BMW MRS Error after Coding - Page 2 - Bimmerfest - BMW Forums
Old 09-12-2019, 05:11 AM
sakmoon1 sakmoon1 is offline
Mein Auto:
[QUOTE=tafikhulafa;13102233]You can try to code your ABG (Airbag) module with ncsexpert:
Here's the step by step
1. Load expertmode profile
2. Choose F3, it should be ZCS/FA/.. button thingy
3. Choose your chassis
4. Read ECU and choose the ABG Module
5. Change job to SG CODIEREN
6. And execute job
Voila!
I can help you via teamviewer if you need further assistance
Greeting and Peace... Thanks Really appreciate it,
I think something is going on with my BMW tools probably SP Daten files is not complete or something I really don't know, when I press F2 to Read ECU it gives internal error
I tried but it did not worked gave error while reading ECU ( Internal Error)
(CSget::SetActSg 2)
I don't know did you ask me to make NCS expert to read All ECU module or only CAS?
anyway its not reading all module at same time you can check pictures I attached.
Again My problem is System time is the issue ERROR_ECU_SERVICE_ NOT_SUPPORTED with code VIRTS90, VIRTS91 and VIRTS92 also don't know these are codes or module? because INPA is showing as modules these as VIRTS90, VIRTS91 and VIRTS92 with ERROR_ECU_SERVICE_ NOT_SUPPORTED
ID:	864349   Click image for larger version
ID:	864351   Click image for larger version
Old 09-12-2019, 05:27 AM
tafikhulafa tafikhulafa is offline
Mein Auto: E39 530i
[QUOTE=sakmoon1;13104079]
6. And execute job
Voila!
(CSget::SetActSg 2)
Send me your TV Id, iíll assist you directly
Old 09-20-2019, 12:17 PM
Mein Auto:
[QUOTE=tafikhulafa;13104091][QUOTE=sakmoon1;13104079]
Greetings and Peace !
Thanks dear for your help
I solve AIRBAG light using your way as you told me but I had to flash ABG Module first with winkfp then I use Ncs expert, really grateful to you Thank you . But still I have something remaining issues that is Error_ECU_SERVICE_NOT_SUPPORTED VIRTSG90-92 Also can't understand what is that can you help please.
Old 09-20-2019, 12:32 PM
Mein Auto:
Send me your TV Id, i'll assist you directly
