Flashing ECU's with E-sys [GUIDE] - Page 5 - Bimmerfest - BMW Forums
Old 04-29-2017, 07:23 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by obieda.atiyani View Post
Thank you so much. I have to mention that for some reason I lost the navigation code (its grayed out) but thats not my worry now. I will flash car first then try to get the code. If anyone can help me with that I'd really appreciate it. Thank you
Sent from my SM-G935T using Tapatalk
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 04-30-2017, 10:13 AM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
Originally Posted by shawnsheridan View Post
1) No.
2) No. You will have to lock ACSM after flash.
3) Make check boxes in blFlash, swDeploy, and cdDeploy, and for Head Unit, also check ibaDeploy.
2) lock? how? what if not?
3) so ibaDeploy only for HU_CIC/HU_NBT? what if it will be checked for other ECUs?
Old 04-30-2017, 10:16 AM
2)
https://www.bimmerfest.com/forums/sho...d.php?t=817447
3) No harm if it is checked for other ECU.
Old 04-30-2017, 10:23 AM
Curamrda's Avatar
Mein Auto: Fxx
2)
thanks!
Old 04-30-2017, 10:24 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Check SVT.
  • blFlash: Flashes new Bootloader (BTLD)
  • swDeploy: Flashes new Software (SWFL)
  • cdDeploy: Encodes (e.g. VO Codes ECU, CAFD)
  • ibaDeploy: used to update the Owners manual for HU (IBAD).
You will only find IBAD under HU. But, as ShawnSheridan said, no harm in selecting for all.
Old 06-01-2017, 02:40 AM
TomaGo TomaGo is offline
Mein Auto: BMW X4
Hello,
I need your help please !
I have flash my DDE module (engine) with the last version of EsysFull and the procedure from this thread. The flash finish sucessfully.
But now i have a lots of errors :
- Handbrake
- ABS
- Automatic PDC
- Start&Stop
If i clear the errors they are back immediatly
What could be the root cause and how can i solve this ?
Thanks for your answers :-)
Thomas
Old 06-01-2017, 04:45 AM
DocNuas's Avatar
DocNuas DocNuas is offline
There's no Doc. Only Zuul
Mein Auto: 1 Series
Have you tried driving the car around for a while to see if some of them clear?
Old 06-01-2017, 04:47 AM
Mein Auto: BMW X4
Just a few hundreds meters. Nothing change...
Old 06-01-2017, 05:03 AM
efodela efodela is offline
Mein Auto: e90 325i
Have you tried reflashing it and the other modules too?
Sent from my SM-G935W8 using Tapatalk
Old 06-01-2017, 05:09 AM
Mein Auto: BMW X4
No i didn't.
Do i need to do it again ?
And flash zgw2 to ?
Old 06-01-2017, 05:21 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
I think you flashed with the latest i-step (17-03-505). What is the current i-level from the rest of the car?
CU Oliver
BMW G20 330e in tansanit 2 blue, all in )
Jaguar XK8 4.2 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 06-01-2017, 05:30 AM
aboulfad aboulfad is offline
Mein Auto: 15 M4, MG/SO
Here is my reply from another forum to @tomago, just to help the community help him... You need to provide more information, if your DME previous Istep was way too old relative to the new one you flashed, in some cases, some users reported issues where they lost certain functionnality (CC) but that has nothing to do with the three top errors.
Ok, those first two errors tell you that you need to teach your Gear sensor. If you execute "test measures" in ISTA, it will show you procedures to remedy those two faults. If you don't understand any of this, then you need help !
The short circuit error could be related to the above two or not...
The 2TB was a mod where you opened your HU (radio), or just hooking it up in the USB port? Hard to say, but I don't think it is related.
Now why these 3 errors popped up after you flashed, no idea, there is as always a piece of information that users don't provide...
Old 06-01-2017, 06:06 AM
Mein Auto: BMW X4
Olivier and Aboulfad,
This was my original i-Step (updated one time per BMW)
I have flashed ECU DDE with F025-17-something
Is this an issue ?
Old 06-01-2017, 06:31 AM
Is this an issue ?
As per the other forum, you also previousely added 2TB option few months ago, can't tell for sure if there is some incompatibility between other ECUs stuck on 2014, and now DME on 2017.
Old 06-01-2017, 07:03 AM
Mein Auto: BMW X4
So maybe i have to flash it back to the original version ?
Old 06-01-2017, 07:09 AM
Normally when you flash DME / DDE, you should also flash EGS. I would flash both modules with original unmodified FA.
Old 06-01-2017, 07:21 AM
I second @shawn's suggestion, although i have updated my DME alone but with a smaller software version difference (55.3 to 58.3, roughly 1 year apart) and no mods to my EGS.
Old 06-01-2017, 07:27 AM
Mein Auto: BMW X4
Ok, so to summarize :
- Remove 2TB Sport Auto option
- Add 2TE (the original config)
- Flash DME
- Flash EGS
Old 06-01-2017, 07:44 AM
- Flash DME
- Flash EGS
Yes.
Old 06-01-2017, 08:55 AM
Mein Auto: BMW X4
I did it and it's works !
aboulfad and shawnsheridan i love you :-) Thanks for your wonderfull help and disponibility.
Thanks also to everyone else who participate
I have replace 2TB option by 2TE as it was at the factory, then flash EGS, then DME, clear the errors 2 times, et voila ! I think that the issue was because of the 2TB option.
EGS and DDE Flash (2 and 2 minutes) :
Good news :
I have to do a test run to confirm but it seems to be ok, i'm so happy
Thanks again !!
Old 06-01-2017, 08:59 AM
Mein Auto: BMW X4
So, now i have 2 more questions :-)
1/ To finish this job, what do you think about updating the other modules ?
(maybe tomorrow, to much stress for today !)
2/ Including the gateway ZGW2 ?
Bye
Old 06-01-2017, 09:26 AM
Mein Auto: BMW X4
shawnsheridan here is a present for you, i know you like bananas
Old 06-01-2017, 09:31 AM
Bye
I would never update any ECU without good reason, especially ZGW. Either you are fixing a bug or adding a new feature. Other than that, there is no reason to udpate.
Nice....I have not seen a 5 banana salute in quite a long time...thanks.
Old 06-30-2017, 07:24 AM
masa52 masa52 is offline
Mein Auto: X6M
Guys how to flash any existing ecu from SVT list even if no software available after TAL????
In all manuals we can find only flash available when new software existing but what if we want to flash again unit with old software???
thanks
Old 06-30-2017, 07:25 AM
thanks
Use old PSdZData Full, Calculate Flash TAL, execute Flash.
