it manually, this is no problem only I need the CAF file from same car with parking assist plus and Driving assistant PLUS.
Possible has this file in anybody's HDD?
Old 09-09-2019, 12:59 AM
Now all are ok. NBT coded too.
So I think i retrofitted in my X4 G02 :
- Driving assistant plus
- Parking assistant plus with surrond camera.
Old 09-09-2019, 01:23 AM
weebyx weebyx is offline
Mein Auto: BMW 320d F30 2018
It would be great to know what your solution to the NBT coding issue was, just so others can learn
/Weebyx
Old 09-09-2019, 07:03 AM
X4 G02 30ix 2018
Retrofit:
5AT
5DN
All working.
ID:	863923   Click image for larger version
