Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links - Page 4 - Bimmerfest - BMW Forums
Old 09-11-2017, 05:12 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by 997usa View Post
hi guys, i came from an F10 M5 and an F83 M4; Now a G12 B7 which has a COMPLETELY different CAFD naming convention... Any good G11/G12 cheat sheets out here?
No. Cheat Sheets are no longer made. Instead, most write Launcher Codes.
Old 09-12-2017, 01:16 PM
kopernik kopernik is offline
Mein Auto: F25 X3 28i 2016
Very please for the latest psdzdata files for e-sys!
Thanks in advance!
Old 09-12-2017, 01:20 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Thanks in advance!
What is wrong with links in Post # 1?
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-14-2017, 02:11 PM
Mullins Mullins is offline
Mein Auto: M235i Estoril Blue
Howdy, I had my cluster replaced in my F22 and lost all my coding data. I'm trying to get back into reset all my settings but my FXX token i bought several years ago is expired (no surprise). It looks like this launcher premium tool replaces a need to buy another token, but it's asking for an activation code. I did shoot the code off to Token to see if he can generate one. Is that the right way to go about this? Wasn't sure if there was something I missed when trying to generate a new EST file. Any help would be awesome!
Old 09-14-2017, 02:29 PM
Almaretto's Avatar
Super Moderator
You should not need Activation code in Fremont unless you are using VM or have non English computer settings. Yes, email is the way to go, but new codes are on temporary hold until new Launcher release.
Old 09-14-2017, 02:32 PM
Originally Posted by Almaretto View Post
You should not need Activation code in fremont unless you are using VM or have non English computer settings. Yes, email is the way to go, but new codes are on temporary hold until new Launcher release.
Dang, ok. Yeah I'm using a VM so that would explain it I guess. Hope to get something soon, as I forgot how annoying some of these stock settings were after 3 years of a coded car!
Old 09-22-2017, 05:33 AM
arjunbts arjunbts is offline
Ford pro
Mein Auto: ford figo
Basic coding language
I think Bmw use basic C for their coding language. Is any framework available for it?. in basic electric cars currently we using c for basic controls. for that detailed coding sas training in chennai
Old 10-09-2017, 06:51 AM
biosdi biosdi is offline
Mein Auto: BMW F36 420d MSport
Hi guys. Following instruction on page 1, at point .09, I run E-Sys Launcher Premium, but it doesn't appear any PIN field, but appears a windows where I should enter the activation code (or I should require it...)
What's wrong?
Old 10-09-2017, 12:29 PM
Almaretto's Avatar
Super Moderator
What's wrong?
Certain regions require an activation code. You must contact developer directly via email to acquire.
Old 10-11-2017, 12:05 PM
cris 335imodern cris 335imodern is offline
Mein Auto: 335i modern f30
i just get my first BMW 335i modern line, I need to add the Sport+ functions and others to my car, can some one explain how to do it and which connector and software use for this.... and also if some one add paddle shift to this car, my donsent have it.....
Old 10-11-2017, 12:20 PM
Asked and answered:
https://www.bimmerfest.com/forums/sho...ostcount=13102
Old 10-13-2017, 05:37 PM
coolpix99 coolpix99 is offline
Mein Auto: 430i Coupe
Need some help here.
I couldn't proceed further trying to generate token with E-Sys Launcher Premium V2.7.1.135. So after entering the PIN + Confirm and I hit 'Generate Token' at the EST Software Token page , the message
"EST Software Token Successfully. Press OK to continue" appears and after clicking OK, it then would return to the EST Software Token page. This keeps going on an would not proceed anywhere further. Please advise.
Also, FreeToken.est did not get created after the above attempt and it does not launch E-Sys software either
Old 10-14-2017, 12:31 PM
Joe Derry Joe Derry is offline
Mein Auto:
My 2008 BMW X5 went into limp mode and can't figure out what is wrong with it. When you put the key in it just dings and the windshield wipers come on. Can any one help me. I took it to a shop and they charged me $1,400. It worked for about a hour and went back into limp mode***129335;***127997;***8205;***9794;***65039;
Old 10-14-2017, 01:01 PM
Searching for help with E-Series (E70) on Thread for Fxx-/Ixx-/Gxx-series won't likely get you much...
And for the $1400 already paid, that shop needs to be the one helping you.
Old 10-19-2017, 09:45 AM
Brixm Brixm is offline
Mein Auto: M235i
Hello,
thanks to your help, I was able to do some coding in november 2016 on my M235I (F22). It allowed me to disable the "fake" engine sound from the ASD Module
I suspect my BMW shop did override my setting as the car is there right now so I'm wondering... Do I need to update some software / data before trying to disable the ASD again?
Thanks a lot!
Old 10-19-2017, 09:46 AM
Mein Auto: M235i
Hello,
Thanks a lot!
Old 10-19-2017, 09:51 AM
Almaretto's Avatar
Super Moderator
Originally Posted by Brixm View Post
Hello,
Thanks a lot!
Latest software is always found in OP. Not ever dealership visit results in programming, but updated firmware usually requires new set of PSdZ. You will know if you get any read errors.
Old 10-19-2017, 09:54 AM
Mein Auto: M235i
Thanks a lot @Almaretto!
I've let them the car to investigate an issue with a speaker... And told me they did some software update. So I'm wondering if they've seen a fault with the ASD and maybe flashed it back to "default".
I'll know when I get the car back!
Old 10-19-2017, 10:00 AM
Almaretto's Avatar
Super Moderator
They will not individually code settings, but part of flashing is VO coding back to factory values.
Old 10-22-2017, 05:54 PM
lax01 lax01 is offline
Mein Auto: BMW M2
How long does it generally take to get the activation code when originally installing?
Old 10-22-2017, 05:56 PM
It varies widely based on TokenMaster's schedule.
Old 10-22-2017, 06:02 PM
Mein Auto: BMW M2
Got it...I also see 2.9.11+ is out on his site (PRO 2.9.11 Build 306 as of 10/8)...the files in the OP (Mega) are still on 2.7.1.135
Assuming you'd want to update Launcher to the latest version right?
Old 10-22-2017, 06:28 PM
It is two different versions, the latest of which are:
ESysLauncherPremiumSetup_2.7.1_Build_135.msi
ESysLauncherPROSetup_2.9.11_Build_306
PRO can only be obtained from TokenMaster himself.
Old 10-23-2017, 11:33 AM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
Looking to code a 2017 X3 but cannot see the gateway. Are there updated coding files available?
Old 10-23-2017, 11:35 AM
Almaretto's Avatar
Super Moderator
Latest files always found in OP. Can you attach screenshot where you are having trouble?
