6WB Retrofit - Coding Required - Page 37 - Bimmerfest - BMW Forums
Old 07-09-2019, 05:01 PM
101Motorsports 101Motorsports is offline
Mein Auto: F10
Originally Posted by shawnsheridan View Post
Can't ever be simultaneously. Always one or the other, but not both.
As stated above.
With HUD on it'll show on the HUD, with HUD off, it'll show on the cluster.
Old 07-18-2019, 08:02 AM
MikeBur MikeBur is offline
Mein Auto:
Virgin EEPROM dUMP 6wb
PM sent.
Hi Shawn, could you send me the dump too please?
Regards
Old 07-18-2019, 09:27 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Regards
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-13-2019, 10:36 AM
gnombom gnombom is offline
Mein Auto:
good day
I have 6WB, I updated the car and I can't update the instrument panel via e -sys. Machine release 03.12. dashboard release 07.16.
How to set the date in VO and i -step?
sorry for my english i am writing through google translator.
Mein Auto:
good day
How to set the date in VO and i -step? Car F10
Old 09-23-2019, 05:22 AM
MarcinSalvage MarcinSalvage is offline
Mein Auto:
Hello Shawn,
Could you please send me the dump of 6WB
Old 09-25-2019, 01:26 AM
Mein Auto:
I updated only the dashboard.
the panel is made 07.16 I tried i-step 16-07 -.....
It turned out i-step ship. dashboards 17-03-501 the time criterion also did not change for me 0312. I looked at the calculation on the HWEL dashboard as it remained black and TAL was correctly calculated.
A very long trial and error method, thanks to the forum I read a lot carefully and everything worked out. Especially a lot of things described shawnsheridan many thanks. It's just that everything is in different sections.
Mein Auto:
Old 09-25-2019, 05:14 AM
Originally Posted by MarcinSalvage View Post
Hello Shawn,
PM sent.
Old 10-29-2019, 11:46 AM
amjadbarznje amjadbarznje is offline
Mein Auto:
I finally got around to installing my 6WB MFID Instrument Cluster.
Since mine was a brand new virgin Kombi, no EEPROM work was necessary to blank the donor car's mileage and VIN. Install was a breeze, and Coding was just a matter of adding 6WB to the VO, changing VO Production date to 1211, and VO Coding DKombi and HU_CIC.
Since my car does not have ECO Pro, I get just the Comfort and Sport mode displays.
Upgrading from the basic Kombi to either 6WA or 6WB is a dramatic improvement, and worth every penny. If I already had 6WA though, I personally would stick with it rather than invest in 6WB.
Attachment 379892
Attachment 379893
Attachment 379894
Attachment 379895
Attachment 379896
hi dear
i need file 160d 35080 6wb bmw f10
Old 10-29-2019, 12:01 PM
Originally Posted by amjadbarznje View Post
hi dear
Sorry, but I do not have EEPROM Dump.
Old 12-08-2019, 02:07 PM
Walopower Walopower is offline
Mein Auto: 525iAT
Hi, about F20 basic cluster eeprom 35160 Vin change.
It's enough to change short vin "P979899" to new one?
(Rename .pdf to .bin)
Old 03-24-2020, 10:25 AM
DeltaDelta DeltaDelta is offline
Mein Auto:
Hi guys, is it possible to show the gear number in drive mode?
Old 03-31-2020, 04:24 AM
keung520 keung520 is offline
Mein Auto:
hi, I have installed a new 6wb digital cluster. How do I do the coding using E-sys? Any instructions?
Old 04-04-2020, 12:28 AM
Ricky V Ricky V is offline
Mein Auto: 325i E46
Hi, anyone can help me ?
I used esys flashed 6WB (2017 made). I cancelled flash due it take too long (flashing only in UDS mode only, not HTTP). After that i can't flash again due ESYS can't see it anymore. Cluster panel all black while plugged in power.
Maybe it dead.
How to rescue it ?
Thanks in advance.
(Sorry for my English)
Mein Auto: 325i E46
(duplicated - deleted)
Old 04-04-2020, 12:17 PM
alec01 alec01 is offline
Mein Auto: BMW G30 520d
Hi,
Check this thread:
https://www.bimmerfest.com/forums/sh....php?t=1371007
If you still can't code it, please open a new thread, explaining in details what is wrong in the process.
Old 04-11-2020, 02:57 PM
Masoud650 Masoud650 is offline
Mein Auto:
Hi there
Im from Dubai
I have a 2013 650i f06 with about 4000 km
I bought a new 6wb Cluster and coded it, the red dot is gone, and everything works, but the mileage of the car still shows 0000 !
Many thanks for your help
Old 04-13-2020, 12:49 AM
uragan1987 uragan1987 is offline
Mein Auto: X3 F25 2012 35iX
You usw a filter or Emulator at 6wb?
Old 04-13-2020, 01:13 AM
Mein Auto:
No, I didn't use a emulator or filter,
Also, CBS data are not read on 6wb!
Old 04-14-2020, 10:48 AM
Mein Auto:
Hi, I would like to remove these warnings:
do you have any idea what the functions are called?
Inviato dal mio iPhone utilizzando Tapatalk
Old 04-24-2020, 08:48 AM
Mein Auto:
2013 F06 650i
These are the steps:
Updated the car to 20-03 recently, before DKOMBI retrofit.
Installed brand new DKOMBI.
Added 6WB to the FA, didn't change build date, VO Coded all ECUs, including the CIC.
Detected and injected CAFD to DKOMBI.
Calculated update, DKOMBI didn't need further update to 20-03.
Now there are two problems:
1. Mileage shows 00000, with no red dot.
2. CBS data didn't sync to the new DKOMBI.
Old 05-22-2020, 09:50 AM
lotficrew lotficrew is offline
Mein Auto:
i have used 6WB can you help me to virginize it thank's
Old 05-22-2020, 11:35 AM
Can you read the posts, there you will get all informations
