All BMWs Beginner's Guide to BMW ISTA+ - Page 33 - Bimmerfest - BMW Forums
Old 07-26-2019, 12:05 PM
TonyM530 TonyM530 is offline
Mein Auto:
Originally Posted by larobs View Post
I am having issues connecting to my e65. Ista+ opens, I can enter vin manually and use ista for repair instructions and wiring diagrams. But when I try to connect I get :
"The vehicle could not be identified. Please check the access to the vehicle and check whether the tester-analysis-diagnosis has been activated."
I am using k+dcan. I followed instructions in guide, using device manager, set to com9.
checked/changed code for the following:
C:\EDIABAS\Bin\EDIABAS.INI
C:\EDIABAS\Bin\OBD.INI
even tried:
C:\Rheingold\Rheingold\Ediabas\BIN\EDIABAS.INI
I noticed that if I change port setting to com1 and use inpa, I can connect. I get errors but can still read faults. Works but not perfect. So that leads me to believe the k+dcan cable is working properly.
Is there a recommended procedure to reinstall? Or any tips/tricks I can try? I want to try everything I can before I remove all files and reinstall.
Hi everyone!
I have absolutely the same issue.
I did install Insta+ from this thread.
Everything went smooth, no problems with installation...
Did scan and clear codes.
Got back to insta within a month and a half and right away got "The vehicle could not be identified. Please check the access to the vehicle and check whether the tester-analysis-diagnosis has been activated."
Re-installation didn't help, getting same error.
Did switch ports from COM9 to COM1 - got connected, able to read codes BUT cannot complete Fault memory delete. Literally getting stuck when system asks to turn off the ignition and take the key off - after doing that nothing really go further of the screen with "take out the key" and cancel button.
Clicking cancel button I guess, cancelling memory fault delete.
Procedure logs says: memory fault delete completed normal, but it shows 0:00 count timer spent on it.
Any help is appreciated, yesterday got Transmission malfunction in traffic with 4e22 and 2ad0 codes popping up.
Old 08-22-2019, 12:07 PM
ERINRONELL ERINRONELL is offline
Mein Auto: 550I
Originally Posted by Almaretto View Post
That error occurs when you have programming enabled but do not have matching data_swi (AKA SDP or Service Data) & registry entries.
It can still be use for diagnostics as well as performing procedures like registering battery.
For programming, you need additional files and ICOM. Alternatively, you can with E-sys and ENET.
Almaretto,
I have ISTA+ 4.10 and have been using ISTA generally since it first came out but only for diagnostics.
I want to enable programming but the necessary steps to do so are not clear. I've scoured the various threads but I'm not confident with what I've found, thus I resort to asking for specific assistance, please.
What Ive done so far: Created a folder called "data_swi" and placed it here: C: Rheingold/PSdz/ I then downloaded Psdzdata full and put it in the folder that I created.
Not sure what to do from here.
I attach screenshots of my registry and program folders.
Your guidance is greatly appreciated.
ID:	861985   Click image for larger version
ID:	861987   Click image for larger version
Old 08-22-2019, 11:59 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by ERINRONELL View Post
Almaretto,
You are missing entries. Make sure you have corresponding registry entries for whatever version you have.
***91; should be [
***93; should be ]
PHP Code:
Windows Registry Editor Version 5.00
***91;HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\BMWGroup\ISPI\ISTA***93;
"ProductVersion"="4.18.32.18637"
"MainProductVersion"
="4.18"
"DataVersion"
="4.18.30"
"DataVersion_en-GB"
="4.18.30"
"LogisticBaseVersion"
="4.18.33"
"SWIData"
="4.18.33"
ID:	862013   Click image for larger version
Old 08-27-2019, 09:22 AM
Dfhii Dfhii is offline
Mein Auto: 2009 535i XDrive
Currently Downloading INSTA-D, Since I have an E60 do i need the SDP&BLP files for the install? I was told they're for Series other than my model. Will it corrupt the install without them? Also a Language question... Do i need all lang files included if i just want to install for english?
Old 08-29-2019, 07:16 PM
Mein Auto: 550I
***91; should be [
***93; should be ]
PHP Code:
="4.18"
"DataVersion"
="4.18.30"
"DataVersion_en-GB"
="4.18.30"
="4.18.33"
"SWIData"
="4.18.33"
Thanks, Im still a bit lost.
Any idea on where I can get a version of ISTA+ 4.18.
My version of psdzdata full is 14.18.33.
Old 08-29-2019, 07:32 PM
Almaretto's Avatar
Super Moderator
Cartechnology.
diagnostics, ista+, procedure, programming, repair, rheingold
