diagnosing a hard brake pedal - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 09-07-2019, 08:28 PM
primem primem is offline
Mein Auto: 2005 x5 4.4L
This might help someone with the same problem. 2006 x5 n53 4.4L
My symptom was a hard brake pedal. I would get one normal push and then a hard pedal until 5 seconds after the pedal is released. When the engine was shut off the brake pedal pushes up.
After a search I found a common issue was the mechanical vacuum pump leaking oil into the brake booster.
I removed the booster vacuum hose and it was oil free. video scope inside the booster was also oil free.
-connecting a vacuum gauge; at both pump test port and at the booster hose showed 26" of vacuum....plenty of vacuum.
I wanted to connect a vacuum gauge to the booster and see if the booster could hold a vacuum but did not have an adapter to connect the gauge to the booster.
I did have a smoke machine and pumping smoke into the booster vacuum hose port showed the booster leaking smoke.
This must be a common problem as boosters from every parts store in town and rock auto were backed ordered.
anyone have a good source for boosters...not dealer...I won't pay $1000 for a booster.
Old 09-08-2019, 09:08 AM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
FCPEuro. https://www.fcpeuro.com/products/bmw...rg-11667545384
By the way they have genuine BMW for $500.
Old 09-08-2019, 11:11 AM
thanks...I will check them out.
Old 09-17-2019, 06:29 PM
I went with the trw booster from fcpeuro. with shipping and currency exchange it will be $350.
Old 09-21-2019, 08:50 AM
AND you get a lifetime warranty with FCP.
Old 09-21-2019, 02:20 PM
Did not know that. Don't mine paying more for that. It will probably outlive the vehicle.
Only boosters available in Canada are thru the dealer.
If I lived in the states the cost would be $229 with free s&h.
Should be here next week.
Old 10-20-2019, 10:23 AM
got the booster in this weekend and all is fixed.
for anyone doing this....remove the brake fluid reservoir from the master cylinder. it slides in easy with the reservoir off.
