Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links - Page 5 - Bimmerfest - BMW Forums
Old 10-23-2017, 02:09 PM
Mten59 Mten59 is offline
Mein Auto: 535d M
hello, I can write new VIN with PSdZData Lite or I need complete PSdZData ?
Old 10-23-2017, 09:27 PM
lax01 lax01 is offline
Mein Auto: BMW M2
Originally Posted by shawnsheridan View Post
It is two different versions, the latest of which are:
ESysLauncherPremiumSetup_2.7.1_Build_135.msi
ESysLauncherPROSetup_2.9.11_Build_306
PRO can only be obtained from TokenMaster himself.
Mind explaining difference...?
Old 10-23-2017, 09:30 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
http://tokenmaster.blogspot.com/2015...d-premium.html
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 10-31-2017, 05:07 AM
larry_bml larry_bml is offline
Mein Auto: 320dA e90
Hello, I know that I may not ask in the right place, but maybe someone can help me.
I retrofited an ATM on my car, and everything was working OK until I wanted to upgrade firmware inside it. I used 62.2 database and because Esys couldn't find corect hardware I used HW-IDs from SVT actual, update worked OK, but after finished NO MORE DATA connection.
GPS is still working but DATA connection not. In ISTA D , ATM says it is connected to network and roaming, but .... nothing.
Now, ATM came with: BTLD_000026A2_001_031_002
FLSFL_000026A3_001_031_002
HWEL_00002AD7_113_001_001
SWFL_000026A4_001_031_002
SWFL_000026A5_001_031_002
SWFL_000026A6_001_031_002
SWFL_000026A7_001_031_002
As I can't make Esys to find correct HWEL with all FA that I tried using 62.2 database, I'm thinking to find and older database. So maybe someone has older databases and can search for files that I wrote earlyer and can tell me what database to use, at least to revert back the upgrade.
ATM came from an G12 20.10.2015.
Thank you and advance.
Old 11-02-2017, 02:01 PM
AdrianE AdrianE is offline
Mein Auto: Mini
Hi all!!
I will really appreciate ur help.
I was trying to code BDC BODY options in my f56 but I am getting and error.
BDC_BODY
readCPS o.k.
CAFD_000017BE_062_010_112 Fehler:
File for "cafd_000017be_062_010_112" not found (C012)
I have downloaded latest PSdZData files, but seems is not available.
Could someone plz share this CAFD file???
Best!
Old 11-02-2017, 03:05 PM
Originally Posted by AdrianE View Post
Hi all!!
BDC_BODY
readCPS o.k.
Best!
It is in latest 62.5, so either you have the CAFD or you don't have the latest PSdZData.
If you don't have it, download and copy to C:\Data\psdzdata\swe\cafd:
cafd_000017be.caf.062_010_112:
https://mega.nz/#!x0gzzSoJ!1K6ysk9Pl...Idvn77W9nViEeA
Old 11-05-2017, 07:40 AM
enry77 enry77 is offline
Mein Auto: bmw 116d msport lci
thankss
Old 11-05-2017, 11:05 AM
Mein Auto: Mini
Hey!!!
Thanks a lot for ur quick response!
Let me try, I will give my comments.
Best!
Old 11-12-2017, 07:20 AM
seabass23 seabass23 is offline
Mein Auto: 2005 X5 4.4
I'm trying to do a new install using the newest software. I removed all old versions.
When attempting to generate the token, E-Sys Launcher Premium is giving me an error: "Invalid provider type specified."
Any ideas?
Old 11-12-2017, 09:12 AM
Any ideas?
Sorry, no idea.
Old 11-15-2017, 11:33 AM
AlphaBetaX5's Avatar
AlphaBetaX5 AlphaBetaX5 is offline
Mein Auto: X5 e70 3.0i
Hello coders,
My laptop is loaded with:
ISTA+,
ISTA-P
NCS-expert
ToolSet32
Inpa
And other programs coming in the package on Mega.
I am trying to do some coding on my 2009 X5 E70.
My cable is k-dcan.
How can I code:
ďautomatically lock doors after x minutes ď
ďAutomatically roll up windows after x minutes ď
ďAutomatically fold mirrors after x minutesĒ
Iím sure it is a pretty basic coding task. Iím new to coding (have successfully coded an agm battery before, so Iím familiar, just need some tips)
Thanks so much
Old 11-15-2017, 11:37 AM
Another question,
Is it possible to update the CCC display software/firmware?
I have seen different displays and different menus on e70s. Mine doesnít have them.
Not sure if the display with a curvy or arc shape menu is newer.
So can/how I update that?
Can I basically do any software updating on the car?
Old 11-15-2017, 11:47 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by AlphaBetaX5 View Post
Hello coders,
This thread is for Fxx/Ixx/Gxx-series BMW's, which uses different cables and software than E-series.
You just need NCSExpert and K+DCAN, but I will not be much help since I never coded E-series
Old 12-01-2017, 08:07 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Installed Launcher Premium 2.7.1 Build 135 in a new Win 10 laptop and install never asks to create token. E-Sys installed successfully but no token anywhere. Uninstalled Launcher, reinstalled and the same thing. Any idea of why this is?
BMW OEM Audio PnP integration
www.TechnicPnP.com
[email protected]
Old 12-02-2017, 01:22 AM
Arildopc Arildopc is offline
Mein Auto: F31-325D, F11-535XD
You use launcher to start esys?
Old 12-02-2017, 02:21 AM
Technic's Avatar
Mein Auto: 2017 M3
Correct.
EDIT: problem fixed. Deleted all and reinstall.
www.TechnicPnP.com
[email protected]
Old 12-11-2017, 10:49 AM
anees anees is offline
Mein Auto: BMW E46 316i
Can I have the links to full psdzdata please ? Many thanks
Old 12-11-2017, 10:53 AM
Almaretto's Avatar
Super Moderator
https://www.bimmerfest.com/forums/sho...901081&page=58
Old 12-15-2017, 08:53 AM
valrossi valrossi is offline
Mein Auto: F10 523i
Can I have the links to full psdzdata please ? Thank you
Sent from my BLA-L29 using Tapatalk
Old 12-15-2017, 09:18 AM
Almaretto's Avatar
Super Moderator
Look one post above yours.
Old 12-28-2017, 02:31 AM
Rob_Korea Rob_Korea is offline
Mein Auto: 320D
Does anyone know if Launcher 3.0 available to download yet? I see on TolkenMasters website details of the release, but I do not see mention of how to download it on the website or these forums.
Cheers and happy new year!
Old 12-28-2017, 06:17 AM
Almaretto's Avatar
Super Moderator
Since December 23 and already an update. There is only a Pro version and must be acquired directly from developer.
Old 12-28-2017, 04:05 PM
Mein Auto: 320D
Cheers, Almaretto.
Old 12-30-2017, 02:14 PM
ZiMMie ZiMMie is offline
Mein Auto: e30
Originally Posted by coolpix99 View Post
Need some help here.
I couldn't proceed further trying to generate token with E-Sys Launcher Premium V2.7.1.135. So after entering the PIN + Confirm and I hit 'Generate Token' at the EST Software Token page , the message
"EST Software Token Successfully. Press OK to continue" appears and after clicking OK, it then would return to the EST Software Token page. This keeps going on an would not proceed anywhere further. Please advise.
Also, FreeToken.est did not get created after the above attempt and it does not launch E-Sys software either
Does anyone have a solution for this, im having the same issue.
Old 12-30-2017, 03:12 PM
Yes. get new Launcher PRO 3.x version.
