6WB Retrofit - Coding Required - Page 5 - Bimmerfest - BMW Forums
Old 08-25-2014, 10:01 PM
BMWzone BMWzone is offline
Mein Auto: F10 530d
Originally Posted by shawnsheridan View Post
I don't see in Petrol picture where is shows 7 series F01.
So where does that leave you with this 6WB?
The Tach adjusted down properly for Diesel use I see, and I don't see the red Tamper Dot.
So all is good?
The 7 series petrol I saw it before flashing, there isn't in the picture.
Red tamper dot is here... is beside the word TIME, very small!
almost all good.
Have you a bin file of 6WB ?, I don't think missing the long VIN, but only 2 short VIN
Old 08-26-2014, 02:36 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by BMWzone View Post
...Have you a bin file of 6WB ?, I don't think missing the long VIN, but only 2 short VIN
Yes. PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 08-26-2014, 04:22 AM
Mein Auto: F10 530d
Yes. PM sent.
Ok! Seems like a great thing in your own style
-Bin files are universal for Kombi? Or they mate to specific hardware version of the Kombi?
-So even if I updated to the latest version I can reflash with Tal Processing?
I read the eprom and VINS were moved after TAL processing
I put my VIN in the original file, the Kombi has lost CAFD, he was back with petrol 07 Series F01, I put the CAFD only through TAL Processing, we couldn't through Detect CAF for SWE,
Red Dot Tamper is still there, the hidden menu of kombi detect my VIN (yesterday and today) despite moving, then CAS4 not find the second VIN
Old 08-26-2014, 04:25 AM
Not Universal per se'. It is Kombi specific 6WA, 6WB, etc., and of course 6WA for F10 is different than 6WA for F30.
Write Virgin .bin to EEPROM with Programmer, and flash like any other ECU.
Old 08-26-2014, 04:38 AM
Mein Auto: F10 530d
I meant in the family of bin 6WB all are equal even if the hardware version is different in that there are different versions gradually
Going to try
Old 08-26-2014, 04:56 AM
I do not know of any instance where a virgin .bin dump did not work in another same type Kombi.
Old 08-26-2014, 04:59 AM
Mein Auto: F10 530d
Old 08-26-2014, 07:14 AM
Mein Auto: F10 530d
TOUCH DOOOWN thank you very much Shawn
F10 530d 0911
Retrofit 223 245 248 2VB 2ND 316 337 3AH 4M5 416 ->451/488-->456 453 465 494 496 552 5AD 5AE 5AG NBT 654 FM2 610 620[CIC] 677 6NR 6WA & 6WB715 760 8TH[KAFAS2-FSC] KeyFOB Mperformance Gxx Series
Reset Kombi Gxx, Virginize VINs and Mileage
Old 08-26-2014, 07:26 AM
Old 08-26-2014, 08:18 AM
tonyscv tonyscv is offline
Mein Auto: 2014 M5
Is there updated firmware for 6WB as of yet that enables HUD turn signals? One of my fav features and to not have it is a bummer.
Old 08-26-2014, 08:46 AM
No.
Old 08-29-2014, 11:28 AM
Mein Auto: F10 530d
So all is good?
I filmed the magic moment of conversion
Old 09-27-2014, 10:03 AM
SoftBMW SoftBMW is offline
Mein Auto: F11 530d M-Sport
Can anyone send me a bin file of a 6WB (160D0WQ EEProm) ?
I have a 6WB with a EEprom that I can't read , so I need to put in a new one.
Old 09-27-2014, 12:27 PM
PM sent.
Old 09-27-2014, 01:05 PM
Thumbs up
Hi Shawn
Thanks a lot.
Can I write this file to a new EEprom, firmware update the 6WB and VO code. And then it will work ?
Old 09-27-2014, 01:07 PM
Yes, it is a virgin Dump. Write to EEPROM, flash kombo and VO Code it.
Old 09-27-2014, 09:16 PM
Arta Arta is offline
Mein Auto: F10 535i
I installed used 6wb cluster too: changed vin to my car's. So need only coding without programing.
Old 10-07-2014, 04:12 AM
1aBimmer's Avatar
1aBimmer 1aBimmer is offline
Mein Auto: 530d
Hi Gents..
I successfully retrofitted a used 6WB but noticed a small side effect ..
In the settings menu .. light and check 'Daytime driving light' .. disappeared
how do I get it back?
greetings
ID:	468564   Click image for larger version
Old 10-07-2014, 04:15 AM
Check your HU_xxx => DAYDRIVING_LIGHT coding.
Old 10-08-2014, 12:10 PM
1aBimmer's Avatar
Mein Auto: 530d
Excellent!! I changed the value to standard!
Thanks Shawn!!
Old 10-17-2014, 01:59 PM
shring shring is offline
Mein Auto: BMW
Hi
I have a F10 2011 535d FW71 with 6WA and 610.
I am not sure which part number to choose. Is 62109319002 the right one? Or 62109363263? When i search @RealOEM with my VIN there is no 6WB cluster available for my car.
Thank you for your help
Old 10-17-2014, 02:09 PM
Mein Auto: F10 530d
Originally Posted by shring View Post
Hi
You need to buy 62109319002, It's with HUD
Old 10-17-2014, 02:10 PM
diagmax diagmax is offline
Mein Auto: F10 535i US
62109319002 is correct. It has support for S610 Head-up.
Old 10-17-2014, 02:19 PM
Mein Auto: BMW
Thx.
When i search @RealOEM with my VIN there is no 6WB cluster available for my car. So the above part no is for a 2011 535d XA71. Will it work either?
Old 10-18-2014, 02:21 PM
RomeoOscar RomeoOscar is offline
Mein Auto: 2010 BMW F11 535d
I think 6WB was only available later 2011 or 2012 F10... That's why you don't have it listed on RealOEM.
10/2010 BMW F11 535d
