All BMWs Beginner's Guide to BMW ISTA+ - Page 3 - Bimmerfest - BMW Forums
Old 02-21-2017, 08:01 AM
Reclaimer's Avatar
Reclaimer Reclaimer is offline
Mein Auto: 2012 E84 x28i
Look in the tools folder.
She said that to me once... about being a machine.
Old 02-21-2017, 08:02 AM
Almaretto's Avatar
Almaretto Almaretto is online now
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by OldE39 View Post
You are right, I didn't install the prerequisite software, but it's not there in the download link:
If not in Tools folder, you can always download some directly from manufacturer. Install vcredist x64 & x86 through 2015.
Old 02-21-2017, 08:10 AM
OldE39 OldE39 is offline
Mein Auto: 1999 528i
Ok, I followed the installation guide PDF I downloaded. I think the prerequisite is in the tools folder. I did install everything needed in the tools folder.
Old 02-21-2017, 08:12 AM
Reclaimer's Avatar
And? Did it work or you still have the same error?
Old 02-21-2017, 08:38 AM
Originally Posted by Almaretto View Post
Make sure you installed all prerequisite software.
Ok, I just got it work! I need to install both the 32 and 64 bit vc_redist.exe!
Thank you so much, Reclaimer and everyone!
Old 03-02-2017, 07:35 PM
circiusorin circiusorin is offline
Mein Auto: 325xi e90
hey everyone....i have win7 x86 and cannot seem to make it work .... program stopped working ... problem event name clr20r3... i did all the steps i have it in two directories d and c ... both directories do the same thing ... the exact same error ... i followed the steps inside ... the only thing i couldnt install was redist x64... any hints ? thanks.
Old 03-02-2017, 10:04 PM
Reclaimer's Avatar
Problem seems to be with your OS, you can try and repair .NET or attempt some service and registry fixes. Google the error, there's a lot of discussion around it.
Old 03-02-2017, 10:07 PM
Thanks for the reply...i tried to google it ... but the topics i found were not exactly for the ista...they are for something else...i just erased all and starting again...hope to sort it out . Cheers
Trimis de pe al meu SM-G925F folosind Tapatalk
Old 03-02-2017, 10:10 PM
Also this freaking error... any hint ? The cable works fine
Old 03-02-2017, 10:19 PM
Reclaimer's Avatar
It's not an ISTA specific error, it's a Microsoft issue. It can affect any application. You can get an idea of what to do here:
http://techdracula.com/fix-program-h...-name-clr20r3/
Old 03-02-2017, 10:20 PM
Reclaimer's Avatar
As long as your cable works, you can ignore it.
Old 03-02-2017, 10:32 PM
Now i cannot install vcredist... uhh sighs
Old 03-02-2017, 10:33 PM
Reclaimer's Avatar
Switch to a different Windows version, try 10 x64.
Old 03-02-2017, 11:37 PM
The error was because my win7 was not sp1... i stopped updates when i first installed windows...so in order to succesfully install .net and c++ specified versions you need windows 7 with sp1 update.
Old 03-21-2017, 11:29 AM
Andy193 Andy193 is offline
Mein Auto: 2001 BMW E46 318i Sedan
Originally Posted by Andy193 View Post
Hi,
When I try to do a complete identification of the car the Error message appears: The vehicle could not be identified. Please check the access to the vehicle and check whether the testing-analysis-diagnosis has been activated.
BMW E46 2001 318i
K+DCAN silver cable (no physical switch)
ISTA works fine if I use the VIN tab or Basic Features tab under Operations
Ignition on > connect cable from laptop to car > start ISTA > Settings > VCI Config > Ediabas > Operations > Read Out Vehicle Data > Complete Identification > Error message
Any ideas? Please help!
Thank you!
The problem with the error was the cable that I purchased on ebay for 12. I was advised to purchase a quality cable and I found one on one-stop-electronics for $99 ( http://www.one-stop-electronics.com/...&product_id=16 ). Also make sure to use the male to female interface adapter if your car is <2006 and requires K-CAN communication.
Thank you Reclaimer!
Old 03-21-2017, 11:47 AM
Reclaimer's Avatar
Old 03-26-2017, 05:26 AM
Ninio Ninio is offline
Mein Auto: BMW E60
Hello, I have the following issue. When i try to read Vehicle data I g***1077;t error NET-0015: HOST NOT FOUND. I change port numbers from both EDIABAS.INI folders and the result is the same, also K + DCAN cable is ok I use it with BMWCarly and works fine for me.
Old 03-26-2017, 07:52 AM
Reclaimer's Avatar
Edit the EDIABAS.ini in ~\Rheingold\Ediabas\BIN folder and change INTERFACE to STD:OBD and try again. It has to match what you have in C:\EDIABAS. There is no port configuration needed for K+DCAN, not sure what ports you changed.
Old 03-26-2017, 08:09 AM
Mein Auto: BMW E60
I follow the steps from GUIDE TO ISTA+ pdf
Old 03-26-2017, 08:11 AM
Reclaimer's Avatar
Did you try changing the interface in the Rheingold EDIABAS folder?
Old 03-26-2017, 09:01 AM
Mein Auto: BMW E60
Sorry for the question, but what do you mean with that ? Maybe to set port 6801 just like in C EDIBAS ?
Old 03-26-2017, 09:30 AM
Reclaimer's Avatar
In the Rheingold EDIABAS ini file, it should look like this at the beginning:
Code:
;# EDIABAS 7.3.0 #
[Configuration]
Interface        = STD:OBD
#Interface	     = STD:PASSTHRUD
#Interface      = REMOTE
For your K+DCAN, make sure that the Interface above is the same (STD:OBD).
Old 03-26-2017, 09:56 AM
Mein Auto: BMW E60
Code:
;# EDIABAS 7.3.0 #
[Configuration]
Interface        = STD:OBD
#Interface      = REMOTE
;# EDIABAS 7.3.0 #
[Configuration]
Interface = STD:OBD
Simulation = 0
EcuPath = C:\EDIABAS\ECU
SimulationPath = C:\EDIABAS\SIM
TracePath = C:\Windows\Temp
TraceSize = 1024
Maybe it's something with the ports idk I set it to COM9 just like in your thread.
Old 03-29-2017, 12:01 PM
aurashku aurashku is offline
Mein Auto: 318dA e90
it worked for me. Thanks!
Old 03-29-2017, 12:50 PM
drastic25 drastic25 is offline
Mein Auto: 328i
quick stupid question, i have ista+ on my computer connected to my 2014 f02 trying to program my driver led xenon headlight it say encode in ista+, i can get it the headlight learn and stay on using ista+ but when i shut off the car it don't stay on. Do i need to recode or re vin it, if so how is it done using ista+...btw it a mint used headlight i know it work because when i run the learning process on ista+ everything work led, halo's, blinker and low high beam.
diagnostics, ista+, procedure, programming, repair, rheingold
