Fxx-/Ixx-/Gxx-series NCD / CAFD Tool v5.2 - Page 3 - Bimmerfest - BMW Forums
Old 07-14-2014, 09:09 PM
simonchs simonchs is offline
Mein Auto: BMW F20 LCI2 120i
sweet!!
Old 07-15-2014, 06:49 AM
dmtr dmtr is offline
Mein Auto: E91
Thanks for excellent job!!!
Old 07-27-2014, 08:16 AM
Bob999 Bob999 is offline
Mein Auto: X5D
TokenMaster: I just want to say thank you for creating and making available the CAFD Tool. It has helped me gain an understanding of coding and my car specifically.
I am new to this and have not found an answer to this question.
My question is about selecting the correct "Build Level" when using the tool. How does the user determine the correct build level for his/her car?
Old 07-27-2014, 08:24 AM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
If you know when your car was built (you can also use online VIN decoder), you can select a build date that is close to that.
Note on the build date: It's only used to determine available options. There are options which are available only from a certain date (6WB, ZBE3...etc). In many cases, it's not that critical. For my 2012, I usually choose November 2013 build date
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 07-27-2014, 08:25 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Read FA, and look at your Build Date, e.g. Zeitkriterium=0314 would be March 2014 Build Level.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 07-27-2014, 08:43 AM
Token Master
D'uh, I forgot about FA . This is absolutely correct
Old 07-27-2014, 08:54 AM
Old 07-27-2014, 09:08 AM
Mein Auto: X5D
Thanks to both TokenMaster and shawnsheridan!
Old 07-28-2014, 01:45 PM
Heden Heden is offline
Mein Auto: X5 F15 30d
Newbie question => Can this program be used to code different functions or is it used to see the code for different available functions which then can be used to code in PSdZData?
Old 07-28-2014, 03:05 PM
Token Master
It's the latter.
Old 07-28-2014, 03:10 PM
Token Master
BTW, if you select an option, like 84S or 5AP, and don't see any affected items, check "Include Default" and try again.
I thought I'd exclude default options but now realized that the actual value may be different. I'll remove this option in the next version and have it return default values always.
Old 07-29-2014, 11:33 PM
avgor avgor is offline
Mein Auto: 2012 BMW 320d F30
Thanks, TokenMaster!
It's an excellent job!
Old 07-30-2014, 07:07 AM
Rsnic's Avatar
Rsnic Rsnic is offline
Mein Auto: 2020 M340Xi (G20)
TokenMaster,
Wow, this is absolutely terrific!!
Have installed this on my desktop and use it to help figuring out all of the intricacies behind coding these great automobiles.
Beaucoup THANKS!!
Al
2014 328i |ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 2VF| 688| 6NWl|
Retired: 2014 328i
BMW CCA
Old 07-30-2014, 08:49 AM
Rsnic's Avatar
Dumb Question
TokenMaster or ShawnSheridan,
As I said above, this tool, along with E-Sys are absolutely superb!!
Have a really dumb question. Whenever I code my car or read & save the information in the various ECUs in the car, even though the entry in E-Sys (with the little green checkmark) is entitled a CAFD, when I save the file to my PC, it is saved as an NCD, albeit with CAFD as the preface to its name.
In this NCD-CAFD tool, there are several references to CAFD files, but can not figure out how to get these -- again, I do have NCDs.
Can someone help clear up my confusion
Al
Retired: 2014 328i
BMW CCA
Old 07-30-2014, 12:29 PM
Token Master
It's an excelent job!
Originally Posted by Rsnic View Post
TokenMaster,
Beaucoup THANKS!!
I enjoyed writing the app
Old 07-31-2014, 04:08 PM
Rsnic's Avatar
Well, a Big DUH on my part -- since this is part of the data package, I looked in the Data directory and its PSDZData subdirectory and a little further down, was a CAFD subdirectory.
Al
Retired: 2014 328i
BMW CCA
Old 07-31-2014, 04:11 PM
Yes, the CAFD are in ...\psdzdata\swe\cafd folder.
Old 08-08-2014, 12:24 PM
gspannu gspannu is offline
Mein Auto: F10 535, F82 M4
Originally Posted by TokenMaster View Post
And I move that it be reserve exclusively for you. Somebody second it quick
Agree. Bananas reserved for Shawn.
The coding world would not be the same without people like you guys.
Shawn, TokenMaster, JEG23 and many others...
Please keep up the good work....
These mean machines become that much meaner with your help.
Old 08-08-2014, 08:16 PM
Token Master
Old 08-28-2014, 04:52 PM
Token Master
Upcoming Feature: Typschlussel
Typschlussel [sic] or Type Key also have significant effect on CAF, so it's but natural to add this into FA/SVT-CAFD section. Type Key contains information about your car, from drive type, to engine, to fuel type and number of cylinders. My type key is 3A57.
My initial idea is to let user enter the type key. This then will be decoded to individual options that users can select. But then, I thought most wouldn't know what it is, much less, where to find it. It's in your FA, by the way. So, I decided to list down all applicable Vehicle Profile Type instead. Useful?
Old 08-28-2014, 05:49 PM
Yes, but a Type Key setting for those that know would be useful too.
Old 08-28-2014, 10:24 PM
jgbackes's Avatar
jgbackes jgbackes is offline
Mein Auto: 2014 750Li
I'm so entrenched into my OSX project that I forgot about this one.
OSX??? It would be nice to not have to run VMWare.
jeff
Old 08-28-2014, 10:44 PM
Token Master
Yes, but a Type Key setting for those that know would be useful to.
Not letting me get off that easy, eh?
Old 08-28-2014, 10:47 PM
Token Master
jeff
E-Sys itself can run under OSX natively but it relies on a Win32 library for all CAN communications, so it's a no-go if you want to connect to the car, unless the CAN library is ported to OSX-compatible format.
Old 09-08-2014, 07:53 PM
Token Master
NCD / CAFD Tool V0.2.7 Alpha
Update: 9/8/2014 V0.2.7 Alpha
  • Added Type Key options to "What-If" feature
  • Minor bug fixes
This is a direct drop-in replacement. If you have customized settings, just replace the executable to keep your settings intact. Settings are kept in NcdCafdTool.exe.Config file.
Timur requested if Type Key can be added. And when I looked into it, it does affect CAF, so it's worth adding it.
Results are determined by a particular CAFD and not every option will have an effect on the selected CAFD. Don't select any options that obviously don't have any code associated to it, e.g. 130, 23B
Results are meant to be use as a guide only. They are by no means authoritative or definitive. Verify and use at your own risks.
Lastly, this tool is free. Never pay anything for this tool.
Rename to .zip NcdCafdTool_V0.2.7.zip.pdf
Alternate Download: Google Drive
