Flashing ECU's with E-sys [GUIDE] - Page 2 - Bimmerfest - BMW Forums
Old 12-18-2016, 05:33 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by egisz View Post
Hi All!
Thanks zkiifreak for great manual, I tried to flash ZGW yesterday and it was not as straight forward as I expected
Details are on another thread, but I'd like to ask few questions here as it may be also usefull for other users.
I have some questions:
  1. Should I use Esys Launcher for flashing ECU? For me it was only way to flash ZGW with launcher ...
  2. What Esys options should be set for ECU flashing? Are they same as for Coding? Should I set Update VCM after TAL execution and Update MSM after TAL execution?
  3. What can cause warnings " VCM-Update is deactivated"? Can it be that Esys/pszdata is too new version for my car?
  4. What could cause warning Could not read ComParam 'MODE_CHANGE_PARAMETER'?
Asked and answered back in original thread, but here is again for benefit of this thread:.
1. E-Sys Launcher is needed only for FDL Coding. Why would you introduce an unneeded variable that adds no value into an already delicate and complicated flashing process?
2. Incidentally, the very errors you are asking about "MODE_CHANGE_PARAMETER doesn't map to an item'" are introduced by using E-Sys Launcher.
3. "Update VCM after TAL execution" and "Update MSM after TAL execution" should always remain unchecked. If you want top udpate car I-Step after a Full Update of car, then go to VCM Module and manually update I-Step Current.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-08-2017, 09:12 AM
tom2325 tom2325 is offline
Mein Auto: F30,F10
Hi,
This is the information for guys who have a plan to retrofit Automatic trunklid.
I have failed to flash HKFM_LS module.
The process is as follows.
1) Done Automatic trunklid retrofit to my Activehybrid 5.
2) I added 316 to FA Salapa.
3) I could not inject cafd by using the 'Detect CAF for SWE' button because there is no cafd file maching swfl_00000D9A_006_007_000.
I have never got this error when detecting CAF.
So, I decided to update the SWE file of HKFM_LS module in order to inject latest cafd file.
4) I tried flashing HKFM_LS by E-SYS as instructed in zkiifreak's manual.
5) I got erorr when calculating TAL. This is the first error.
I can not figure out but I continued my work because SME2 module may be no relevant to HKFM_LS.
5) Checked only HKFM_LS on the ECU list of TAL-Processing.
6) I got second error when executing TAL flashing HKFM_LS.
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2017/01/07-14:53:25.638
[HKFM_LS - 6B] - [Exception - HKFM_LS - 6b] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HKFM_LS_0x6B.
Excpected (relevant process classes only):[hwel_00000d98-004_002_000],
Actual (relevant process classes only): [hwel_00000d98-004_001_000],
Missing SGBMID(s): [hwel_00000d98-004_002_000],
Surplus SGBMID(s): [hwel_00000d98-004_001_000]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "1min 3s". [C206]
I think the causes of this error may be;
1. Flashing by modified FA caused confusion.
2. Retrofitted HKFM_LS module is older than my F10, so E-Sys could not inject latest cafd or firmware into the module.
I can not figure out the confusion of using modified FA, so I will try the another HKFM_LS module which has the latest SWFL file.
Will be reported soon.
Old 01-18-2017, 05:38 PM
powershot powershot is offline
Mein Auto: BMW F31 318d
Hi Guys,
I need to upgrade the FEM in my F31.
I bought a used MAX FEM and a guy already coded my car VIN in the used FEM.
The problem is that he cannot update the software in the FEM, he says the software finishes and then restarts, in loop (he is not using E-sys).
Do you think that is possible to flash the FEM with E-sys by following the steps in this tutorial?
I already coded some things with E-sys and it seems easy to execute this tutorial.
My only concern is to identify the correct dependencies for the FEM.
Many thanks
Old 01-21-2017, 06:32 AM
flashdash flashdash is offline
Mein Auto: 2010 bmw 535d m sport F10
I would like to update the DSC I& EGS ecus in my 2010 F10, would I need to update SHE aswell?
Sent from my SM-G935F using Tapatalk
Old 01-21-2017, 10:04 AM
Almaretto's Avatar
Almaretto Almaretto is online now
Super Moderator
Mein Auto: Test Vehicles
I am not sure what SHE is, but guide goes over dependencies.
Old 01-21-2017, 10:06 AM
Sorry I meant ZGW,
Old 01-21-2017, 10:08 AM
Almaretto's Avatar
Super Moderator
Sorry I meant ZGW,
Answer is still the same: "How to identify dependencies:"
Old 01-21-2017, 04:09 PM
Tak Miya's Avatar
Tak Miya Tak Miya is offline
Mein Auto: F34 320i
Originally Posted by tom2325 View Post
Hi,
Hi Tom
I & U are on the same boat probably.
Refer my experience "HKFM module flashing procedure" as below for your reference.
https://www.bimmerfest.com/forums/sho...98&postcount=6
And let me suggest that you may change language setting of e-sys from Germany to English for easy understanding unless you are Germany...
option --> setting --> language
F34 320iGT 2013 OCT manufactured by Dingolfing , Germany
Old 01-23-2017, 03:41 AM
Tried to update CID & HU_CIC ecus with esys 3.2.8.1 and got following errors also my navigation is greyed out if i press nav button it says currently unavailable can anyone help please
ID:	587573Click image for larger version
Old 01-23-2017, 05:51 AM
Attachment 587573Attachment 587574
This "SVK-Ist does not match expected SGBMIDs for ecu..." means you have chosen an improper I-Step Shipment when you made your SVT Target (SVT_soll).
Old 01-23-2017, 05:53 AM
How can I revert back to standard is this possible I saved all data, any help appreciated
Old 01-23-2017, 06:06 AM
You picture shows flash went for 46 minutes before faling...I don't think there is any turning back. You need to properly flash it, using correct I-Step Shipment of car.
Old 01-23-2017, 10:11 AM
I double checked the I shipment of my car it is f010-10-09-524 but still getting the same error, any possibility you can do remote access to fix, I Dont mind paying
Old 01-23-2017, 10:16 AM
In SVT_soll (Target), does HWEL show as Balck, or Red / Blue?
Old 01-23-2017, 10:27 AM
Black. I dont seem to have a CAFD under HU_CIC and cannot seem to code one in either
Old 01-23-2017, 10:37 AM
Well, that confirms I-Step shipment is correct, so now I am at a loss as to why you have "SVK-Ist does not match expected SGBMIDs for ecu..." in first place.
Old 01-23-2017, 10:39 AM
I managed to update my KOMBI, and EGS fine on the hu_cic I get error and also on cid, problem now is,my navigation says unavailable also now my car is,saying battery low ,Recharge even though I've charged battery and registered a new battery using diagnostic tool, wish I never messed with the I drive
Old 01-23-2017, 10:41 AM
Does CIC and CIC have CAFD with Green Dot? Are they codeabale?
Old 01-23-2017, 10:51 AM
CAFD is missing in CIC I cannot code or add CAFD always gives error
Old 01-23-2017, 10:55 AM
Well, you you will need to try flashing CIC again. I would start over, make new Flash TAL and run it for CIC only.
Old 01-23-2017, 10:57 AM
Ok thanks will try tomorrow
Old 01-24-2017, 12:38 AM
If I wanted to flash back to original factory shipment state what version psdzdata would I need any ideas
Old 01-24-2017, 03:13 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
WDBI_CPS in HU_CIC means WriteDataByIdentifier_CodierPrüfstempel. E-Sys wasn't able to write the correct VIN into the Head Unit. Normally you will get those problems when your VO has a wrong VIN inside or anything else. It seems that E-Sys stopped the flash procedure during the cdDeploy (WDBI_CPS is an error for cdDeploy). Please mark the event box in folder logs in TAL processing - then you can see a little bit more what's happen during the flash procedure.
SVK errors by flashing CID is normal when your CID is from 2010 and/or the first half of 2011. It's one of the problem E-Sys has with CIDs (remember the problems with cdDeploy with corrupted CAFD in CID).
CU Oliver
BMW F30 330e Hybrid 2016 in tansanit blue, cohibabrown for every day (09/2019 G20 330e in tanasnit 2 blue, all in )
Jaguar XK8 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 01-24-2017, 03:15 AM
Originally Posted by milkyway View Post
Hello!
CU Oliver
Is there anything I can do to rectify this issue as my navigation isn't working, also before flashing I checked the vin and it matched
Old 01-24-2017, 03:21 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
1.) check the FSCs inside the CIC
2.) attach the picture from the SVT_IST/SOLL calculation
3.) reflash the CIC with the existing TAL
CU Oliver
