F45/F46/F48/F55/F56 Coding Thread - Page 14 - Bimmerfest - BMW Forums
Old 06-17-2019, 01:29 PM
cucca76 cucca76 is offline
Mein Auto: bmw x3 f25
Originally Posted by ak0707 View Post
Hi cucca76
If you are installed steering wheel Control Unit with Vibration Actuator Motor then code: LIN_VARIANTE_LRE > lre_tlc LRE_VERBAUT > aktiv
Did you installed Control Uni for vibration motor only or with heated ?
HELLO AK0707
I only installed the vibration, and the two codes configured it but it always gives me the error.
the module code is the following 9218381-02
I tried various encodings but nothing, I checked power supply and it's ok the only thing that comes to mind is that the module doesn't work. or are there other encodings to do? I connected the module to the lin11 as described in the tis.
Old 06-17-2019, 01:32 PM
rhiza888 rhiza888 is offline
Mein Auto:
Hello, Need help to fix my Problem.
Sport+ is activated and Works, but no signal in cluster/kombi, when Activated.
I tried to FDL Code the Kombi like: FDS_Menue_Text/Signal1-4 to Menue_3
My Problem is, if i try to Code, there is no Option Menue_3. I only can change to Menue_10.
The Button ***8222; Werte" one line down Could be changed to everything i want. But i dont know the number of werte.
Is there a way to fix my Problem?
HERE is a photo of my car shown in esys:
Old 06-17-2019, 02:58 PM
ak0707 ak0707 is offline
Mein Auto:
I had same issue when I aktiv Sent_msg_345 in Kafas2 so don't need to aktiv this entry instead of that Try this
In Kafas2 SEND_MSG_A18 > aktiv
In BDC_BODY ComAdapterPdu_18A_Steurung_Vibration_Lenkrad > aktiv
If you have ICM module then code
Vibration_Lenkrad > Aktiv
Old 06-17-2019, 03:18 PM
Mein Auto:
Try this
in NBT
eff_dyn_sport_cid
eff_dyn_sport_unit
hud_sportanzeige_enable
hud_sportanzeige_fes_enable
hud_sportanzeige_ms_gasse_enable
In Kombi
hud_pia_m_sport
ki_pia_m_sport_digi_tacho
spa_sport_enale
I think these entires related to HUD and Kombi display
Old 06-17-2019, 03:20 PM
Mein Auto:
HELLO AK0707
I tried various encodings but nothing, I checked power supply and it's ok the only thing that comes to mind is that the module doesn't work. or are there other encodings to do? I connected the module to the lin11 as described in the tis.[/QUOTE]
[QUOTE=ak0707;13030135]
Hello cucca76
If you have ICM module then code Vibration_Lenkrad > Aktiv
Old 07-05-2019, 10:20 AM
Mein Auto:
Looking / Searching for Can-High and Can-Low Signal for Can-Bus controlled Valve Exhaust.
Hello,
i want to install a ***8222;HG-Motorsport Ego-X" Valve Controlled Exhaust.
To install the Controller i Need to know, where i can find the Can-High and Can-Low Signal in BDC??
I Need to know Pins and Cable-Colors.
Anyone know the answer?
Old 08-16-2019, 01:23 AM
funkier funkier is offline
Mein Auto: F30 N13
Hello,
Has anyone succeeded on the activation of camera based active cruise control?
Mein Auto: F30 N13
Hello,
Old 09-11-2019, 02:31 PM
Damienf45 Damienf45 is offline
Mein Auto: 220d active tourer f45
Hello Shawn, or anyone who can help
I have an F45 with active guard and I want to activate SLI. Can you help regarding fsc code? Thanks in advance.
Old 09-11-2019, 02:33 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-30-2019, 11:44 AM
Coding SLI on F45
I managed to FDL code SLI (Speed limit information) to work on my BMW F45 (Active Tourer). I gained all my information and software from reading these open forums (thankyou everyone esp shawnsheridan and ak0707) and thought I could feed this little bit back hope it helps someone...
What is needed?
An FSC code this needs to be imported into the KAFAS2 ECU to enable the option. The FSC code is unique for the car VIN. The FSC code can be obtain through a few sources (BMW dealers, Tuners/ coding houses). PM me if your stuck for an FSC code.
The usual software ESYS, ESYS launcher, and ODB to Ethernet cable.
The car must have a KAFAS camera. I think the camera is standard equipment on all F45s as it is needed for Active Guard (Forward collision warning) which is shown in my brochure (UK Jan 2017) as standard on all trim levels.
I'm not sure if navigation is strictly needed as well, I know that SLI does use a GPS location and maps to determine speed limit in addition to road signs detected by camera (my car has navigation plus).
Why FDL (instead of VO code)?
SLI on its own (without Driving Assistant) cannot be VO coded on the F45. Normally there is a distinct option code for SLI on BMW (8TH), but unfortunately this is not the case for the F45. On the F45 SLI comes only as part of driving assistant (5AS). I assume if you try to VO code all of 5AS without all of the hardware required you will have some issues (to be honest, I never tried).
What do you get?
Current speed limit as detected by camera reading signs, or by GPS location and maps, shown in the instrument cluster and also shown on the HUD (If a HUD is installed). Options in the idrive setting to turn the displays on and off. I believe you also get 'no overtaking restriction shown' in both places as well, but I have not managed to test this yet (hav'nt found the right road yet).
How to import the FSC code?
I used the information posted here (quite easy really):
https://cartechnology.co.uk/showthread.php?tid=29432
What FDL code changes do you need?
I obtained this list by a mixture of: using NCD / CAFD What if tool (on option 5AS); ESYS code verification (with option 5AS); and a bit of educated guess; and a bit of trial and error.
Im not sure if all of these are needed, but they are what I coded with no adverse effects...
On the KAFAS 2 ECU:
<<< CAFD_00001148.caf.000_029_006 (Kafas2) >>>
Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F056
Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F056
On the KOMBI ECU:
<<< CAFD_000009C8.caf.006_004_021 (KOMBI L7_MID) >>>
KOMBI L7_MID > Anzeige_Konfiguration 3000 > SPEED_LIMIT = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv
KOMBI L7_MID > FZG_Ausstattung 3003 > ANZEIGE_NPI = aktiv (Note: I think NPI stands for no passing information)
KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_NPI_ENABLE = aktiv (Note: only needed if HUD fitted)
KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_SLI_ENABLE = aktiv (Note: only needed if HUD fitted)
KOMBI L7_MID > FZG_Ausstattung 3003 > TSM_ENABLE = aktiv
KOMBI L7_MID > PIA_Einheiten 3008 > HUD_PIA_NPI = aktiv (Note: only needed if HUD fitted)
KOMBI L7_MID > PIA_Einheiten 3008 > HUD_PIA_SLI = aktiv (Note: only needed if HUD fitted)
KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv (Note: This was already aktiv for me)
On the Head Unit ECU:
<<< CAFD_00000DED.caf.003_015_037 (HU_NBT) >>>HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv
If anyone can help... one of the FDL settings above mentions TSM and some of the comments in the CAFD files suggests TSM is an alternative to SLI. Does anybody know what TSM might be?
As said above, I hope this helps somebody...
Based in UK.
Drives 2017 F45 Active Tourer 220d
Old 10-01-2019, 11:51 PM
German80 German80 is offline
Mein Auto: BMW F46 218i GT
Hello,
I am trying to code SLI on my car F46,
but seems without unique code FSC it not gonna be work;
Please see the progress of how I did it in pictures and what I get right now:
https://photos.app.goo.gl/uGqmcSsJi7ZU6BsE7
Maybe anyone can help with FSC code or any other guide!
P.S.
As well I am getting an error when I am trying to modify VO and attach to it 8TH
https://photos.app.goo.gl/QrGfRNj42uUXp6Yo6
Old 10-02-2019, 05:50 AM
Originally Posted by German80 View Post
Hello,
P.S.
It's not clear to me. Do you have SLI FSC Code or not?
If 8TH is not valid for a chassis, SLI must be FDL Coded.
And you should enable your PM function too:
"German80 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
Old 10-02-2019, 06:05 AM
Strange seems: Enabled Private Messaging
No I don't have SLI FSC Codes.
I just done coding thru e-sys.
To enable some settings according list I found in this forum.
Old 10-02-2019, 06:10 AM
You cannot code SLI without 7E SLI FSC Code.
And you PM is still disabled.
Old 10-02-2019, 06:23 AM
How to get this code 7E SLI FSC?
Old 10-02-2019, 06:51 AM
I tried to reply to your same PM, but I still get:
Old 10-02-2019, 07:00 AM
Private Messaging all option are marked
Old 10-02-2019, 08:31 AM
Mein Auto:
German80 FSC you will get from https://cartechnology.co.uk
Old 10-02-2019, 08:40 AM
German80 sorry I have not been able to reply earlier. I looked at your photo of your dash and I can see that it is different from mine. Mine has the 5.7 inch black panel display. It looks like yours does not. I am thinking perhaps yours cannot show SLI. I will post a picture of mine later so you can compare. It would be best to be sure your can display SLI before paying for fsc.
Here is a link to a photo of my dash
https://photos.app.goo.gl/yWAmzGFVESGHabxV7
As you can see in the links below there are two instrument clusters for the f46:
part number 62106805182 if you dont have 5AS (driving assist) 610 (Nav) or 6UP (Nav Plus)
http://bmwfans.info/parts-catalog/F4...ent_cluster_2/
part number 62109382087 if you have one of 5AS, 610 or 6UP
http://bmwfans.info/parts-catalog/F4...ument_cluster/
As SLI comes with 5AS I am guessing that you need part number 62109382087 to show SLI (THIS IS ONLY MY GUESS)
I have 6UP which is means I have 62109382087 and can add SLI from 5AS.
My guess is your instrument cluster looks different to mine because you dont have 610 or 6UP hence you have part number 62106805182.
Can anyone else on this forum confirm if they have managed to get SLI working without having 610 or 6UP installed on an F45 or F46 please?
Based in UK.
Old 10-02-2019, 02:32 PM
Damienf45
I have an instrument cluster like in the attached picture.
My navigation option is 6UN.
Old 10-02-2019, 02:59 PM
Ah very good :-) then I say my guess was wrong and your instrument cluster can show SLI.
It seems all you need is now is the fsc code, did you get pm from Shawn yet?
Based in UK.
Old 10-02-2019, 03:04 PM
German80 I am also unable to pm you, can you pm me your email address?
Based in UK.
I don't know but I cannot receive PM in this forum.
I check all settings seems all checked
I guess I need a special code for SLI.
Old 10-02-2019, 03:06 PM
