6WB Retrofit - Coding Required - Page 2 - Bimmerfest - BMW Forums
Old 12-05-2013, 08:13 AM
joder joder is offline
Mein Auto: '14 535i and '14 x5 35
Originally Posted by shawnsheridan View Post
It will not void warranty. It is OEM part designed for your chassis.
And you will not want to sell your 6WA. If you retrofit 6WB, you will need to swap 6WA back in for any dealer service that involves ISTA/P programming.
I retrofitted mine, and its no big deal. I can swap clusters in under 5 minutes.
Good to know - not sure if it is work $2k since I will have 6WA. If I had the standard it would be a no brainer.
The MFID is amazing...
Old 12-05-2013, 08:19 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Agreed, and I have written such.
I don't have 610 HUD, so I had only basic Kombi to start with. But, if I had 6WA to start with, I would not have retrofitted 6WB.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 12-05-2013, 11:04 AM
cuorealfa1's Avatar
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5erGT 535d/Mini F57 JCW
Shawn..
Is it just swapping the cluster and VO Coding the Kombi enough?
As i understood, the best is to use a NEW one. Due to the mileage which is already on the cluster, right?
Thx
2011-?, BMW F07 2010 /// Retrofits: 6VC, 2VB, 323, 5AC, 5AD, 5AG, 5DL, LCI M5/6 Sports Steering Wheel, M-Package
2017-May 2018, Mini Cooper S F57 2017 /// Retrofits: none ;-)
May 2018- ?, Mini Cooper JCW F57 LCI
Old 12-05-2013, 11:05 AM
Originally Posted by cuorealfa1 View Post
Shawn..
Thx
If it is new, then yes. Install Kombi, inject CAFD, and Code.
Old 12-05-2013, 11:07 AM
cuorealfa1's Avatar
and if I use a used one?
Old 12-05-2013, 11:11 AM
Then you need to first also blank VIN and Mileage in EEPROM with an EEPROM Programmer, and then Flash Kombi to write car VIN to it.
Old 12-05-2013, 11:12 AM
cuorealfa1's Avatar
do you know if a dealer is able to do it? Do the have the equipment?
thx Shawn
Old 12-05-2013, 11:16 AM
thx Shawn
No, they wont do it. Dealers will only do official BMW retrofits, and there is no official 6WB retrofit. And even if they could, they would NEVER do it with a used module.
Old 12-05-2013, 11:59 AM
From what you have seen is the mileage stored elsewhere in the car? Just curious as to what would stop folks from flashing the cluster to reset mileage. Of course it is illegal, however, I would think that there would be somewhere else more secure that this data would be stored.
Old 12-05-2013, 12:03 PM
Yes. It is stored in CAS, and whichever one, Kombi or CAS has higher mileage in it, it pushes the higher mileage to the other one.
Old 12-05-2013, 12:46 PM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
Is this also true for a retrofitted NBT, or is the cluster a special case?
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 12-05-2013, 02:01 PM
Same holds true. When they pull your factory VO from server, it isn't going to match the car's hardware, and ISTA/P is not going to like it.
Old 12-05-2013, 09:21 PM
cuorealfa1's Avatar
can i then use a cluster which has less mileage then mine, and get it flashed from my dealer with my VO? (the xml file)?
Old 12-05-2013, 09:30 PM
You should get a used cluster with less mileage if at all posssible. However, doing so doesn't change anything with the Dealer. They are not going to touch a Kombi retrofit, new or used, and if used, regardless of mileage.
Old 12-05-2013, 09:56 PM
djsaad1 djsaad1 is offline
Mein Auto: range rover
Shawn, would you know why the 6WB is showing that service is past due and needs break fluid and oil change but the 6WA isn't. The car was just in service with 6WA installed, when I got it back I put 6WB back in but now it's saying I need service again. I don't really care, but the issue is that it's sending a signal to the dealership telling them I need service.
Old 12-05-2013, 09:59 PM
The CBS records didn't update after 6WB went back in car. I am not sure why. Did you try VO Coding it again?
Old 12-05-2013, 10:04 PM
Yeah I did.
The weird thing is it was doing this before I went to service. They called me to come in because the car was telling them I needed service. I put 6wa back in brought the car to them and they were confused on why the car wasn't telling them it needed service anymore. I just played dumb.
They performed service, I got lucky and they flashed my whole car to 51.1, got the car back and just put 6WB in but it's still requesting service. I will mess with it more tomorrow. It's odd because it's saying service was due 11/2014, so there is a date off somewhere.
Old 12-05-2013, 10:08 PM
Yeah I did.
I think there is a way to sync CBS records with INPA, but I don't know it off the top of my head,
You may want to consider flashing 6WB now to 51.1 to match the car, which should also fix the issue.
Old 12-05-2013, 10:14 PM
I just vo coded it with a 11/13 fa date so that I could get the m sport edition hp reading in sport mode, and that seemed to take away the service request. I will flash kombi tomorrow though so that it's all on the same version.
Old 12-05-2013, 10:18 PM
Can you post a picture of the new hp reading?
Old 12-05-2013, 10:26 PM
My phone battery is dead. But here is a pic from another owner
http://farm4.staticflickr.com/3771/9...457cb5c0_c.jpg
Not sure why his says 480, mine says 400
Old 12-07-2013, 04:58 AM
Oh, that. I FDL Coded it when I first got my 6WB installed, but it didn't work.
If it works in 51.1, let me know.
Old 12-07-2013, 06:36 AM
GDMERC GDMERC is offline
Mein Auto: 2013 528xi
Shawn, what code was that?
Old 12-07-2013, 08:46 AM
It works for me on 51.1 but it's engine dependent. It should work with whatever engines allow you to have the power and torque meter on the idrive screen. It does show 0-480, I misread it the first time around I thought the 8 was a 0.
Old 12-07-2013, 09:39 AM
kaxasia kaxasia is offline
Mein Auto: BMW F10 550 M
Re: 6WB Retrofit - Coding Required
Hi shown. If you can't make your 6wb how we can make our kombi coding :-( which one you have problem exactly
Sent from my C6903 using BimmerApp mobile app
