F001 / F006 / F010 pls help esys coding backup - Bimmerfest - BMW Forums
Old 09-07-2019, 05:45 AM
gabytro05 gabytro05 is offline
Mein Auto: BMW F10
Hey guys,
I tried to activate BT audio on my F30. I vo coded the care from 6NF to 6NS, but not only it didn t work..now I have no BT in the meniu, nothing happnes when I press "TEL" button.
I tried to restore the back up but I donno if I did correctly. I load the file, activate FA and just clicked code.
Any ideeas?
Old 09-07-2019, 05:46 AM
dayvg dayvg is offline
Mein Auto: F10 530D MSport
Originally Posted by gabytro05 View Post
Hey guys,
Any ideeas?
Load your original FA and VO code the ECU again. Iím assuming you have a backed up original FA?
2015 530D MSport
Retrofits: KAFAS2, TV Module, Paddle Shifters, Leather Sport Shifter, Rear Cam, Top View Cams, Folding Mirrors, Side View, Extra 12v sockets! (601, 6WB, 2TB, 5DL, 430, 5DP, 5AS, in progress 316, 5AG and ACC)
Retrofits to complete: ACC, Auto trunk
Old 09-07-2019, 05:48 AM
Mein Auto: BMW F10
I did click Save and I have a file that if I load I get the FA list..hope that is the back up.
Old 09-07-2019, 05:49 AM
Mein Auto: BMW F10
I did try to restore but I donno if I did it right. I clicked LOAD - activate FA - code..
Old 09-07-2019, 05:52 AM
Mein Auto: BMW F10
oh and when I did that I got one or two errors in that list (with red) ( but I think that also happened when I first coded it!
Yeah should be. Load that then VO code the ECU again. If you havenít written the updated FA to the car (VCM) then you should be able to just read FA, check it doesnít have added/changed SALAPA code, then VO code any ECU you VO coded to enable BT.
2015 530D MSport
Old 09-07-2019, 05:54 AM
If there is any red after VO coding you have a problem. It must be green. It will usually be that you have added a SALAPA code that is not supported by hardware.
2015 530D MSport
Old 09-07-2019, 05:56 AM
Mein Auto: BMW F10
I didn t select any ecu. I just edited SALAPA CODE i modified 6NF in 6NS, saved and then I clicked code!
Old 09-07-2019, 05:57 AM
Mein Auto: BMW F10
yeah probably, but I changed it back ..from 6NS to 6NF
You need to select an ECU to code, did you attempt to code all ECUís?
2015 530D MSport
Old 09-07-2019, 05:58 AM
Mein Auto: BMW F10
I just clicked CODE (from the right part of the screen)
Old 09-07-2019, 06:01 AM
Have you followed a guide or set of instructions? It seems to me you have no idea what you are doing. https://www.dropbox.com/s/132nks5eq0...Guide.pdf?dl=0
2015 530D MSport
Old 09-07-2019, 06:02 AM
Mein Auto: BMW F10
I followed those instructions
Old 09-07-2019, 06:03 AM
Mein Auto: BMW F10
yes that s exactly what i did
Old 09-07-2019, 06:04 AM
So on the last page where it says ďWhatís nextĒ you clearly havenít followed this part.
2015 530D MSport
Old 09-07-2019, 06:06 AM
Mein Auto: BMW F10
No no I did..I remember that. I coded Hu-NBT.
Anyway..so what can I do now?
Old 09-07-2019, 06:07 AM
Ok, so that part that you followed is selecting the ECU to code, which is good. So now you must revert your FA back to how it was originally and VO code HU_NBT again. Once youíve done that report back.
2015 530D MSport
Old 09-07-2019, 06:23 AM
Mein Auto: BMW F10
pff ok, I will try that. Now I am not sure if I only coded NBT or all ecus. In the last page of those instructions it says "right click on ecu" and I now I did that to the firs "ECU" I saw..and that is the one on top. I don t think I coded that one though...but what If I did?
Do I need to reload FA and code every ecu individualy?
I know I am an idiot! (
Old 09-07-2019, 06:28 AM
So first off you need to know which ECU you coded. The first one could be ACSM which is your crash safety module. You could find yourself with issues if you need to now lock your airbag, letís hope thatís not the case. You may have VO coded ALL ecus, how long did the initial VO code take? All ECUís would be well over a minute, maybe 2-3. So, first step to be safe is to load original FA and just VO code HU_NBT. If it was me, I would VO code all ECUís, but I wouldnít have made this mistake in the first place VO code HUNBT and check if your BT is back. This is probably the most simple VO coding that most people start out with to enable EBT, but youíve made this complicated for yourself buddy.
2015 530D MSport
Old 09-07-2019, 06:35 AM
Mein Auto: BMW F10
I know I did, I was in a hurry..anyway like I told u ..idiot!
It didn t took more than when I coded HU_NBT.
But do I really need to reload that FA (backup)? I mean..I know for sure the only thing I changed is that 6NS in SALAPA..nothing else. Of that I am 100% sure
Then just VO code NBT with modified FA and see what happens.
2015 530D MSport
Old 09-07-2019, 06:38 AM
Mein Auto: BMW F10
I will try to do what u said. If it doesn t work do u think u can help me by connecting to my laptop (with team viewer)? I will pay! It is really imp to do this today. Tomorrow I have to leave the town! I would really appreciate it! (if I can t do it myself)
Old 09-07-2019, 06:39 AM
You should be fine, but I may be able to
Help later this evening. Have a go, follow the guide exactly and you will be fine.
2015 530D MSport
Mein Auto: BMW F10
oh one more thing: if IT s ok the BT should show in the meniu immediately? or should I lock the car and leave it like that for 10min?
Old 09-07-2019, 06:40 AM
It should be there as soon as the NBT is coded. You should have the BT option to connect phones etc
2015 530D MSport
