F45/F46/F48/F55/F56 Coding Thread - Page 3 - Bimmerfest - BMW Forums
Old 07-05-2016, 04:15 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by dmnc02 View Post
. > . 3000 > 3000_31_31_3 = UNK_PARAM_0
. > . 300A > 300A_32_32_255 = aktiv
For 297A mapping, compare to cafd_0000121c (DSC_CT02, FP = F45, F56, I001).
Edit: I am still running comparison but data groups, bytes, positional and storage info is the same if not very similar.
Old 07-05-2016, 06:54 PM
dmnc02's Avatar
dmnc02 dmnc02 is offline
Mein Auto: 2015 M4
Good find: it does look like a close match.
In CAFD_0000121c, 3000_31_31_3 corresponds to C_Funktion_Reifenpannerkennung_Aktiv_e (with literal values nicht_aktiv, RPA and RDC) and 300A_32_32_255 corresponds to QdmRdcDep (with literal values noRDC and isRDC). Clearly, both relate to RDC.
2015 Mineral Grey ///M4 6MT
Old 07-05-2016, 07:13 PM
Almaretto's Avatar
Super Moderator
This trimmed data is a funny thing. I find it strange that an SVT tree clearly has ECU name but not when looking at caf viewer or FDL-editor. Little data redundancy issues.
I had not looked at the RDC parameters yet, but found some matching when looking at fdl's related to 5AV Active Guard. The 3000 functions line up perfectly. The 3009 ones I located by checking storage info.
Old 07-05-2016, 07:26 PM
dmnc02's Avatar
Mein Auto: 2015 M4
The ECU names are not taken from the CAFDs: E-Sys can display the ECU name in the SVT tree even if an ECU has not been coded or has a corrupted CAFD and Rheingold can display the ECU names even with no access to PSdZData. Sometimes a bit of redundancy is helpful.
Old 07-05-2016, 09:17 PM
Almaretto's Avatar
Super Moderator
I know the svt data is pulled from elsewhere, I just find redundancy a breakdown in data integrity. Though, in this case, it is helpful.
I am just trying to figure out from where I can pull the data of ECU names of a dozen unmapped CAFD's if I do not have read and saved SVT with them.
Old 08-22-2016, 12:08 AM
Oakserver Oakserver is offline
Mein Auto: 220d F45
Originally Posted by mekatu View Post
Finally solved my problem and completed cruise control coding. Knowing that information on F45 and F46 is limited on the web I have prepared a DIY Guide for those who want to install the dynamic cruise control on their F45/F46.
Here is the link:
https://www.dropbox.com/s/fln6jgy54m..._Rev0.pdf?dl=0
Hi Mekatu,
I partially used your guide for retrofitting cruise to my F45 Active Tourer. Thanks Mekatu.
My car has the sport auto transmission and therefore flappy paddles to change gear. This meant it was easier to take the steering wheel off. Meant I didn't need to touch the shroud.
The modules you are coding for the F45 are not quite correct which is probably why you needed to code them all to work.
The modules I needed to code after adding 544 into SALAPA were the following:
(Please note I did this with the engine running and you do see a few errors as you progress but don't be alarmed they will be gone when you finish all the coding of the modules below)
SAS
BDC_BODY
BKOMBI
DSC2
HU_ENTRYNAV
Old 08-26-2016, 09:54 PM
witchrobin witchrobin is offline
Mein Auto: X1
Have you tried FDL coding the 297A CAFD? I was able to map the code i am looking for by comparing to the cafd_0000121c as you suggested. Wasn't sure if it would be safe to code with this "funny trimmed function" as someone else mentioned.
Thanks.
Old 08-26-2016, 10:27 PM
Almaretto's Avatar
Super Moderator
Thanks.
I have not FDL-coded 297A. I successfully coded HVAC memory settings in unmapped IHKA2 (CAFD_000047D6) using IHKA (CAFD_00000092).
Old 08-27-2016, 08:23 AM
Mein Auto: X1
I am having problem saving after the FDL edit. I was using esys 3.26 + 57.3 psdzdata. Tried upgrading to 3.27 + 59.3 but still same error.
Any idea?
Thanks.
Old 08-27-2016, 08:46 AM
Almaretto's Avatar
Super Moderator
Any idea?
Thanks.
Changing psdzdata is unlikely to solve anything except caf not found errors.
What are you specifically editing? This error occurs when you select save icon in fdl-editor or code fdl?
Old 08-28-2016, 09:09 AM
Mein Auto: X1
I am trying to code the LIM feature https://www.bimmerfest.com/forums/sho...d.php?t=669435
Yes, the error occurs when i click on the save icon in the fdl editor after making the change.
I installed e-sys on a Win7 VM on my Mac and it seems to save properly.
So there much be something up with my Windows 7 laptop that's giving me the error. It's weird that other ECUs like kombi, bdc, seem save properly. I have tried uninstalling and reinstalling esys multiple times. I'll see if i can find another laptop to try this out.
Old 08-28-2016, 08:49 PM
Almaretto's Avatar
Super Moderator
Are you setting the following?:
  • DSC2 (CAFD_0000297A)
    • 3009_6_6_255: aktiv
    • 3009_24_24_255: aktiv
  • KOMBI (CAFD_000009C8)
    • SLD_ENABLE: aktiv
On a set of EU F48 NCD's, of those, I only had to change 3009_6_6_255; but, was able to save without error. You can PM me your troublesome NCD and I can see if I have trouble changing.
Old 08-29-2016, 11:05 AM
Mein Auto: X1
    • SLD_ENABLE: aktiv
Yes, those are the exact changes i was try to make from the DSC2 module. Neither 3009_6_6_255 or 3009_24_24_255 allowed me to save, but the problem has been solved now.
I upgraded e-sys launcher from 2.4.3 to 2.5.3 for another feature (unlock after engine off) cause it wasn't mapped in 2.4.3. After upgrading I can also save the 297A NCD without error.
Thanks for your help.
I have another question you may know. I coded the feature to enable rear-view camera at all speeds.
PCD Module:
300B->D_SCHWELLE_1_KMH set to: Werte = FF
300B->D_SCHWELLE_2_KMH set to: Werte = FF
300B->V_SCHWELLE_1_KMH set to: Werte = FF
300B->V_SCHWELLE_2_KMH set to: Werte = FF
This gives me the option to turn on rear view when i need at any speed, but the down side is after going from reverse gear to drive, the review camera no longer automatically shuts off. Do you know if I can play with the 2 thresholds that will allow auto shut off of camera when going from reverse to drive, but still allow me to turn on the rear view manually during faster forward speed?
Thanks again.
Old 08-29-2016, 11:46 AM
Almaretto's Avatar
Super Moderator
PCD Module:
Thanks again.
You are welcome.
Re Cameras: I do not. I just know there are limitations when raising auto-shut off for velocity (255 km/h) and distance (255 m) on top/rear/side cameras. I have coded these for others, but never understood the desire for cameras in motion; as such, I never looked further into these parameters.
Old 08-29-2016, 08:12 PM
Mein Auto: X1
You are welcome.
I thought it could be something useful, but I guess it's more of a distraction to have to manually turn off the rear view when switching gear from R->D. Probably will code it back. I did noticed that after moving forward for about a min (didn't time exactly) the camera does turn off.
Old 08-29-2016, 09:17 PM
Almaretto's Avatar
Super Moderator
The coding is separated by camera (side vs top vs rear), with two parameters each for distance and velocity. You could code back or play with the wertes. Find what works for you.
Each cars layout is a little different. I find the F10 to have the best; I am able to select all the individual switches in center (eg, media, communication, PDC, etc) without looking. On my F15, I tend to look more.
Old 09-03-2016, 11:10 PM
Cothy Cothy is offline
Mein Auto: F46
Hello,
I have a F46 from 07/2016.
I want to retrofit SLI (8TH) but Esys can not modify FA.
I understand that 8TH is no valid salapa for F46.
I have the 7E FSC for Kafas2.
Now i want to do FDL Coding.
Can someone help me witch ECU I have to code and how?
Old 09-04-2016, 01:26 AM
Almaretto's Avatar
Super Moderator
Originally Posted by Cothy View Post
Hello,
The F045 FA2FP table contains 8TD Decoding Speed Limit Info. You may be able to use TM's NCD / CAFD tool to determine what to FDL code. On an F48, it affects BDC, KAFAS2, DSC2, Kombi, and HU_NBT.
Old 09-05-2016, 11:50 AM
Mein Auto: F46
8TD is to deactivate 8TH (SLI) in countrys where it isn't allowed.
I am locking for a way to retrofit 8TH to my F46 but till now i couldn't find help.
Thanks anyway.
Old 09-05-2016, 12:26 PM
Almaretto's Avatar
Super Moderator
Thanks anyway.
I know. I was suggesting to use the deactivate code to give you way to FDL code opposite of 8TD.
Old 09-13-2016, 02:38 AM
MrTracey MrTracey is offline
Mein Auto: F48 X1 Xdrive20i M-Sport
Can't change comfort blink from 3 flashes
Hi,
I have a 2016 X1 (F48, July 2016 build). I've successfully coded a few things (6NS, Auto stop-start memory, door mirror fold delay = 0 on lock, etc) BUT...
I wanted to change the "comfort turn-signal blink" from 3 blinks to 4.
I went to BDC_BODY, 3068, BLINKZYKLEN_ANZAHL_TIPP expecting to change the 'werte' from 2 to 3...but it was 00 ??
Well, I went ahead and changed it to 03 (for 4 blinks) anyway, confirmed the change was saved, coded it, but still only 3 blinks. I'm a bit baffled - I guess the parameter I need to change must be something else..but what? where? Any ideas?
BTW, I'm using E-Sys v.3.27.1 with v.59.3_PSdZData (selecting F056 when connecting to the car).
Annoyingly, I did this a couple of years ago with no problems on my previous car (M135i).
Old 10-02-2016, 05:21 AM
Mein Auto: F46
Got SLI and NPI work on a F46.
Upgraded FSC 007E to Kafas and FDL coded Kafas and Kombi.
http://www.directupload.net/file/d/4...743tdi_jpg.htm
Old 10-02-2016, 12:23 PM
Maxym Maxym is offline
Mein Auto: F48
Hi,
today I want to code my F48! (03/2016)
But I can not read out the ECUs with the VCM button in E-Sys.
If i try it to read it with the VCM Button it comes an Error, only with the ECU Buttom it run.
But he finds only two ECU,s and only one cafd to code.
What make i wrong?
Software: Win7 64bit, e-sys launcher 2.5.3.108, e-sys 3.27.1, PsdZData 59.4
Sorry for the bad english
Thanks Maxym
Old 10-02-2016, 12:52 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by Maxym View Post
Hi,
What make i wrong?
Thanks Maxym
Nothing. For F48, you are supposed to use Read ECU, not Read SVT.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 10-02-2016, 01:04 PM
Mein Auto: F48
Ok, thanks
But why he found only two ECU,s
