F45/F46/F48/F55/F56 Coding Thread - Page 5 - Bimmerfest - BMW Forums
Old 10-30-2016, 08:26 AM
fjsato fjsato is offline
Mein Auto: Mini Cooper JCW F56 Moon
Hi experts. Need help:
I've done theses two codes:
IHKA Module:
A/C System Remembers Last Setting
3003==>MEMORY_OFF set to aktiv-werte=01
Always Remember Air ReCirculating
3003==>MEMORY_UMLUFT set to: aktiv
And now I can not turn off the A/C. I already undone, but the A/C stilll on, without the possibility to turn off.
Someone passed for something like this?
Mini Cooper S 2010 R56 Volcanic Red
Mini Cooper S 2016 F56 Eletric Blue
Mini Cooper JCW 2018 F56 Moonwalker Gray
Old 10-31-2016, 12:17 PM
mateforrest mateforrest is offline
Mein Auto: BMW F16 3.0D & mini F54
Originally Posted by Roonster View Post
Fore sure, I will help you as soon as I have my Coding PC back up and running.
Could you be more specific? Do you mean only KAFAS2 or in general? It depends very much on the VO of the car. Do you have a list (SVT list) with all ECU's?
Roonster, Shanwn in the picture is the list of my ecuīs please help me.
Anyway, if i buy a Control module for the KAfas with the speed limit info activated, should i need the fsc code too? can i use the old fsc code inside the old used control unit ? regards
Name:	Captura de pantalla 2016-10-31 a las 20.08.37.png
Old 10-31-2016, 12:22 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
You cannot use a Used KAFAS ECU with Donor FSC Codes. There is no Emulator for it, nor any known way to make virgin and use a different set of FSC Codes. And even if so, this would coast you more than just getting an FSC Code for current KAFAS ECU.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 10-31-2016, 01:47 PM
matteis matteis is offline
Mein Auto: F20 - 118i Sport GP 2013
IHKA Module:
Try to Vo Code IHKA (the entire folder, not CAFD file itself).
Right click on IHKA folder > Code.
Old 10-31-2016, 01:52 PM
Roonster Roonster is offline
Mein Auto: MINI F54 S & SD All4
It's not a bug, it's a feature. It is a protection feature for the climate compressor after coding the IHKA. Let the engine and the climate control run for at least 2o minutes an everything will went back to normal.
IHKA Module:
Old 10-31-2016, 03:24 PM
Almaretto's Avatar
Almaretto Almaretto is online now
Super Moderator
Mein Auto: Test Vehicles
Is this a new protection or unique to certain chassis? Every time I have coded HVAC settings, they have worked immediately.
Old 11-01-2016, 12:03 AM
Hello Roonster,
please do you recover the back up of your computer?
i need your help for my f54 coding.
thanks
Old 11-03-2016, 02:10 PM
Any new information ?
Old 11-04-2016, 01:03 PM
ck21 ck21 is offline
Mein Auto: x1
Coding F48
Hi everyone,
I am totally new in coding BMWs. I have experience in coding VAG (VW,Audi,Seat,Skoda) cars, but BMW has different approach. Here are some of the things I would like to change/re-code:
1. Extended Bluetooth 6NS. I read somewhere in this forum, after enabling 6NS the voice control is still not available. Is that correct??
2. Is it possible to keep the lights off when the switch is in "0" position? As you probably know, even in "0" position the lights go on when it is dark. I find this very annoying when I reverse out of my garage (which is dark) while outside it is totally bright.
3. Is there a way to mirror the cellphone screen on the CID screen? I have a Samsung phone.
Can I read / erase fault codes with E-sys software?
Thank in advance
Old 11-04-2016, 01:09 PM
Almaretto's Avatar
Super Moderator
Originally Posted by ck21 View Post
Hi everyone,
Thank in advance
1. Voice Control requires FSC Activation Code.
2. You can adjust headlight sensitivity, that may help with the issue.
3. Not unless you have idrive5 for MiraCast or retrofit something like Bimmertech SmartView.
Old 11-05-2016, 04:58 PM
Saeger Saeger is offline
Mein Auto: X1 sDrive20i GP ActFlex
Link doesn't work
Old 11-05-2016, 05:47 PM
Almaretto's Avatar
Super Moderator
Originally Posted by Saeger View Post
Link doesn't work
What link?
Old 11-07-2016, 06:09 AM
Mein Auto: x1
Ok it doesnt sound very promising though... It's a pity that BMW in the year 2016 does not offer voice commands and screen mirroring of smartphones as standard
Anyway,
Where can you get the FSC code?
What about reading / clearing ECU fault codes? What software would I need?
Old 11-07-2016, 06:11 AM
Anyway,
PM sent for FSC Code source.
You can clear faults with E-Sys Transmitter.
Old 11-08-2016, 05:33 AM
mii007ab mii007ab is offline
Mein Auto: 318d
Hi Shawn, could you also send me the FSC Code Source?
Thanks in advance
Old 11-08-2016, 05:34 AM
Thanks in advance
PM sent.
Old 11-09-2016, 02:40 PM
Shawn, Roonster please i need your help and opinion.
I just retrofited to my Mini the automatic folding exterior mirrors.
As my Mini has memory seats i have LIN line to the mirrors , so is near plug and play.
I changed the mirrors, changed the control button in driverīs door , with the folding button, and finally adding 313 to VO and coded ONLY the BCD_BODY unit.
Ok , it works fine and perfectly, but i have a problem since retrofit.
The automatic close and open of the FRONT WINDOWS when hold the open or close button of the key doesn't works. Itīs very strange because the rear window , and the Panorama Glass Roof works fine ,THE EXTERIOR MIRRORS FOLDing PERFECTLY, the faliure is only in the front windows.
My car has also confort access and the door button holding does the same result, only works the rear door windows and the panorama roof.
Obviously before the retrofit this feature worked ok.
What do you think?
Should i code any more unit?
Please any advice or opinion is welcome.
Old 11-09-2016, 03:39 PM
Sorry, but I have no idea. I have never even coded an F5x car before. I really don't know anything about them.
Old 11-12-2016, 01:54 AM
What link?
Almaretto you are to a code master, please could you help me ?
Regards
Old 11-13-2016, 01:34 AM
Almaretto's Avatar
Super Moderator
Regards
I would check car with ISTA+.
Old 11-13-2016, 03:53 AM
Cothy Cothy is offline
Mein Auto: F46
Hello, is the initialization of the Windows ok? Does auto up work when you normally close the window by the interior window buttons?
Old 11-13-2016, 09:22 AM
Thanks, all you are right.
I erased the errors in the BCD unit and then made an initialization and now works fine
Old 11-13-2016, 09:33 AM
Now i want to activate the pedestrian detection as Roonster confirm the possibility.
Please any help?
take look to the options.
Name:	Captura de pantalla 2016-11-13 a las 10.36.07.png
ID:	581765   Click image for larger version
Name:	Captura de pantalla 2016-11-13 a las 10.35.58.png
Old 11-23-2016, 11:28 PM
kentonchen kentonchen is offline
Mein Auto: mini f56
F56s can enable the "2TB Steptronic Sport transmission" by the e-sys?
Old 11-24-2016, 12:48 AM
Almaretto's Avatar
Super Moderator
2TB is a valid option code for an F56.
