Flashing ECU's with E-sys [GUIDE] - Page 4 - Bimmerfest - BMW Forums
Old 01-25-2017, 12:45 AM
flashdash flashdash is offline
Mein Auto: 2010 bmw 535d m sport F10
Here is pic of I shipment
Sent from my SM-G935F using Tapatalk
Old 01-25-2017, 12:57 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
Please check your shipment i-level in E-sys. Expert mode/VCM, folder master and then i-step read. Then you can see your shipment i-level. In TAL calculation choose this shipment i-level for the calculation and calculate it again. You should get a correct SVT_SOLL and a correct TAL. Flash then the head unit again.
EDIT: Choose this i-level F010-10-09-524 as shipment i-level and calculate SOLL again. The result should be massiv different to your first one.
CU Oliver
BMW F30 330e Hybrid 2016 in tansanit blue, cohibabrown for every day (09/2019 G20 330e in tanasnit 2 blue, all in )
Jaguar XK8 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 01-25-2017, 12:59 AM
Originally Posted by milkyway View Post
Hello!
CU Oliver
Should I load the saved SVT then recalculate or shall I read the current SVT from car and calculate
Old 01-25-2017, 01:00 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
Read VO and activate it, read SVT (read ECU), choose your correct shipment i-level, calculate SOLL.
CU Oliver
Old 01-25-2017, 01:16 AM
Hello!
CU Oliver
Just tried and got this error straight away
Old 01-25-2017, 01:38 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
Please post the calculation.
CU Oliver
Old 01-25-2017, 01:41 AM
Hello!
CU Oliver
Screenshot or actual file?
Old 01-25-2017, 01:43 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
Screenshot from your calculation with the correct shipment level.
I fear that you flashed your CIc with a wrong TAL (wrong shipment level for calculation) and therefore you have to flash it totally new.
CU Oliver
Old 01-25-2017, 02:20 AM
Old 01-25-2017, 02:58 AM
I'm surprised because with the saved SVT I managed to flash KOMBI, AMP_TOPHB, EGS, DSC without issues just the HU_CIC is giving me problem
Old 01-25-2017, 05:40 AM
Can anybody help me to get my navigation working the option is currently greyed out, if I press the navigation button it says function currently unavailable
Old 01-28-2017, 06:03 AM
Hello!
CU Oliver
From the screenshot I sent you of my shipment level can you advise any further as to what I can do?
Old 02-07-2017, 10:17 AM
bmwrider2010 bmwrider2010 is offline
Mein Auto: F11
Does anybody know why flashing process won't start? It finishes after 1sec. Trying to retrofit 6WA KOMBI on F11. FA changed to 0311, 6WA added. I don't know KOMBI I-step shipment so I choose closest one. No matter what I try result is same
Old 02-08-2017, 08:53 AM
Mein Auto: F11
got it sorted changed I-ship for first possible with 6wa
Old 02-09-2017, 02:55 AM
gk tds gk tds is offline
Mein Auto: 535d
I have exactly the same problem with 6wa on f10 2010.
Old 02-28-2017, 07:15 AM
KL4K50N KL4K50N is offline
Mein Auto: F10 525d
Hello,
I did 6WA retrofit in my F10. The cluster came from F01. I would like to flash a new software via E-sys in KOMBI. When i press TAL calculation i've got two errors (MULF 55, TEL 36)... After that when i press START to do a flash i have this message :
[/QUOTE]
Old 03-02-2017, 05:28 AM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
will this guide work, if I will download latest pszdata for bmw f10 , and try to upload / flash new bin for CIC to update the CIC sw? Shall I somehow backup the origin *.bin file in the CIC in car?
which file do I have to upload to cic exactly ?
thanks
Old 03-02-2017, 08:04 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
thanks
The Guide is good for flashing any and all ECU with E-Sys.
Follow the Guide. There is nothing to backup, and the process when followed will identify what specific firmware files are to be updated on CIC and then will update it.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 04-27-2017, 01:25 AM
Curamrda's Avatar
Mein Auto: Fxx
hello,
do I understand it correct, that if i will download full DATA, and check checkbox "ALL ECU" esys will calculate order which ECU should be updated first, according the dependencies?
and for all ECUS have only check checkboxes: blFlash, swDeploy, cdDeploy, and ibaDeploy?
Anyway i would like to backup that old bin files in ECU, before flashing. just to have the origin sw in cace if anything goes wrong. How can I save the sw from ECUs in car?
Thanks.
Old 04-27-2017, 11:01 AM
aboulfad aboulfad is offline
Mein Auto: 15 M4, MG/SO
hello,
Yep.
Yes.
The only way I know of, is that you figure out your car's I-step, and download from somewhere on the Internet the corresponding psdZdata FULL. You can not save the ECU firmware from the car...
Old 04-27-2017, 02:35 PM
Curamrda's Avatar
Mein Auto: Fxx
thanks for excelent answers ! Thats what I needed to know
Old 04-27-2017, 03:04 PM
you are welcome !
Old 04-29-2017, 06:18 AM
obieda.atiyani obieda.atiyani is offline
Mein Auto: m4
Hello. I'm almost done downloading the files for esus full. Glint to flash whole car but have few qs:
1) do I have to worry about the dependencies if I'm doing the whole car?
2) do I need to lock airbags before flashing? If not when do I do this?
3) on the flashing screen which boxes am I supposed to select?
Thank you in advance!
Sent from my SM-G935T using Tapatalk
Old 04-29-2017, 06:51 AM
1) No.
2) No. You will have to lock ACSM after flash.
3) Make check boxes in blFlash, swDeploy, and cdDeploy, and for Head Unit, also check ibaDeploy.
Old 04-29-2017, 07:18 AM
Mein Auto: m4
Thank you so much. I have to mention that for some reason I lost the navigation code (its grayed out) but thats not my worry now. I will flash car first then try to get the code. If anyone can help me with that I'd really appreciate it. Thank you
