Flashing ECU's with E-sys [GUIDE] - Page 13 - Bimmerfest - BMW Forums
Old 08-24-2019, 09:24 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by kujass.pl View Post
Which e-sys should I use for flashing?
Injecting CAFD and Flashing ECU's with >= v.4.17.20 PSdZData require using newer E-Sys 3.33.x:
1) Install E-Sys 3.27.1 to default location, C:\EC-Apps\ESG\E-Sys.
2) Use E-Sys 3.27.1 for normal FDL and VO Coding. For FDL Coding, use E-Sys Launcher PREMIUM 2.x to launch E-Sys 3.27.1,
3) Install E-Sys 3.33.4 to different location, e.g. C:\EC-Apps\ESG\E-Sys_3.33.4
4) Use E-Sys 3.33.4 for CAFD Injection and Flashing. Do NOT use with E-Sys Launcher PREMIUM 2.x.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 08-24-2019, 10:02 AM
kujass.pl kujass.pl is offline
Mein Auto: F10 535i
Thanks @shawnsheridan, I will go with the 3.31.0 (the newsest I have).
So I have two weirdos.
1. I don't know why some folders are blue/red, some black?
2. I have one icon with two green arrows, which means that ECU has changed? Strange thing, because there is nothing about it in the car history and this ECU is Function unit roof... (no, the car hadn't accident before .
one more thing, I have retrofit combox with esys and there is no green arrows in that ecu.. What I was expecting.
535i F10 / USA
Old 08-24-2019, 10:15 AM
Mein Auto: F10 535i
Ok, Probably I'm going nowhere without the newsest 3.33.4...... Shwan, do you mind if I ask you for the link (32 bit)?
Code:
Error in module "TALL processing" while reading element  from XML file "svt_tal.xml". [C352]
Error in XML parser: File "C:\Data\TAL\svt_tal.xml" is corrupt or not of type XML. [C087]
Invalid "Tal": "cvc-elt.1.a: Cannot find the declaration of element 'svt'. [line 2, column 48]" [C294]
Update: I got 3.33.0 (the last one with 32 bit support)
535i F10 / USA
Old 08-24-2019, 11:07 AM
blue/red means ECU has some firmware update(s). Black means no update.
Old 08-25-2019, 09:38 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Thanks for the reminder. I have added 3.33.4 to list.
Old 08-25-2019, 11:11 PM
weebyx weebyx is offline
Mein Auto: BMW 320d F30 2018
The green arrows does not mean ECU has been changed. It means that this ECU is not the correct HWEL version for your car/I-Step, and needs to be changed to match the car.
If it is the original module, then you probably have selected the wrong I-Step Factory when doing the TAL calculation ?
/Weebyx
Old 08-27-2019, 02:58 PM
Stoonage1 Stoonage1 is offline
Mein Auto:
Hello everyone,
I guess my FZD needs to be flashed since my sunroof and read lights are not working.
I have esys installed and working ( coded some CFADís) i am using an enet cable.
Here are my questions:
1 is the enet cable correct for flashing activities? ( i cannot connect to the gateway)
2 is it mandatory to connect to the gateway for flashing ?
3 i tried the inject with no success (see picture3)
4 i am trining to flash the fzd according to the guide but also with no success ( see picture )
5 no possibility to read coding data
Thanks in advance
ID:	862541Click image for larger version
ATTACH]862539[/ATTACH]) Click image for larger version
Sent from my iPhone using Bimmerfest mobile appClick image for larger version
Old 08-27-2019, 04:51 PM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
i do not read so much German..but did you read or set FA before flashing? what car??
Old 08-27-2019, 11:34 PM
Mein Auto:
Yes i was already able to vo code but when it comes to flashing itís nit working. Maybe i need to connect to the gateway?
Old 08-28-2019, 01:19 AM
Curamrda's Avatar
Mein Auto: Fxx
on the 3rd picture.. does it say, you have to define FA first ? So you were able to connect to the car, read FA/ SVT, calculate tal .. but not able flash?
Old 08-28-2019, 01:27 AM
Mein Auto:
Yes it said the FA must be set when Tal contains coding transactions
Yes, but it was a connection via vin and not gateway
Gesendet von iPhone mit Bimmerfest
Old 08-28-2019, 09:05 AM
Mein Auto:
Old 08-28-2019, 11:20 AM
Mein Auto:
Originally Posted by Stoonage1 View Post
Attachment 862689
Old 08-28-2019, 11:23 AM
Mein Auto:
Here ist picture i hope you can help
Old 08-29-2019, 01:07 AM
Curamrda's Avatar
Mein Auto: Fxx
Attachment 862691
well, the error note is quite explaining... " FA must not be a Null.... " . Did you set proper SVT, TAL and FA before flashing? show us the those fields or attach the FA.xml file
Old 08-29-2019, 11:08 AM
Maxwell4321 Maxwell4321 is offline
Mein Auto: F13 M6
Attachment 862691
You have made a mistake in reading the VIN
In TAL Processing:
Click on Read FA button to generate FA_aus_VCM
Select Read VIN out of FA then click on Read VIN
If you click Read VIN while Enter VIN is selected you will get the FA Null error
Old 08-29-2019, 06:53 PM
Almaretto's Avatar
Super Moderator
Attachment 862689
"FA must not be a Null"
https://www.bimmerfest.com/forums/sh...d.php?t=876038
Old 09-03-2019, 01:32 AM
pablito_f10 pablito_f10 is offline
Mein Auto: Bmw F10 3.0d
For both esys should I use full psdzdata?
Old 09-03-2019, 07:24 PM
Almaretto's Avatar
Super Moderator
You can use lite to calculate. But, need full to actually flash.
Old 09-07-2019, 04:33 PM
Thanks for reply
I have got some more questions to make sure I'll do everything correct . I have calculated SVT an TAL in Esys 3.2.7 . Finally I understood what dependencies are - I need to check ecu which I want to update for any PreRequsite ECU and update them aswell . Here are my some questions .
1) As you can see on picture -for example Kombi has got PreRequsite of TalLine 1 ,3 and 15 - TalLine 3 and 15 is same ECU-ZGW. So why it has got two PreRequsite if this is one module ?
2) when I open ESYS 3.33.4 and want to open SVT file generated in esys 3.2.7 warrning alert comes up. Why ? There is same problem for TAL .
3) ECU list in tal processing shows me 2 the same ecu's SM 6E and 6D.
4) as some ecu's have got dependencies of ZGW ,should I be worried to flash it ?
5) what ecu's do you recommend to update ? some told me to update Steering,Fuel pump,traction and automatic gearbox but I cannot see fuel pomp,gearbox and steering on ecus list.
ID:	863733   Click image for larger version
Old 09-13-2019, 11:19 PM
motorberserker motorberserker is offline
Mein Auto: F10 520d
I got the problgm of "I-Step ist not available" too.
have tried the E-Sys versions of 3.26, 3.27, 3.28, 3.30 and 3.34. The problam unfortunately remains.
Actually I successfully update the ZGW2 last year by following the this guide, however it doesn't work with the new PSDzData Full (Extracted from ISTA version 4.17.13), and all the E-Sys mentioned above.
Is there anything else I missed?
thanks an advance.
Old 09-14-2019, 12:03 AM
Almaretto's Avatar
Super Moderator
thanks an advance.
Switch bullet to "Complete Flash."
Old 09-14-2019, 01:54 AM
Mein Auto: F10 520d
I've tried, it still doesn't work.
I remember these two fields "I-Step (shipm.) & I-Step (target)" shoud show the version no. after reading and activing the FA, but the "I-Step (target)" could be modifed only if the Calculation Strategy is switched to "Complete Flash". However it shows "not available" no metter I switch to "Complete Flash" before or after reading th FA.
Old 09-14-2019, 01:59 AM
Reinstall esys. Uninstall esys and his file like DATA folder etc. Remember, DATA folder needs to be deleted manually. Install esys again with psdzdata . Should help.
Old 09-14-2019, 02:21 AM
Almaretto's Avatar
Super Moderator
Then you have something installed incorrectly. All you need are three things:
1. FA
2. SVT
3. Complete Flash
Then, you should be able to select shipment. You can even do with Psdzdata lite.
