Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links - Page 3 - Bimmerfest - BMW Forums
Old 09-05-2017, 10:08 AM
DietCokeOfEvil DietCokeOfEvil is offline
Mein Auto: 2013 BMW M5
Does the E-Sys / launcher author usually reply pretty quick with an activation code?
Old 09-05-2017, 10:12 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Sometimes it is fast, and sometimes, not so much.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-06-2017, 04:06 AM
lalamper lalamper is offline
Mein Auto: F20, 116i, 2013
Update: I got it from the first post.. Sorry, my fault.
But what about Esys 3.27.1 and PSdZData 3.62.4 compatibility? Are they friends?
And what about mapping of latest PSdZData 3.62.4 with Premium 2.7.1_build135? According to the changelog of Esys Launcher, it was recently (at v2.6.0 build 128) upgraded to support only up to V3.59.4... There are no more information about newest PSdZData compatibility...
Hi Shawn,
Could you please send me the link for latest stuff for coding?
My car got updated by the dealer, all my codings lost..
Old 09-06-2017, 07:03 AM
Hi Shawn,
E-Sys 3.27.1 works with latest 62.4 PSdZData, and remains the preferred version.
PM sent.
Old 09-06-2017, 07:38 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Currently, mapping is only an issue for some G-series ECU's.
Old 09-09-2017, 03:29 PM
Yeaham Yeaham is offline
Mein Auto: Mini F56
My mini F56 was recently dealer ECU updated and all my previous settings erased. I updated the psdzdata to support the new I Stop version, but I cant seem to find any of the same settings in the ASCM or BDC sections still. Am I missing a CADF file still? Any help appreciated.
Thanks,
Old 09-09-2017, 03:43 PM
Thanks,
If you can read ECU, then you are not missing any CAFD. Make sure you are using latest E-Sys Launcher.
Old 09-09-2017, 04:54 PM
Almaretto's Avatar
Super Moderator
Thanks,
What is the name of ASCM and BDC (CAFD_0000WZYZ_###_###_###)?
Old 09-10-2017, 06:11 AM
Mein Auto: Mini F56
I'm using E-Sys 3.27.1 with launcher premium v2.7.1
I was looking under ACSM2 (there is no other ACSM listed) and it has the following CAFDs:
CAFD_000011AB_007_001_007
CAFD_000011AC_007_000_007
CAFD_000011AD_004_001_010
I was looking in the first CAFD (11AB), but then looked through all them. I'm basically trying to find where the 3000 Initialwarnung and 3000 SeatBeltReminder_xxx settings went. I cant find them. Did they move?
Thanks again for the help
Old 09-10-2017, 06:40 AM
Do you see anything other than dots (.)?
CAFD_000011AB_007_001_007 is Trimmed in Launcher PREMIUM.
Old 09-10-2017, 07:15 AM
Mein Auto: Mini F56
Sorry but i'm confused by that question.
I can "Edit" the FDL under that CAFD (11AB) and open to see the Funktionen listing (ZUENDKRIEIS_XX, and a few other settings), just cant find the ones I'm looking for (search finds no existence of them). Do I need the untrimmed CAFD? Before the ECU update at the dealer I used Esys Launcher 2.4.3 with an earlier psdzdata that was supporting my I-Step then and I found those parameters in those areas with no problem. Does the new version of launcher trim it differently than last time?
Old 09-10-2017, 07:28 AM
Disregard Trimmed part. I had to change Launcher PREMIUM Car Series to F056 to get invoke the Mapping; however, in looking at it, it appears this CAFD is not being mapped correctly.
Old 09-10-2017, 07:58 AM
Mein Auto: Mini F56
Oh interesting, been a year since I've used the tools, but thought it was much easier to find the parameters I was looking for.
So is this mis-mapping a function of the E-sys tool itself?
Old 09-10-2017, 08:06 AM
...So is this mis-mapping a function of the E-sys tool itself?
Yes.
Old 09-10-2017, 08:17 AM
Mein Auto: Mini F56
Will a newer version of E-sys help? Though I guess its a matter of what the latest E-sys launcher supports as well since I cant make any changes unless it does.
Thanks,
Old 09-10-2017, 08:51 AM
Thanks,
No. It has nothing to do with E-Sys. The CAFD Mapping Database is builtin E-Sys Launcher.
Old 09-10-2017, 08:55 AM
Mein Auto: Mini F56
Ah, ok. So I'm assuming I'm dead in the water then, or at least until an updated E-Sys Launcher addresses it.
Thanks for explaining and looking into it.
Old 09-10-2017, 09:18 AM
Yes.
Old 09-10-2017, 09:40 AM
Mein Auto: Mini F56
Well that's unfortunate. Would the older version of E-Sys (3.24) and E-Sys launcher (2.4.3) work the latest psdzdata? Ie: could those solve the mapping issue?
Old 09-10-2017, 09:42 AM
No. I already confirmed you are "dead in the water", until new version of Launcher PREMIUM is released that has an updated CAFD Mapping Database. Why you are asking now about older E-Sys and older E-Sys Launcher escapes me.
Old 09-10-2017, 09:57 AM
Mein Auto: Mini F56
Desperation
Question is because it seemed to map those parameters before in the previous version as I was able to find and change those settings. Wasnt sure it was a function of the just the updated launcher or all of the above (new ISTA-P with I-Level, new E-sys, new E-sys launcher). That's all.
Old 09-10-2017, 10:00 AM
Desperation
ECU has new CAFD, and it must be added to CAFD Mapping Database. Mapping of old CAFD is irrelevant.
Old 09-10-2017, 10:04 AM
Almaretto's Avatar
Super Moderator
No. You can accomplish the same with VO coding.
Old 09-10-2017, 10:24 AM
Mein Auto: Mini F56
I'll have to look out how to accomplish it that way then....
Thanks for all the responses...
Old 09-11-2017, 04:10 PM
997usa 997usa is offline
Mein Auto: 2015 M4 Convertible
hi guys, i came from an F10 M5 and an F83 M4; Now a G12 B7 which has a COMPLETELY different CAFD naming convention... Any good G11/G12 cheat sheets out here?
Current:
2018 BMW B7 Alpina
2017 Ferrari 488
2015 Volkswagen GTI
2015 Cadillac Escalade
Former:
2016 Porsche 911 Turbo
2015 BMW M4 Convertible
2014 Ferrari 458
2014 Jeep Grand Cherokee Overland
2014 Volkswagen GTi
2013 Maserati Gran Turismo
2013 Porsche Carrera S
2013 BMW F10 M5
2012 BMW F01 740i
2013 BMW X5 3.5D
2011 Porsche Carrera 4s
2009 Range Rover Sport
2009 Mercedes SL500
2007 Porsche Carrera
2005 BMW Z4
2003 BMW 318Ci
