Flashing ECU's with E-sys [GUIDE] - Page 3 - Bimmerfest - BMW Forums
Old 01-24-2017, 04:31 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by flashdash View Post
If I wanted to flash back to original factory shipment state what version psdzdata would I need any ideas
Sent from my SM-G935F using Tapatalk
You should be able to flash with any version, not just original version. But if you want original version, what is your I-Step Shipment?
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-24-2017, 04:36 AM
flashdash flashdash is offline
Mein Auto: 2010 bmw 535d m sport F10
10-09-524
Old 01-24-2017, 04:43 AM
10-09-524
I don't show a F010-10-09-524, but F010-10-09-522 is 39.4.
Old 01-24-2017, 08:31 AM
I'm going to try flash the CIC again what options shall I tick in the ecu options just blflash, swdeploy, & cddeploy
Old 01-24-2017, 08:34 AM
And IbaDeploy.
Old 01-24-2017, 09:06 AM
Just tried to reflash and after 10 seconds got the following error
Old 01-24-2017, 09:10 AM
The error is on the cddeploy part
Old 01-24-2017, 09:35 AM
Originally Posted by milkyway View Post
Hello!
1.) check the FSCs inside the CIC
2.) attach the picture from the SVT_IST/SOLL calculation
3.) reflash the CIC with the existing TAL
CU Oliver
Here are pics of fsc, SVT_IST/SOL I tried reflashing with current tal it fails below are pics Click image for larger version
ID:	587668Click image for larger version
ID:	587669Click image for larger version
ID:	587670Click image for larger version
ID:	587671Click image for larger version
Old 01-24-2017, 10:56 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
You should try a flash with the old TAL. That one you used for the first try.
And please send the same pictures from that one before you click on start.
CU Oliver
BMW F30 330e Hybrid 2016 in tansanit blue, cohibabrown for every day (09/2019 G20 330e in tanasnit 2 blue, all in )
Jaguar XK8 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 01-24-2017, 10:59 AM
Hello!
CU Oliver
And the FA do I read FA or load saved FA?
Old 01-24-2017, 11:34 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
If you have the original VO in VCM you can read it.
CU Oliver
Old 01-24-2017, 12:01 PM
Hello!
CU Oliver
This is error I got when truer flashing with saved tal
Old 01-24-2017, 12:10 PM
Almaretto's Avatar
Almaretto Almaretto is online now
Super Moderator
Mein Auto: Test Vehicles
Run without Launcher.
Old 01-24-2017, 12:11 PM
Will it run without me having a token?
Old 01-24-2017, 12:14 PM
Token needed only for FDL Coding and nothing more.
Old 01-24-2017, 12:15 PM
Great I'll try running without loader
Old 01-24-2017, 12:22 PM
Almaretto's Avatar
Super Moderator
Think You Need a Software Token? Maybe Not.... Token only needed for:
  • FDL Coding (CAF-Viewer, FDL-Editor, & Applying Changes)
  • Coding-Verification
Old 01-24-2017, 01:53 PM
Tried to flash using esys without loader exactly same error on cddeploy, is there anything else I can try?
Old 01-24-2017, 02:25 PM
Almaretto's Avatar
Super Moderator
THE FLASHING PROCESS
Old 01-25-2017, 12:00 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
Only a cdDeploy should not solve your problem. That's the reason why I asked you about some pictures from your old SVT_IST/SOLL calculation and for the TAL. I mean this calculation which you used for the first flash (with the WSDBI_CPS result). It could help to flash bootloader, iba and swfl again.
Do you checked the status of your FSC inside the head unit (E-Sys, comfort mode, FSC) for diagnose adress 0x63? Is the VIN for the FSC the same like the VIN in your VO?
WDBI_CPS means that E-Sys isn't ablo to inject the VIN correctly in the head unit. This can happen some times, mostly when you will flash a used cluster with an undeleted eeprom. This can also happen when you try to flash a head unit with an uncorrect VIN.
CU Oliver
Old 01-25-2017, 12:15 AM
Hello!
CU Oliver
The head unit I'm trying to flash is the original to the car, I will check fsc, the shortly, the pictures you require from my old svt do I open the svt sol I saved in the coding section then take picture of the hu_cic tree?
Old 01-25-2017, 12:18 AM
Hello!
CU Oliver
Here are pics of SVT_ist and SVT_sol
ID:	587712Click image for larger version
Old 01-25-2017, 12:32 AM
Just checked vin in FSC it's the same as ,my car and my FA
Old 01-25-2017, 12:33 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
This calculation is not correct. Please check your shipment i-level!!!!!!!!!!!!!!!!!!!!
I'm sure, this is not F010-16-11-503. In that case your calculation must be wrong and you will get a nice error during the flash procedure. With a 16-11-503 E-Sys will expect a NBT as head unit, not a CIC!
And I'm wondering why E-Sys will make only a cdDeploy with a CIC. Now it's clear - wrong shipment i-level.
CU Oliver
Old 01-25-2017, 12:38 AM
Hello!
CU Oliver
It always connects as this but if I check I shipment in the vin it shows different, how can I change this incorrect I shipment
